Question about Fujitsu 24C1 Air Conditioner
Fault with 241C Aircon
We have two fujitsu inverters in our office. On both units, the operation light is flashing rapidly, and the timer light is also flashing continuously. Any advice??
  • Anonymous Jul 01, 2008
    I have the same problem
  • 615 Answers
This happen when you use the inverter for a long time and start getting old and over heat...try to power down the units and keep it for about an hour and then starft them again and try to install a small fan to keep them cool.
Posted on Sep 08, 2009
Fujitsu Aircon model AST24PBA-W has green Timer light continuously flashing and red Operation light giving 5 flashes. Outside unit fan will not run. What does this code indicate has failed?
Most likely a faulty fan motor. You will need a tech to diagnose correctly as this uses a DC motor which has a circuit board inside so has very specific tests. Other possible faults for this code are compressor rotation error, CT abnormal or current trip all of which will need a tech to diagnose.
Nov 04, 2017 | Fujitsu Heating & Cooling
What does error message mean on Fujitsu inverter aircon model ASTA30LCC. red operation light flashes on 5 times with green timer light flashing on twice. Can someone please tell me what the fault is?
This is an "Outdoor unit control error" - specifically, a "Current trip error". There is a problem with one or more of the outdoor boards and you will need a tech to diagnose.
Jul 18, 2016 | Fujitsu Heating & Cooling
I have two flashes on the timer light of my indoor unit of Fujitsu Inverter ASU9RLS
Serial signal (reverse) error, at operation start up. operation led - off, timer led - 2 flashes, coil dry led - off, check wire between indoor and outdoor
Jul 10, 2015 | Fujitsu ASU9RLS2 Single Zone Wall Ductless...
LG aircon operation light flashes 8 times and then shifts to timer light flashes 4times and then back again to operation light but aircon is not operating.
jz on the aircon manuly on inside the front door.lift the front on the indoor unit there the on/off button,jz press it.don't use remote it can help u
Apr 20, 2014 | LG Heating & Cooling
FUJITSU Indoor Inverter ASTA09LCC/ASTA12LCC airconditioning - not cooling
If the operation button is flashing 8 times, the timer light should also flash 4 times in each sequence. This indicates a failure of the PFC circuit in the outdoor unit which basically means a faulty outdoor board and will have to be replaced.
If the operation light is flashing 8 times by itself, the indoor controller board may have a fault. You can normally test this by putting the mode on the remote to 'Fan' and checking that the controls otherwise work normally - louvers work as directed and fan speed changes correctly when selected on the remote.
Most likely the fault lies in the outdoor board but you should contact a tech to diagnose correctly.
Sep 24, 2017 | Fujitsu 18C1 Air Conditioner
Ihave a fujitsu air conditioner model asta18lcc about 2 yrs old when I turn it on fan works but room wont get cold or hot,red operation light does not stay on but green timer light flashes on. thanks...
The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
Aug 13, 2010 | Fujitsu 24C1 Air Conditioner
Fujitsu inverter air cond. Just stopped working properly. Model outdoor AOT30PMAL indoor unit AST30PBA-W. Code oper. Red led flashes fast continously green led (timer) repeats 13 slow flashes. After power...
It sounds like your inverter is at fault. You will need an inverter tester ( most good service techs will have one ) to prove that the output to the compressor is correct. If the inverter is okay then it will be the compressor at fault with a location error or it is simply seized. A common fault that caused this was the eev remained closed (coil failure ) and caused the compressor to over heat.
May 11, 2010 | Heating & Cooling
The timer light flashes twice about every 15 seconds
This may mean that the filters may need to be cleaned. According to service manual the unit has a "Serial reverse transfer
error at start up operation". Call fujitsu for service if the fault cannot be rectified.
I take the time to answer your questions, please rate me
Mat
Aug 28, 2009 | Fujitsu Heating & Cooling
Fujitsu 24C1 Air Conditioner Logo
675 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
