Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
I have the Bissell 9400 ProHeat 2X and it will not dispense cleaning fluid. Is there anything I can check?
YES! And it was amazingly simple. The soap dispenser has a red washer/gasket thing that fits over the nozzle. For clarity, it can be viewed here: http://www.vacpartswarehouse.com/Products-p/2036677.htm
The red part can come loose and remain inside the receiver where it fits snugly and looks like it belongs there. In this configuration, the tank cannot insert far enough into the receiver to open the spring valve and no detergent will flow. Simply remove the red piece from the receiver (I used small pliers), replace it on the tank nozzle, and the detergent will flow again!
Posted on Feb 19, 2011
  • Debbie Rayner Mar 11, 2011
    Thanks so much, that solved our problem. Makes you wonder why Bissell don't put this useful info in their manual as it's such a simple fix.
  • 4 Answers
Take the water tank off, you should see 2 spraying nozzles. You need to get to these and clear them out with a needle or something. Did the trick for me.
Posted on Sep 07, 2010
How do I get Bissell Proheat 2X to work. Not dispensing water.
Did you clean the filter on the water tank. It's generally a red screen type device. Additionally, there is a filter under the Flow Indicator, unscrew the cap, lift out the propeller, lift the filter screen and clean it. Reassemble in reverse order. If you occassionally run one and half cups of white vinager through the machine it will clean out the calc buildup. Additionally, the filters should be cleaned after each use.
Feb 07, 2016 | Bissell Brushroll Proheat 2X 8920 9200...
I took my bissell 9400 series apart to clean the heater and the hoses were clogged. now I'm not sure where they go, i get all solution now and no water. i cant find a diagram of hoses nowhere,
I've taken some pictures of the inside of my Bissell Proheat 2x Plus and posted them here:
http://bbay.dreamhost.com/bissel_proheat_2x_plus/
Best of luck!
Nov 18, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat Rug and Floor cleaner. Won't
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 Proheat 2X won't dispense fluid.
heatman101
fgjhdjk
Jun 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel Proheat 2x "catches" when it is pushed forward-- Help Please!!!!
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=499675
Bissell ProHeat 2x "catches" when it is pushed...
Posted by Marlene101 on Apr 08, 2008
My ProHeat 2x bucks and catches when I try to push it forward-help!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Bissell 9500 ProHeat 2X Clean Shot Upright
The Bissell is not designed to be like a vacuum – it is designed to clean on the pull back, you dispense the Bissell cleaning fluid, the brushes scrub the carpet and the suction will vacuum up the excess water, the push forward will do the reverse action. You may want to refer to your owner’s manual and check out the trouble shooting guide for no water coming out. You may want to contact the factory or manufacturer to see if they have service tech support or to send out a new owner’s manual for your current model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac Man
Go Ahead. Use Us.
Apr 08, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
263 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
