Question about Emerson Pool & Spa
When vaccuming pool,after attaching hose to skimmer water pressure resort to priming stage.wyh?
  • 331 Answers
You need to pre-prime the hose with water. remove the hose, vac head and pole from the pool. lay the hose out straight (not coiled up). with the pole and hose attached, lower the vac head to the bottom of the pool. carefully feed the remaining hose over the pool wall vertically down into the water hand over hand until the end of the hose is at the water line, water should well-up out of the end of the hose. keeping the end of the hose low at the water line, bring it to the skimmer and through the skimmer opening. stick the end of the hose down into the vacuum port in the bottom of the skimmer pot. this should resolve the loss of flow at the pump from gulping air through the hose.
Posted on Sep 08, 2010
  • l_stubbs Sep 23, 2010
    did exactly as you suggested.worked fine until all the water has passed thru the hose.goes bace to priming mode.when i see air coming out of the water inlets,i can take the hose out of the skimmer opening,when i do that water start to bubbling back thru skimmer.when stop and water return back to normal flo,i can return host to skimmer get strong pressure until the water has passed thru hose.back to primming mode.where is all this coming from?
  • Charles East
    Charles East Sep 23, 2010
    It might be a possibility you have a hole in the hose. Remember that the hose is being used to **** water. not air. The end of the hose (vacuum head) must remain under water at all times. But also understand that if there is a leak, hole, crack or loose connection that is NOT under water, then the suction action happening inside the hose will pull air into that opening, which if enough, will cause the pump to drop prime. Listen for a hissing or gurgling sound along the hose. You can set it up as previously suggested or as John224 suggested and once suction is established, leave the vacuum still underwater and watch for bubbles in the leaf trap of the pump or listen for a hiss in the section of hose not completely underwater.
    Another matter you have to attend to, is keeping the water level up above your skimmer opening(s). If your vac hose is going down into the skimmer pot, the water in the pot must remain full at all times or air will be sucked in when the water is gone. If you have your filter system set to backwash or any other setting that would remove water from your pool, the level is going to drop. so add water as necessary to keep the level several inches above the bottom of the skimmer opening(s)
    Another possibility is a preexisting air leak in the suction line of the skimmer back to the pump. If the leak is really small, it may not pose a significant issue for the pump as far as dropping prime, but would produce a small amount of air bubbles showing in the pump all the time. As suction increases, the leak would become more prominent, which adding the vac hose would do. Your pump should not have any air bubbles present when the system is setup for normal operation on filter and not vacuuming. If there is air bubbles, then you have an air leak.
    Your pump lid o-ring seal must be clean, no cracks, and lubricated with a suitable sealant like Aladdin's Magic Lube or similar product made for this. DO NOT use vaseline or petroleum based products as these will deteriorate the o-ring. Make sure there is NO debris on or around the oring. tighten the lid is instructed by the pump manufacturer. If it is a threaded lid, then hand tighten ONLY! If the lid is leaking air while the pump is running, shut off the pump and immediately tighten the lid some more by hand is possible. Do not over-tighten the lid using a wrench. It will be very difficult to remove later.
    Knowing how your plumbing is laid out would make diagnosing this easier for you. If this is an in-ground pool, you likely have a bottom drain and 1 or more skimmers. In many installations, the bottom drain and the skimmer are plumbing together on the same piping leading back to the pump and might include 1 or more valves to adjust water flow through the skimmers or bottom drain. The valves (if present) could also be leaking air. If they can be disassembled, then they should be serviced to lubricate and even replace any o-rings that could be deteriorated.
    Summarized...
    1. Thoroughly inspect your vacuum hose and attached fittings for cracks holes, etc.
    2. Thoroughly inspect your pump for loose suction connection, lid loose or oring dirty or deteriorated.
    3. Thoroughly inspect any suction control valves for leaks.
    President:
  • Emerson Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
It happens because you are introducing a lot of air into the suction line when you attach the vacuum hose. Once the pump draws that air thru and expels it you should go back to normal pump flow in order to vacuum. To help eliminate this problem, place the vacuum under the water and take the end of the hose you will attach to the skimmer and place it over a return outlet. This will fill the hose with water and force most if not all the air out. Attach the hose to the vacuum plate and vacuum away.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Sep 07, 2010
How do i prime this swimming pool pump?
