I have an HP the monitor doent turn on but all the light are on how can i fix it.
    Sergeant:
  • 172 Answers
1. unplug the monitor from the computer and check if you can see the monitor selftest (you will see diff color bars moving around) if you see the monitor self test then your monitor is working fine
2. check the cables. use a diff cable to connect your monitor to the computer. use a known good cable.
3. plug in your monitor to diff computer if it worked then you have to reseat your video card
(NOTE : before removing any internal parts from your computer. your pc must be off and the power cable is removed, after removing the power cable press the power button for about 5 secs to remove any electro static discharge)
4. after reseating the video card and still doesnt work remove the video card from the computer. use the onboard video card if you have one.
if it does work then the video card needs to be replaced.
you can also try to reset the memory by removing them and reinstalling them inside the computer
hope this help
Posted on Sep 07, 2010
HP L1908W When i turn on the monitor, it turns on for 1 second and goes off.. Can u tell me whats wrong?!? i think maybe the inverter... Thanks, faisca
First use an external light sorce like a LED flash light. With it close to the screen do you see a light ghosty image of the desktop?
If you do then either your backlight's or backlight power circuit have failed. If the monitor is not under waranty some repair shops may be able to fix the problem.
If there is no image then the LCD is not conecting to the main board and the monitor will need to be replaced.
If you want futher details on the first instance contact me
Sep 12, 2011 | HP L1908W 19" LCD Monitor
My monitor doent turn on not even with the power cable.. what to do?
The monitor has a power supply problem and often developes bulging capacitors which become open, and there are usually other underline issues that make the repair not cost effective to fix. The only thing I can suggest is have it checked with an estimate so you can make a personal choice.
Jan 27, 2011 | Sony SDM M51 15.1" LCD Monitor
My hp pavillion mx 50 montior dosent turn on and if it does the green light on turns to an orange what to do to fix it
Check your Monitor Cable at the back of your PC unplug it and chec for bad pin conection make sure your Monitor cable are plug in correclty....
Oct 01, 2010 | HP Pavilion MX50 15" CRT Monitor
Hp pavilion.
You could have RAM problems.
Reseat the RAM module/s, they may not be making proper connection. If this doen't work you may have faulty RAM. Take them out and test them in another laptop or get your friendly computer shop to test them for you.
Jul 02, 2009 | HP Pavilion dv6000z Notebook
Vertical lines in my HP screen
Please check if you get those line as soon as you turn it on, If yes, so need to get a replacement for the screen , and if it is no, try updating video driver of your system from the manufacturer website.
Hope this work
Cheers!!!!
May 25, 2009 | HP f2105 Monitor
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Fan issue
check you thermostat and replace it , usually they go out after 10-15 years
Mar 16, 2009 | 1993 Chevrolet Beretta
Hp vs17e monitor says it's in sleep mode then goes blank
check the board postings for the HP f1903 monitor.I recall seeing a problem of the same there and a solution or fix. As it is only a newer version of the same model, it may be the same fix. Appears HP has a big problem with QA and this particular model. Lots of people have same or similar problems, and all appear to have a similar fix or solution. Tricky part... figuring out how to "Open" the monitor to check it inside!
Good Luck.
PS - if you figure out the opening part, let us all know!
Feb 02, 2009 | HP Pavilion F1703 17" LCD Monitor
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
