Question about Compaq Presario SR1000T (568657) PC Desktop
My Compaq Presario SR1000 won't turn on. There's a green flashing light to the back of the tower. I have tried to hold in the power button and everything else but it doesn't work. What could be wrong (a fuse or something)?
kikoksky
  • 119 Answers
SOURCE: CPU doesn't turn on!!
    • Power supply light on or flashes Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure: CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC.
      1. Disconnect everything from the computer, including the power cord.
      2. With the power cord disconnected , press the power button on the front of the computer for five seconds. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps. NOTE: If the power supply fan makes an inconsistent grinding sound or stops and starts erratically, replace the power supply
      3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America. Performing this step ensures that the voltage switch is engaged and set correctly for your country/region. Figure 4: Voltage selector switch c00517964.jpg Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
      4. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
      5. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it. NOTE: If you find the device that was causing the problem was a surge protector, resetting a breaker or fuse on the surge protector may fix the issue.
      6. Remove all attached devices except for keyboard, mouse, and monitor.
      7. Remove any internal component that was recently added, such as video card, memory, CD, DVD, and hard drives. An added device may take more power than the power supply is rated for. If the problem goes away when the component is removed, the only option is to upgrade the power supply to power supply with a higher wattage rating.
      8. Check the power switch:
        1. With the power cord disconnected, press the power button on the front of the PC. The button should release easily and not stick in the socket.
          • If the button sticks, it should be replaced or serviced.
          • If the power button does not stick and appears to be functioning, continue using these steps.
        2. With the power cord disconnected, remove the case or side panel.
        3. Follow the wires from the power button on the front of the computer to their connection on the motherboard.
        4. Look at the power switch cables connected to the motherboard. If the cable has become disconnected, connect the power switch cable connector to the connector on the motherboard. Figure 5: Power switch connector on Motherboard c00517968.jpg
        5. Replace the side panel, plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
      9. Find the defective part:
        1. With the power cord disconnected, remove the case or side panel.
        2. Disconnect all power cable connectors from their connectors on the motherboard and from the back of internal devices (the back of drives). Make sure to label or remember where each cable connects for future reference. Figure 6: Example of common power connections c00540428.jpg
        3. Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
          • If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
          • If the LED is still flashing (it should not flash with all connectors removed), plug the power cable into a different power outlet that is known to be good. If the LED still flashes, the power supply should be replaced.
          • If the LED light is now off, plug the power cable into a different power outlet that is known to be good. If the LED stays off, the power supply should be replaced.
          NOTE: If an electrical storm or power surge has recently occurred, then it is more likely that the power supply, the modem, or motherboard is damaged and requires replacement. If the power supply was damaged due to power outage or storm, this may not be covered under the "act of nature" policy in the warranty statement. Refer to the warranty statement that came with your computer for more information.
Posted on Jun 20, 2008
gilheero
  • 207 Answers
SOURCE: Compaq Presario S6000nx pc wont start up
check the connection of your wires through your motherboard? try to reseat those connection( caution: you must have an assistance of any qualified personnel or technician because if you reconnect it in wrong position,this will result the motherboard to burn)
BE CAREFUL!!! but this will help..
Posted on Jan 24, 2008
computafixa
  • 317 Answers
SOURCE: red light flashing on power button
Sounds like the hard drive has had a failure, you need to get a replacement one, and reinstall it, along with the opperating system, and any other programs that were on the old one.
Posted on Feb 14, 2008
acdr
  • 1913 Answers
SOURCE: Compaq Presario SR1000 desktop boot up problem
hi
change your ram.
clean your processor and reattach it.
check your motherboard dont touch the cabinet
Posted on Mar 23, 2008
SOURCE: need diagram presario SR1000 motherboard
http://www.hp.com/#Support Hewlett Pacard support will provide all you need.RICHARDM69
Posted on Dec 21, 2008
After power outage compaq presario SR1123WM desktop wont turn on
cHECK THE ps IF GOOD CHECK THE mobo COMMN BECOME DEAD AFTER POWER SURGE.
Nov 06, 2011 | Computers & Internet
Compaq presario sr1000 desktop computer. Computer fan was working all the time and making noise. I removed dust inside central unit with hoover. When I re-connected power cable, there was a flashing green...
Hold down the ON/OFF button for 10 seconds, to see if that makes anything happen.
The disk-drive could be in a "cage" -- remove the screws holding the cage in place, and the whole cage can be removed. Then, unscrew the disk-drive from its cage.
Oct 23, 2010 | Compaq Presario SR1000T (568657) PC...
I have a HP Compaq Presario Media Center computer, it is plugged to a surge protector, the other night the electricity went out and my computer was turned on, and now I cannot get it to turn on at all, the...
try removing all power cables of your computer that are connected to the surge protector. reset the surge protector. wait for about 5 minuets before you turn on the surge protector. then plug all cables that your remove from your computer the turn on the computer.
Jun 03, 2010 | HP Compaq Presario Media Center SR1750NX...
Computer wll not turn on.Where that power button is, the light is blinking green.
Please try the following:
Remove all the attachments (power cable, video cable mouse and keyboard) from the back of your computer tower. Press and hold the power button for at least 7 - 8 seconds, This will drain the flea power. Try to turn on the computer and it would start normally.
Please let me know the result. I that does not work I will provide you further steps.
Thank you for choosing Fixya
Nov 18, 2009 | Compaq Presario 5000 PC Desktop
Compaq Presario SR1000 Won't Turn On
The power on buttom might be it. Before doing anything else, check and fix the power ON button. I have a tower that gave me the same trouble. The Power On button somehow was out of place. Once I aligned it, the tower worked again. Good guess..! Good luck
Jun 14, 2009 | Compaq Presario SR1000T (568657) PC...
Flashing Green light on back and tower won't come on.
Yes, you should try replacing the power supply first. If that doesn't work, then it could be a bad motherboard.
Mar 27, 2009 | Compaq Presario S6500NX (DQ181A#ABA) PC...
On my desk-top presario
HP/Compaq has had alot of power supply issues with this series of computers. Do you have another power supply you can try in this system? If the light is flashing rapidly, it is usually a power supply. Fairly cheap and easy to replace.
Jan 26, 2009 | Compaq Presario SR1050NX (DW257A) PC...
nothing to do with the ram ... this motherboard sometimes locks, ( dont ask me why) but if you take out the power cord for 5-10 minutes and then press and hold the front power button on the machine (about 10 seconds) it will reset the board. Plug in the power cord and the basic items, sound, video etc ( some usb devices tend to stop it booting to) boot into windows. Then add the rest of your usb devices ..
Mar 23, 2008 | Computers & Internet
Compaq Presario SR1000T (568657) PC Desktop Logo
2,001 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
