Washing Machines Logo
Posted on May 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tub will not spin after wash or rinse cycle - Washing Machines
  • 1 more comment
  • robertw0129 May 17, 2008
    Thanks for the reply. Checked the pump. impellors are clear. Water drains from the tub ok. but, the tub does not spin in any cycle.
    Thanks for the reply, Sorry I havent responded sooner, just now had a chance to look at the machine. The tub does not spin after any cycle. Checked belt on bottom of unit and it is in place and appears ok. I question the possibility of bad contacts as this washer has several wash cycles and the tub does not spin on any one of them. What type of mechanism engages the tub to make it spin? MATAG PAV2300AWW
  • robertw0129 May 20, 2008
    Belts is good woth no burned spot. the pulleys are also tight.It appears that the transmission is bad.I am pretty sure the lid switch is ok, as I can hear a clicking when the lid is opened and closed in the spin cycle. I think it is time to give the may tag repair man something to do. Thanks
ALBERT GARCIA
Level 3:
  • Master 975 Answers
  • Posted on May 14, 2008
ALBERT GARCIA
Master
Level 3:
Answers
975
Questions
5
Helped
358184
Points
2970
Check out the DRAIN MOTOR PUMP , it could be clogged , open panel of washer , check a little motor with 2 hoses connected to it , remove MOTOR and check inside the IMPELLERS , remove any debri , clean it , and install again , it should be working properly , hope this helpd AJ
Benjamin Patri
Level 3:
  • Master 3,037 Answers
Benjamin Patri
Master
Level 3:
Answers
3037
Questions
7
Helped
706528
Points
8239
But it does spin during the wash cycle, correct?
  • 5 more comments
  • Benjamin Patri
    Benjamin Patri May 14, 2008
    Well, instead of waiting for your reply, I will assume that it does spin during the first two cycles so your problem is most likely is that the timer contact in that spot is faulty.
    Replacing this timer will fix your problem.
  • Benjamin Patri
    Please let me know if you need any further help and I would be glad to do what I can.
  • Benjamin Patri
    Benjamin Patri May 17, 2008
    Does the motor sound like it is working when running? If so, then your transmission needs to be replaced on the washing machine. Also, you said the belt looks fine but check the pulleys that it is on.
    Check out the following links for diagrams and parts. Also please let me know what else you need and I would be happy to help. Thanks
    http://www.repairclinic.com/0100_21.asp
    http://www.partselect.com/PartSearchResu...
  • Benjamin Patri
    By checking the pulleys, I mean, do they turn and does the belt look worn from possibly non-turning pulleys
  • Benjamin Patri
    Also another thing to check is the lid switch which may cause the tub not to spin or agitate.
  • Benjamin Patri
    Benjamin Patri May 19, 2008
    alright, so where are we at, what have you checked?
  • Benjamin Patri
    Benjamin Patri May 20, 2008
    no problem, good luck
5 Related Answers
Terry Schneider
  • 177 Answers
  • Posted on Jul 12, 2008
SOURCE: I own a Maytag Performa
sounds like you have a tub seal problem, which took out the bearings, I take it one buzy mom does lots of laundry! Maybe time for a new washer.
A
Anonymous
  • Posted on Oct 18, 2008
SOURCE: Whirlpool Model LSV6234AWO
door switch bad?
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Feb 23, 2009
SOURCE: washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Anonymous
  • 582 Answers
  • Posted on Aug 12, 2009
SOURCE: washing machine will not advance through the wash cycle
when it reaches the stopping point does it stop after the wash cycle if so try pushing the switch to the lid with a popsicle stick and see if it goes into the spin cycleif it does the lid switch is bad. the washer will not go into the spin cycle unless the lid is closed and if the swich is bad it won't let the time advance
Anonymous
  • 228 Answers
SOURCE: Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Tub sometimes will not spin to wring out clothes.
Sounds like the machine is not pausing between cycles to allow the transmission to lock into spin.
Eric
The tub will not spin in the rinse cycle
This sounds like a timer problem if it will spin in other cycles. If you hear a motor running but no spin it is the motor couple.
Washing machine will not go thru it's spin cycle.
I just replaced the 4 rubber straps on the tub. Washed a load and it worked fine. Washed a second load and it did not spin on the rinse cycle. Checked the wiring on the switches. All OK. What do I check next. Did I mess up something around the tub ?
Rinse Cycle
Is this a fairly new Energy star machine? If it is the rinse cycle is a spin only cycle with several spray rinses.
You may have an option switch that gives you a Fabric softener option, use this option and you will have a deep tub cold water rinse.
Make sure you are using He detergent.
If you have soft water use less detergent
Let me know if you have further questions.
Your sales rep should have told you this!
Washer LSQ8543JQO -- in cycle issue
what brand washer? if lidswitch is bad most washers will not drain and spin to move to the next cycle
Top Washing Machines Experts
john h
