Question about Whirlpool Duet GHW9150P Front Load Washer
THE DRUM WHEN SPINNING MAKE LOUD KNOCKING NOISE? THERE ALSO IS LONG MELTED PLASTIC PIECES COMING FROM FRONT DOOR AREA.
The plastic pieces are from the friction of the metal spinning onto the white plastic, Part cost about 187 but I am thinking of just ditching this crappy washing machine, something is always going wrong. call me 3616432681
Posted on Sep 07, 2010
Hotpoint aquarius wm64 loud banging noise when spinning with full load no noise when spinning empty i have found small pieces of plastic inside drum
Several possibilities here.
First and fore most is the drum support or main drum bearigs are failing., more likely to be drum support
The pieces of plastic you refer to are from inside the outer drum, because what is happening is the inner drum is catching the outer drum, and breaking the plastic inside.
You are going to have to strip it down to determine the exact cause, what I expect you will find is that the alloy 3 legged drom support has corroded away,a nd the drum has come loose.
Hope this helps you solve your problem
Nov 28, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
I have GE profile Model DPSR473EW with loud squeak when drum turns ? I also need to learn how to access the drum etc...
I have experienced two problems with "loud squeeks" with the DPSR473EW. First, if you take the top off (open door, remove two screws under top door lip releasing the top), then.., remove two small screws (inside up high - one on each side) holding the front panel/door assembly on. Pull the front panel/door assy away from the main unit - can't seperate due to some wires near the blower. On the door/front panel assy..., you will see four "teflon slides" that fit into a plastic semi-circular assy (the drum rides on those four teflon slides). Most of the time, this is where the squeeks come from - I've seen them worn thru..., and the drum riding on the plastic (just order the teflon slides - qty 4 - WE1M333). If the plastic piece that the slides fit into is worn, replace it - WE2M26 (top bearing). This should do it. If the slides look OK (so the squeek hasn't been fixed), the other place for a squeek is...., the back bearing. This bearing is basically a male rotating plastic sleeve running in a metal female hole. I have seen those wear thru the plastic bushing..., causing lots of noise. To inspect that bearing, you will need to a) remove the belt (plenty of instructions on the internet), then b)remove the drum..., then..., you can inspect that back bearing (two pieces - one piece on the back of the drum, the female piece mounted on the heater shroud.. If you need to replace that bearing, or one half of it - you can order pn WE25M40 - it will have both pieces. Good Luck
Nov 15, 2009 | GE Profile DPSR473EW Dryer
On the final spin the washing machine is so loud you cant even be in the same room as it, it is not vibrating externally as far as i can tell
Remove rear access panel, and remove the drive belt.
Spin drum by hand, and if it feels rough or noisy, then the main drum bearings have failed, if no noise, then check motor for noise, if no noise, check the concrete wieghts are not loose, and that the dampers are not broken or worn.
Please rate my solution.
Thanks.
Nov 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Spinning cycle has become very noisy on fast spin
Hi
The most common cause of this is the main drum bearing seal has failed and water has washed all the grease out of the drum bearing and knackered it. You will hear a loud roaring noise on the fast spin when this has happened. As it's certainly not a 5-minute-job, it's not economic to have this fault repaired on an older machine if you are paying for the repairs yourself. Get a new machine.
It is fairly unusual for balance weights to come loose as they are usually held tight by locking nuts. I've seen it happen but not very often. Sometimes they break off the drum completely. Symptoms of this are loud knocking noises, the machine attempting to leave the building while on a fast spin and a heavy piece of metal/concrete on the floor under the machine!
Thanks for contacting Fixya.com
Oct 11, 2009 | Zanussi FLA1201W Front Load Washer
Loud grinding noise when machine operating
Hi
Oct 11, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Makes loud noise during the spin cycle.
no loud noises water will drain, just belt broke plastic piece needs to come off so I can replace belt.
Sep 13, 2009 | Kenmore Elite 45986 Front Load Washer
Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Loud rattling noise, but dries ok
The drum of a dryer is supported b the front and back of the unit, spins on a felt gasket. Noise is coming from rollers or their is something stuck between drum and the felts. The pulley is a piece of springy metal with a plastic wheel on it, could also be worn. If you take off front of dryer, drum will come loose, check to see if something is stuck. Common for loose change to get jambed in felts. Also spin rollers and pulley to see if need to be replaced. I still think something is caught in felt.
Aug 17, 2009 | Kenmore 63942 Dryer
Front loader making loud noise with spin cycle
It may be something that was in the wash and fell thru the holes in the inner drum. Check all the plastic agitators and make sure they are all secure and an attach bolt has not backed out of one and rubbing the outer tub. It will wear a hole in it fast if it is.
Usually when the bearings go bad, it gets very loud on the spin cycle, like a loud roar and sometimes clothes will have rust or grease stains on them.
I just replaced my tub bearings on my Frigidare and spent about $60. They are all pretty much the same. On mine they only list the complete rear outer tub assembly with bearings, but you can knock the old bearings and seal out and match them up at a bearing supply house or you can buy online. Online seems much cheaper. If you buy bearings, make sure you get ones with a -2rs on the end of the part number. ex. 6308-2rs. They are sealed and hold up much better in water environment.
I would give it a try, the junk man doesn't care if it comes in pieces or one big piece.
There are a couple online articles that can probably help you. Do a google search for 'washer rear tub bearings"
Jan 29, 2009 | GE WPXH214A Front Load Washer
Loud Knocking
this is a collapsed drum bearing, one of the most costly of the repairs apart from the timer and motor, not normally a job for the diy man unless has an engineering background, sorry, the cost of repair depends on the age and replacement cost of a machine, a bit like a car, would you buy an engine for a 20 year old car, if you have a machine thats expensive then the repair could be worth it? stop running it you will cause more damage both to the clothes and the machine sorry (ps i am a retired appliance engineer of 20 years service)
Sep 18, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
211 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
