Question about Samsung 226BW Monitor
If i try to connect to 1680x1050, my screen goes dark. but when im using 1600x1000 it still desplays
    President:
  • 1,851 Answers
The resolution 1680X1050 is the native resolution for your monitor. This means that the best view for your monitor is for this resolution. Your problem in not at the resolution, it's at the refresh rate. How to fix this? Go to the settings for your screen. At the lower right corner you will locate "for advanced users" button. Click on it and choose the "screen" tab. At the lower part of the window you will locate the "refresh rate". Click on it and change it at the lower setting (about 60 - 70 Hertz). Click on aplly - OK. You will be back to the resolution settings page. Set the resolution at 1680X1050, apply - ok. Go back to "refresh rate" window and change the setting to a higher setting STEP BY STEP. In case of an "out of range" and blaack screen DON'T DO ANYTHING, at 15 seconds you will come back to the previous settings. With this procedure you will get the native resolution for your screen with the higher refresh rate.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 07, 2010
Auto detect analog
Hi Jessica,
Dell E228WFPC/E228WFP does support displays with 1920x1080 set resolution via DVI connection while it is restricted to validated Dell brand displays:
  • The restriction applies to resolution higher than 1680x1050 via DVI connection.
  • No restriction with VGA connection, which supports up to 1920x1200.
If you use a DVI connection set your computer's resolution to 1680x1050.
http://downloads.dell.com/Manuals/all-products/esuprt_electronics/esuprt_Display/dell-e228wfp_User's%20Guide_en-us.pdf
Feb 19, 2014 | Dell Computers & Internet
I just installed cosmi casino on my dell laptop. The display is set for 1680x1050. But when I start up the casino games the display comes up 640x480. I go to the display section on my cmptr. and it...
Maybe the game settings is set to 640x480.Here follow the steps below if this will help you.
  1. Run the Game
  2. At the menu screen, go the the Option then check the video or display settings if it is set to 640x480.
  3. If it is Set to 640x480 change it to 1680x1050.
  4. If the display is already 1680x1050 then try the 2nd option below.
Another option.
  1. On your deskop, Right click the icon of Las Vegas Casino.
  2. Then on the menu, choose properties,
  3. On the Properties, go to the Compatibility Tab.
  4. On the Compatibility Tab, check the display settings if the " Run in 640x480 screen resolution " is activated, if Yes then just uncheck the box and then click apply and Ok.
  5. Run the game and you should be in 1680x1050 resolution now.
Goodluck, hope my solution will help. Please give some feedback regarding my solution.
Thank you very much for using Fixya! Have a Great Day!
Jul 10, 2011 | ValuSoft Las Vegas Casino Players...
I cannot get good resolution in my Hannspree HF229H, what can I do???
The resolution you should be getting is 1680x1050. Under Windows 7, right click on your desktop then open 'Screen Resolution'. If the resolution is set to anything other than 1680x1050, set it to that. If that setting is not available then it is possible that your video card does not support that resolution. This would only effect old computers. If the resolution is set to 1680x1050 but you don't have the proper resolution onscreen, try adjusting the monitor settings using the buttons on the bottom of your monitor. Hope this help and have a nice day!
May 02, 2011 | Hannspree 22" widescreen LCD Flat Panel HD...
Hello, I have a Toshiba Dynadock U Universal USB Connect Docking Station. I have a Dell laptop with Windows 7 Professional. I set my screen resolution at 1680x1050. Whenever I turn on my laptop, the...
why dont you disable hibernation as it seems the dynadock is outputting a signal that is the maximum that your external monitor / tv is capable of showing
Feb 28, 2011 | Toshiba Dynadock USB Docking Station
I have a custom built computer with dual NVIDIA GeForce 8400 GS - 512MB - 16X PCI Express. Until recently, I had two Eizo L565 monitors. I had one connected by DVI-D and the other by D-Sub. I acquired a...
You have to use the dvi-d cables on both video card in order to get the higher resolutions on both screens. also the nvidia control panel must be set up the right way so that both screens receive the higher resolution.. there should be a selection for panning across both screens, and another for selecting apps on 1 screen and main os on the other. try changing those settings around, more than likely that is the reason that it's going at a lower resolution.
Dec 17, 2010 | Computers & Internet
Trying to get the screen size fixed properly. screen needs to be set at 1680x1050. It is making pictures look fat
u need to check if ur monitor is capable of handling 1680x1050...resolution
go to Desktop/right click on desktop/go to properties/settings.../in the screen resolution optopn/do u c a slider than has option to select ur 1680x1050
if it has then chose that and click OK....
if ur monitor can show that resolution it will give ua msg else u wont..
mind it...a higher resolution and change regresh freq rate can spoil ur monitor....
so be careful while doing this
Dec 17, 2009 | Computers & Internet
The screen is very, very dark. Someone told me the backlighting might be broken, but I don't know. I can just barely make out things on my desktop. The lighting can't be turned up.
make sure your wire is connected to the main power, cuz it could be loose, my laptop goes dim if its not connected to the main power, but im not sure about very very dark
Jul 04, 2009 | Dell Inspiron 1420 Laptop
1440x900 Monitor seems to think it is a 1680x1050 screen @ >19"?
Try reinstalling the video driver (Control Panel - System - Device Drivers - Video ... ) Good luck
Jun 13, 2009 | ViewSonic VA1930WM LCD Monitor
Scrolling lines on monitor
Weird... if there's still warranty on the monitor see if you can get it fixed or replaced with a new one.
Mar 06, 2009 | LG W2252TQ Monitor
Viewsonic vx2245wm
You need to chk graphics settings in NVidia control center and change resolution until it looks right
Mar 06, 2017 | ViewSonic VX2235wm LCD Monitor
Open Questions:
See all Samsung 226BW Monitor Questions
Samsung 226BW Monitor Logo
142 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
