Question about Acer D-Link 2.4GHz Wireless Router 802.11b (DLINKROUTER)
Locking my internet
How can i make sure that no one outside of my house is connecting to my internet?
  • 47 Answers
-Connect computer to router via ethernet cable
-Open browser on pc
-Enter 192.168.0.1 in address bar
-Username is admin
-Password is blank (nothing)
Add security and encryption:
-Click on home tab
-Click the "Wireless" button.
-Click the "Open System" button next to "Authentication".
-Set the "WEP Encryption" to "128 bit".
-Set the "Key Type" to "ASCII".
-Type a 13 digit password into "Key 1".
-Click "Apply".
-When you connect to your wireless network from a computer, you will need to enter the 13 digit password.
Change SSID:
-Click the "Home" tab.
-Change the "SSID" from "default" to an SSID of your choice.
-Click "Apply".
Posted on May 14, 2008
    Sergeant:
    Champion:
  • 271 Answers
You don't have to worry about that...router has a built in firewall...that allows only your IP...
I have moved into a hous and i do not know how to ise growatt that was inside my house already.
That appears to be for a solar energy system, you should have solar panels on the house if you have that. If the unit is small and has an antenna then it monitors your solar power and reports what the inverter on the outside of the house is producing to whomever is your solar provider. IT requires an internet connection to do this. http://growatt-america.com/
Oct 16, 2017 | Computers & Internet
My ford f150-88 no get cherge i replace the alterator
The small wire which goes to the Alternator brushes is suppose to slip over the connector post. Often the connection is missed even though the plastic connector has locked in place.
What some mechanics do is work the metal clip outside the plastic housing and then fit the metal clip on the post or tab to insure that the wire is connected. Then the plastic housing is slid down the wire and locked into the Alternator housing.
Mar 29, 2013 | 1988 Ford F 150
Can a 2wire 1000HG be used as a bridge?
You would need to look in the settings to see if it has bridge mode. A possible option for you. Get two wireless routers. Have one in the house where it is now. Run an ethernet cable from it into the shop (Max lenth should not exceed 300ft) Put the other router in the shop. Hook the ethernet from an Ethernet port on the router in the house to the WAN/Uplink port on the second router. Make sure both routers have DHCP enabled and they are on different subnets. So house network could be (Ex: 192.168.0.0) network and Shop (192.168.1.0) network. These will route correctly and use the same internet connection. If you need further directions just ask.
Jan 13, 2013 | 2wire Computers & Internet
No conneck to internet
first you must have an ISP Internet Service provider contract which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the internet or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts to set up your new internet connection
during the setup process you will be asked for a password I suggest you make a log of all pass words used outside of your computer incase of memory lapses
if you have already done this
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Apr 01, 2011 | Computers & Internet
My laptop is 2 months old and suddenly cannot connect to the internet. i have mobile and wireless internet and neither works for my laptop. Connectivity is fine for other PC's in my house hold.
also
hope this helps don
Feb 27, 2011 | Acer Aspire 4520-5582 Notebook
I cant open my internet explorer..
or if this is what you mean
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
hope this helps
don
Feb 19, 2011 | Computers & Internet
Is it possible to Wirelessly connect Router to a Router? We have a Router (outside the house) by which we connect to the internet inside the house. The problem is is that the internet connection is not...
1.Yes you can connect router to router.
2.Buy ruckus 802.11n.It got MIMO antenna.I hope it will work for u.You can use single router to access internet from all room
Feb 04, 2011 | Computers & Internet
This zhone 6212-13-200 modem continually connects, disconnects
you will need to use the power supply that came with the zhone
router......other power supplies are not interchangeable.
make sure all other items that are pluged into the other phone jacks
have inline dsl filters....do not filter the router...if you have the whole
house filter on the outside of your house you will not need to put inline
filters inside ...
make sure there are no loose connections...
last call you isp provider
Jan 02, 2010 | Zhone 6212-I3-200 Router
Internet connection dies when phone rings
There are a number of tests you can perform to find the problem unhook all the phones in your house and then call to see if it still does it. If it doesnt it may be one of your phones. If it does check the wiring in the jacks and make sure the wires are not backwards in any of them. If they all appear to be fine there maybe a problem at the pole or box whichever the company has installed in your neighborhood. Once you have determined that none of the above is present its not your fault and the providing internet company should not charge you to come out and check the outside lines. It can be as simple as a little short in the wire especially if its underground.
You may also wanna locate the phone box on the outside of your home and see if it disconnects when connected to there.
The box Outside Should Look Like This
And You'll Need To Disconnect All Of The Lines From These Plugs And Then Plug Your Internet Directly Into One Of Them. This Will Disconnect All The Phone Lines In The House. Now Place A Call To Your Home Via Cell Phone Or Have A Friend Call And If It Doesn't Disconnect Your Internet The Problem Is In The House.
If It Still Does Its The Phone Company's Problem And You'll Need To Call Them To Fix The Problem.
If This Does Not %100 Solve Your Problem Let me Know And I Will Continue Further Trouble Shooting With You.
Sincerely,
Michael Scott
Feb 04, 2009 | NetGear WGR614 Wireless Router
Wireless Connection Difficulties
sounds like your wireless card in your laptop needs either a replacement, or new drivers.
www.sony.com
May 23, 2008 | Sony VAIO VGN-FJ290P1 Notebook
Acer D-Link 2.4GHz Wireless Router 802.11b (DLINKROUTER) Logo
88 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
