Question about HP Computers & Internet
My monitor suddenly goes black for no apparent reason. I have checeked a nd RE-checked all connections. The monitor has been working fine until now...there have been no changes to it. I can turn off the power switch, then turn it on again, and it will only stay on for a few seconds before going black again. Solution?
    Genius:
  • 1,478 Answers
If you turn the monitor off then about 1020 sec turn it back on and have a picture for few seconds again, it sound like the power supply in the monitor. But if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Posted on Sep 07, 2010
DS240WB worked fine but seems now not recognizing signal and fails to turn on
The reason why your monitor might not be recognizing a signal is because the graphics card in your pc might not be correctly plugged into a pci slot or your internal graphics may have a short somewhere. If the monitor turns completely off after it cycles Then it might be an internal problem with the backlighting in your monitor screen
Dec 07, 2013 | DoubleSight DS-240WB Monitor
Monitor works ok then suddenly loose picture(black screen) turn monitor off then turn it back on works for approx 5 secs then goes back to black screen
there are many reason why a monitor suddenly turned off then back to work again , over use may over heat that cause the soled parts on the printed board of your CRT go loosen , try to re sold it, sometimes your PC might stop viewing so the monitor automatically shot off stby mode , loose connection due to basted parts , capacitors,power regulators,resistors , even the cables also might be.
Jul 10, 2011 | Fujitsu Siemens MCM 173V (White) 17" CRT...
My monitor works fine for weeks than suddenly just goes black! I turn it off and back on and it only stays on for about three seconds than goes black again! The power light stays on!
take off the monitor data cable from pc and try to turn monitor on if appears a smal square on the screen that mean your monitor is ok , and the black screen reason maybe data cable or vga card.
note : your monitor resolution is 1680x1050 some times wrong resolution cause like this problems
if you see that is helpful please don't forget to vote me
best regards
Apr 22, 2011 | Acer P221W LCD Monitor
My Viewsonic vx922 was working fine until this morning. The computer had a problem and I restored it to the original factory settings. I had to download the drivers for my Radeon card to allow me to do 2...
Looking like there is an issue with the powerboard on the monitor. This problem you are having appears to be common with this monitor, with a lot of them failing for no apparent reason
Jan 05, 2011 | ViewSonic VX922 19" Monitor Flat Panel
Monitor is black but power light is blinking green. Worked fine last night, but this morning screen was black and light was bliking. Suggestions? Thanks!
Firstly check the power cables nd VGA port is it proper or not nd then if this is proper then ur problem might be in RAM remove the ram and rub it with eraser nd insert it again nd check CMOS battery also ....u will surely get a positive result....
Aug 31, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
My monitor went black, and the power switch just flashes.
is your CPU working properly? if that the case, your monitor is in need of a service.
reasons for why a monitor goes blank?
Reason 1: Wetness
The number one reason why computer monitors go blank is - wetness. Believe it or not, when your computer monitor is exposed to humid air, sometimes water can condense and accumulate in the monitor. This causes the monitor to malfunction and go blank. I've had this happen to my desktop PC at least three times before. What you need to do is to leave the monitor alone for some time and allow the water to evaporate. That usually solves the problem.
Reason 2: Faulty Graphics Card
The next reason why your computer monitor goes black is due to a faulty graphics card. The best way to detect this kind of problem is to connect up a new monitor to your PC, then check if you have a blank screen. If you continue to have a blank screen, then it's likely your video card is faulty.
Reason 3: Faulty RAM
This one is less obvious and less common, but it can happen. You might sometimes get bad RAM modules which prevent your PC from booting up even to the basic BIOS startup screen. To detect this kind of problem is more troublesome, you might need to remove those RAM modules and insert them into another computer.
Reason 4: Loose Connections
Another reason why your monitor goes blank is due to loose connections. The connection from the monitor to the mains is usually a culprit, as is the connection between the monitor and the video card. Check those connections before you declare your computer monitor as faulty.
Reason 5: A Short Circuit In The Motherboard
And the final reason why your computer monitor goes blank? It's possibly because of a short circuit in the motherboard. This is the most undesirable outcome of course, as you might have to replace your entire motherboard. However, it's possible that this can happen - so keep your fingers crossed and hope it doesn't happen to you.
try this.
please rate my solution.
have a nice day.
Jul 05, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor black screen prob
disconnect the monitor from the back of the system and see if u see the colour scheme or anything if u do see something that means monitor fine ... problem with system
Sep 19, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
M70 crt
just check the power cable from the monitor is connected properly or not try reconnecting it...
may be there is some loose contact in power cable............
check the cable which connects the cpu from the monitor is connected properly check whether is there any loose contact try reconnecting it...........
if problem persists then there is a problem with operating system try reinstalling it....
Feb 10, 2008 | HP Pavilion M70 17" CRT Monitor
Black Screen after sitting for awhile
Might be that the graphics card is overheating.
Nov 08, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
212 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
