Question about Whirlpool LER7646E Dryer
Whirlpool dryer ler 7620 kq8 Dryer not heating I replaced the heating element and it is still not heating. what do you think it is?
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 10, 2010
DRYER WHIRLPOOL LER 6646 SERNO. MS23065579 IT RUNS BUT NO HEAT OUTPUT TO DRY CLOTHES
I would suggest replacing the heating element these are usually always the culprit and pretty much anybody can replace them.
Check here for parts for you model number, they also have good diagrams.
Hope this helps, thanks.
May 12, 2011 | Dryers
How do i replace the fuse in whirlpool dryer for LER 7648KT0? how can i tell that it's blown, like a regular fuse? The dryer is working but no drying clothes, possible heating element? thanks- kyle
no its nothing like a a regular fuse in your car or home if you need help geting it diagnosed and fixed check here http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270664800939&ssPageName=STRK:MESELX:IT
there are about 5 possibel problems most cheap (around $10.00 for parts if you diy)
Nov 17, 2010 | Whirlpool LER7646E Dryer
I don't know anything about dryers so please bear with me. My dryer drum turns, fan blows, but wont heat. replaced heating element. Still no heat. Has 124 volts on both prongs of element. What should i do?...
Have you tried flipping the breakers @ your electrical box? Mine will do that at time when one breaker has tripped. It will have enough juice to run it but not heat it. IF that doesn't work there may be a broken wire to the heating element or possibly even a faulty heating element. I'd try the breakers first though.(Im not a professional I've just been a single mom for 18 years and have found myself working on all sorts of things and gaining knowledge from hands on experience) Hope it helps & works.
Aug 03, 2010 | Whirlpool Dryers
Whirlpool LER 6620 heats, but does not tumble.
if the dryer heats the motor should be good. if it hums its either runing or the hum is a stall noise . if belt is in tact then if motor were going so would the drum . so i think the motor isn't going just humming and the heat sw in the motor is stuck closed with lint and you need to replace the motor .. take the belt off and turn motor if it turns free . the blow it out good and reinstall belt and try again ..mm
Dec 03, 2009 | Dryers
Dryer will run but does not heat up
Either bad heating element or missing one leg of the 240V circuit. The motor runs on 120V.
Sep 24, 2009 | Whirlpool LER4600 Electric Dryer
Electric dryer has not heat model # ler 4600
Normally caused by bad thermostats and or heating element
Sep 24, 2009 | Whirlpool Dryers
Dryer won't heat yp
You are going to need a heater element OR a limit kit. A simple continuity check is all that is needed to confirm the failed part. Remove one wire from each component you check so you do not get a backfeed (false reading). Remember to unplug the machine.
If it turns out the clixons are all good and the heater is fine then the timer will probably be the culprit.
Dec 14, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool Ler 7620 Lwo
Thermal fuse for the motor is out. It's on inside on the back wall. look for the two blue wires connecting to it.
Sep 05, 2008 | Whirlpool LER8648P Electric Dryer
Dryers Logo
183 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
