Question about Sony HDW-F900R Camcorder
Sony f900r error code e-061 - Sony HDW-F900R Camcorder
Error 061-321 xerox workcentre 5024 - Xerox Office Equipment & Supplies
061-321 ROS Motor Fail
BSD-ON: CH6.5
The number of rotation of the ROS Motor did not come within the standard range within the specified time (5 s) after the ROS Motor On.
Cause/Action
1. Turn the power OFF and ON.
2. Check whether the Drum Cartridge is installed.
3. Check the ROS Motor (Output Check [061-001]) for operation failure.
4. Check the LD +5VDC power supply of the LD PWB J140 pin-8.
5. If no problem is found, replace the following parts in sequence:
• ROS Assembly (PL 2.1)
• ESS/MCU PWB (PL 18.3)
http://turbobit.net/upqkewkg8xjt.html
Feb 18, 2017 | Xerox Office Equipment & Supplies
Keeps giving error code 061
Hello sir; Did you recently replace new toner, if you did, please go back to check out does the door close right, otherwise you have to check the corona wire is broken?
Jan 04, 2010 | Canon CLC-700 Copier
Error code E061 0093
its a problem of dirty primary assembly or the corona and grid wires are dirty or check your front door actuators if the laser window is not open,laser can't reach the drum and will result Error 061 hope this will help
Jun 08, 2009 | Canon CLC 1180 Copier
Tring to get a urc code for new sony bravia
Try any of these....
003, 004, 011, 013, 016, 050, 061, 074,
077, 078, 107, 138, 140, 151, 170, 190
If they don't work run a code search.... If you still have no luck, then your new remote will not work with that television.
Jan 29, 2009 | RCA Universal Remote Control
XEROX PHASER 6180 LASER ERROR 061-370. WHAT IS THIS?
Chain Link 061-370 An error was detected in the Laser Unit.
Initial Actions
? Cycle printer power.
? If the problem persists, follow the procedure below.
Sep 04, 2008 | Xerox Office Equipment & Supplies
Error code 061 and the ADF door is closed
In this case make sure that the plastic tab that actuates the sensor is not broken off. If it is, try and find some way to defeat it. Other wise you will have to replace the whole transmit door assembly.
Apr 29, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Look up error code E00061001 for Canon 5020i
Title : E-061 Error Code Problem :
E-061 code is occurring for the IR5000/6000
Solution :
Check, re-seat or replace the Primary Corona Assembly
Apr 25, 2008 | Canon imageRUNNER 5020i Copier
Sony HDW-F900R Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
