SOURCE: Not receiving alerts anymore...
My wr-100 came with a special note inserted with the instructions that the WR-100 was programmed to not give off an audible alert on tests. This is to supposedly protect you from thinking you have a real emergency. Mine is new. Maybe the older ones had an audible test alert. I assume yours gave an alert at one time??
SOURCE: Hello, my Toro 14-38 hxl (model 71193)is not
I have 12-38 hxl, and if my grass is too tall, it will wedge under the cutting deck and lock the blades, and the belt willstart smoking white. With the motor off look under and see if you do not have something stuck (branches or grass).Also, check your sparkplug.
SOURCE: Furnace unit to be louder now than last season
Check your air filter, make sure all registers are open full and there is no restriction in all ducts. Could be an unbalanced fan, clean the squirll cage fan with a brush and vacuum.
SOURCE: Trimmer wont start from storing over winter
clean the leads with alcohol but remember not to try and start it straight away.
SOURCE: ! year old, worked begining of wint. season. Now
Sorry to hear you are having trouble with the pump...Thanks to www.automaticpoolcovers.com for pulling this rule warranty information together. They sell many of these with the pool cover systems and their site tells you all you need to know about dealing with Rule warranty issues. You can find that information at:
http://www.automaticpoolcovers.net/pdfs_new/Rule%20Pump%20Warranty.pdf
Or Rule direct at www.rule-industries.com.
You may be interested in knowing they warranty the pumps for 3 years.
John
