Question about IBM Infoprint 1332 Laser Printer
Print Cartridge Can I use the print cartridge 75P4305 in IBM Infoprint 1332 printer.
  • Jeff Weiss May 11, 2010
    Unfortunatly, no. This is the compatibility list for that part number: IBM InfoPrint 1352 / 1352n / 1372 / 1372n Laser Toner Printers
  • 32 Answers
Unfortunatly, no. This is the compatibility list for that part number: IBMPrint Cartridge - 2.gif InfoPrint 1352 / 1352n / 1372 / 1372n Laser Toner Printers
Posted on Jul 24, 2009
Infoprinter 1332 dirty copies just on one side. fuser changed March 2008
Replace the wiper blade in the cartridge and clean the primary charge roller inside on roof.
Feb 25, 2011 | IBM Infoprint 1332 Laser Printer
Tip
IBM Infoprint 1332
I want Dwn load driver IBM Infoprint 1332
on Aug 04, 2008 | IBM Infoprint 1332 Laser Printer
How many pages per minute on a InfoPrint 1332
The InfoPrint 1332 has a maximum output speed of 35 pages per minute. This speed can be less if you are using thicker paper or paper that's not 8.5" x 11", and other factors can affect the speed as well.
Apr 14, 2010 | IBM Infoprint 1332 Laser Printer
My IBM Infoprint 1552 is leaving gray spikes at
Check your toner cartridge (most print quality problems are toner cartridge problems) if that is not the problem (and it probably is) then check the fuser for toner buildup matching the defect you have. There is also a small possibility of the laser being deflected and causing this (unlikely) but clean the small mirror above the toner cartridge (it is small in height and as long as the machine is wide and up in a cavity)
Feb 08, 2010 | IBM Infoprint 1552 Laser Printer
Print out smears, makes grinding noise, replacing cartridge doesn't work
imaging unit or furnace or transfer kit attached to imaging unit needs replacement. A kit similar to this: http://www.officesupplysanity.com/home/oss/page_103490/120v_usage_kit_for_infoprint_133213521372_laser_pr.html?rid=baseIBM39V2634&utm_source=google&utm_medium=base&utm_campaign=office_supplies
may prove to be a good investment to keep your printer going.
If the cost doesn't support the value of the printer you could try to remove the imaging unit and clean it with a damp cloth and replace after dry.
Nov 07, 2009 | IBM Infoprint 1332 Laser Printer
1332 infoprint printer not supporting 1332 toner cartridge
If the toner in the machine is NOT MIRC it will not work in a MIRC printer. Get the correct toner cartridge or get a NON MICR printer to put your toner in. MICR uses a special toner (magnetic) for printing checks and the printer is usually modified at the factory (troy or others) to make it print using MICR toner. No way around it.
Aug 14, 2009 | IBM Infoprint 1332 Laser Printer
Poor print quality
you need to replace the Drum otherwise known as the photoconductor I believe the part number is 75P5712 - your toner cartridge actually seats into the PC kit.
Dec 12, 2008 | IBM Infoprint 1412 Laser Printer
Infoprint 1332
in valid cartridge refill
Oct 21, 2008 | IBM Infoprint 1332 Laser Printer
Ibm infoprint 1332`
It's quite straight forward
1. Remove the left door.
2. Remove the right cover
3. Remove the paper support
4. Remove the redrive cap
5. Press the fuser wiper cover latch and remove the cover.
6. Remove the top cover screws
7. Remove the paper bin full sensor flag assembly from the mounting bracket
8. Remove top cover.
9. Remove 3 screws and the cables, the printhead will now come out.
10. After replacing the printhead run some test prints with the cover off, loosen the 3 screws holding the printhead to make any adjustments needed to insure the print is straight.
Jun 18, 2008 | IBM Infoprint 1332 Laser Printer
Infoprint 1120 929 service toner sensor error code
The problem is caused by one of the following (normally it's the cartridge that's faulty, very common on Lexmark's and IBM Infoprints)
The toner sensor is not operating properly, the developer
drive assembly is not operating properly or the print
cartridge is defective
Jun 09, 2008 | IBM Infoprint 1120 Laser Printer
IBM Infoprint 1332 Laser Printer Logo
119 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
