Question about RCA F27442 27" TV
Why does my tv come on by itself... in the middle of the night?
RCA LED48G45RQ TV turns on by itself during the night
possible faulty power board, although it could actually be set toi turn on at a particular time..... check in the 'menu' under timer
Dec 08, 2015 | RCA Televison & Video
Tv turns itself on in middle of night
Go into the menu options and see if it has a setting for alarm. It may be turning on at the same time every night to wake you up. It is also possible a neighbor has the same infrared code and is pushing their power button and it is turning your on.
Feb 08, 2015 | Insignia Televison & Video
Digihome tv
It's probably checking for firmware updates. You may be able to turn this off in the menus, but you would then need to manually check for updates occasionally.
May 06, 2014 | Televison & Video
Problem with Sony KDL-46VL160 46 in. HDTV TV TV turns on in the middle of the night and switches input. I read it could be due to the receiver downloading the guide in the middle of the night and...
The problem in most of the case are:
1. Interference from a defective fluorescent lamp at your room sending signals to the infrared receiver of the TV.
2. Defective infrared receiver itself that sending noisy control signals to the CPU.
3. Defective manual control withes it has leakage.
4. Water damaged control switch PC board.
Jul 19, 2017 | Sony KDL Televison & Video
Sony Trinitron turns on in the middle of the night for no reason
maybe the people next door have a powerful remote, and when they turn their tv off a night it turns yours on?
Dec 11, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Jensen TV
Perhpas the TV has a timer function that is turning it on at a certain time. Does it seem to occuring at the same time of night? check the TV settings for a timer.
The only other possibility is that the camper is losing AC power in the middle of the night, and when the power comes back on perhaps the TV is turning on.
However, i rather suspect the first problem...
I am a certified RV technician, so if you have other problems with your camper please let me know
Sep 05, 2008 | Televison & Video
Samsung TV about 4 years old, the tv turned off by itself last night and for whatever reason will not turn back on. When we use the remote the middle green light comes on in the middle as well when we use...
have u repleace the lamp yet , if not repleace, 4 years old would be a lot of hours the lamp may look intact but after severals hours tv start to go off
May 03, 2008 | Televison & Video
TV Comes on in the middle of the night
another infared device tricking the set, remote lights, sky box, video senders for sky etc.
Feb 26, 2008 | Hitachi 53SDX89B 53" Rear Projection...
RCA F27442 27" TV Logo
375 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
