RCA am-fm steroe radio / dual cassette recorder & compact disc player model rp-9518A. when I try to play a disk it stops and then restarts again at all 5 stations need to know what may be the cause or is there a lubrication that I can use. [ help ] thank you
    President:
  • 1,851 Answers
I assume that the problem occurs on the cd player. If this problem occurs only at this cd it's a disk problem. If it occurs on various disks try using a cd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alcohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropyl alcohol to clean up the cd lens manually. In case this doesn’t solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 07, 2010
I was attempting to install a new stereo in my 2000 taurus. it requires to an adapter to put the new stereo in. i got the new adapter and stereo in *kinda* but decided i didnt really know what i was...
check your fuses first. You may have blown one.
Visual Inspection Chart Mechanical Electrical
  • Integrated control panel (ICP) physically damaged, misaligned, any control(s) inoperative
  • Digital audio compact disc player physically damaged, misaligned, any control(s) inoperative
  • Antenna or antenna cable physically damaged, misaligned connection(s)
  • Radio speakers, mounting/speaker cones physically damaged, misaligned
  • Radio ignition interference capacitors, radio frequency interference suppression bond misaligned (also check for cleanliness and metal-to-metal contact)
  • Battery junction box (BJB) fuses F127 (5A), F117 (20A), F127 (5A).
  • Central junction box (CJB) fuse F227 (10A) F211 (15A), F216 (15A), F226 (10A) (wagon only)
  1. If the fault is not visually evident, proceed to diagnose the integrated control panel (ICP) by entering the ICP Self-Diagnostic Mode.
NOTE: To enter the ICP Self-Diagnostic Mode, the ICP must be ON and in radio tuner mode (AM/FM).
  1. Enter the diagnostic mode by pressing and holding preset buttons 3 and 6 simultaneously. This will suspend all radio functions, and display SP.
  1. Preset Button 1 = Audio internal/external SELF TEST. The display will flash SELF while gathering the diagnostic trouble codes (DTCs), then stop flashing when complete. Press the TUNE UP button to display the DTCs if any exist. Record codes and refer to the following table:
ICP SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit (RCU) 2 No response from cassette player 3 - 4 No response from compact disc player 5 - 6 - 7 No response from remote climate control 8 - 9 Read Only Memory Verification failed
  1. Preset Button 2 = Displays the feature strap for code identification, refer to the following table.
Code Description 01 Base-Electronic Search Radio (ESR) with Manual Climate Control (MCC) 07 Electronic Search Radio with Cassette (ESC) with MCC 17 ESC with Electronic Automatic Temperature Control (EATC) 97 Not programmed default of ESC with EATC
  1. Preset Button 3 = ICP and RCU identification. This test identifies the software level of the ICP and RCU. The ICP is tested first, followed by the RCU. The display will have two sequences of three codes each. The first sequence is for the ICP, the second sequence is for the RCU. For code identification, refer to the following table:
Item Part Number Description 1 - Product variant code 2 - Tape model 3 - CDR
SOFTWARE IDENTIFICATION CODES Product Type Code Description Product Variant Code Description 21 ICP 07
08
09
10
11
12 EATC with AM/FM, cassette player and CD changer
EATC with AM/FM and cassette player
Manual A/C with AM/FM and cassette player
EATC with AM/FM cassette player and CD changer 31 RCU 01
02
03 Analog
Digital
Midline 71 Remote climate control 01 LH drive 52 Compact disc/disc jockey 01
02
03
04 Sony® 10 disc
Sony® 6 disc
Clarion® 6 disc
FMS 6 disc
Sep 13, 2011 | 2000 Ford Taurus
I need a power cord for RP-7986 AM/FM Stero Radio/Cassette Recorder/Compact Disc Player.
Depending on where you live, you can find them at Radio Shack, Walmart, most discount electronics parts stores,etc.They are universal except for the physical plug style at the unit side. Best bet is to take the unit with you if possible for a perfect match. Hope this helps
Dec 22, 2009 | RCA RP7986 CD Player
Want to know how to program a rca rcr3273n remote control thats got no code search button
If you have a later set and an older remote, it will not have a compatible code.
If you are just missing the codes for your remote, try here:
Some RCA remote codes
Sep 07, 2009 | RCA Universal Remote Control
I have got a rca 5 disc changer rp 8055c it want play my cd
RCA 5 DISK CD PLAYER AND RADIO CANT HERE MUSIC LIGHTS COME ON CD PLAYS BUT NO SOUND.
HELP
Aug 16, 2009 | RCA RP8078 5-Disc CD Changer
Luxman Digit synthesized stereo Receiver AM/FM & Phono not work'g
The problem is still there, but I am expecting HELP fir free.
May 11, 2009 | Car Audio & Video
RCA audio system,and three disc. autio radio works , but the three dicc player will not play any audio discs. I think the tuner is out of programing. Haveany suggestions. it is a am fm radio and compact...
I always encountered that kind of problem,the audio works but discs player not working.This kind of a problem of a disc player had three causes,first the lense is busted already secondly the MPEG MEMORY IC is busted,thirdly the roller that's moving back and port bringing the lense set stock up full of dirt this is most common problem.That why whateveryou did is not functioning.If you know how to open your unit it's better. First you do is to clean the roller with the use of a lighter fluid to take the old greases that already harden with dirt. After that all is clean put a first class greases type-A only little to the roller and wipe the lense with a cotton buds. If all this procedure nothings happens,you better change the lense with desame code number, to avoid conflict.If the lense is change still not functioning that's the time you change the MPEG memory IC.I assure it to you it's works 100%.
Jun 15, 2008 | RCA Audio Players & Recorders
112 people viewed this question
 Grubhead
Grubhead