The normal procedure would be to unscrew the top of the inlet basket and fill that with water until it flow out down the inlet pipe, then replace the top cover. Make sure the skimmer box basket is clean, the pool water level is high, or put a fast running hose in the skimmer box to make sure the primed pump does not have to pull the water up from too low at the inlet.
If it will not pull the pool water in when started, then -
- there is a leak or blockage somewhere on the inlet side
- the pump impeller is damaged
- the filter is clogged too much and causing back pressure
- the pump power and pipe sizing are mismatched
Oct 08, 2014 | Pool & Spa
How to vacum my spa with pool maintenance kit
if you have the intex kit , it comes with instuctions but hers it ina nut shell , find adaptor plate that fits inside skimmer (flat thing with hose port in middle) assemble sustion head and handle with hose attached and drop into pool (keep handle out) fill hose full so it sort of sinks (no air gaps) snake carefully end of hose over to skimmer (pump running normal) fit plate into skimmer quickly snake hose thru skimmer hole and fit to plate adaptor on hose port , wait a few minutes if flow continues out pump dishcharge then your good to go if not dissasemble and start over , but let filter pick up prime again 1st , do not lift head out of water even to get big stuff off pickup do it in the pool under water
Jul 23, 2014 | Intex Above Ground Swimming Pool Skimmer...
Pentair 1 1/2 hp pool pump works while skimming but loses prime when vaccum gets plugged in
the pump is doing what it was designed for any difference in suction will make it error out you might have to set it on manual to vacuum
May 11, 2014 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Barracuda automatic pool cleaner
try hose into skimmer hole maybe air leak from plate make sure swivel end of hose on cleaner maybe air leak if sticking out of water
Dec 26, 2011 | Zodiac BARRACUDA G3 IN-GRND CLEANER
How do I vaccum the pool? I dont know if I turn the Veriflow to out and then where do I hook in the hose?..Its my girlfriends pool and she just expects me to know. Thanks
Oh then you DO need help. To vacuum you don't need to change the valve setting on the filter, but if there is a valve on the intake selecting main drain/skimmer you can select skimmer only, but I usually only do this after I have the hose primed. . You attach the hose to the skimmer inlet. Usually there will be a round plate attched to the hose that fits into the skimmer ( you may have to remove the basket) If you don't have that round plate on the hose, then you can insert the hose driectly into the bottom of the skimmer. Before you attach the hose, connect it to the skimmer head on the pole. Submerge the head and hose. Allow to settle to bottom. Put all the hose into the pool. Take the other end and hold over the discharge back into the pool to fill the hose with water (prime) until air bubbles stop coming from vacuum head. Then hold your hand over the hose (to keep from loosing prime) and quickly attach to skimmer. You may hear some air, and the pump may stop pumping fully mommentairly untill it is pumping full water again. Now you can select the valve to divert all the flow from the skimmer
Aug 13, 2010 | Hayward SAND FILTER, PRO SERIES
When i put my hose in to vaccum i lose suction but with out hose it will **** your hand down the pump is workin great
Are you filling the hose with water before you put your hose into the skimmer? Put your vacuum in the pool - put the other end of the hose over a discharge ... when the air bubbles stop coming from the bottom ... , put your hand over the end of the hose and then stick the hose into the skimmer suction.
Jun 04, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
Losing pressure 2-3 min vacuum hose is attached to skimmer
de filters clog very fast i suggest put vac in pool put hose over pool attach a wet vac to get water out of hose remove wet vac and vac saves de and water
Jul 09, 2009 | Hayward 1HP Super Pump II Inground Pool...
I have the 15' X 42'intex metal frame. Pool and
YOU CAN DO THIS 2 WAYS IF YOU WANT TO USE SKIMMER THERE IS A PIECE THAT GOES INSIDE SKIMMER TO ATTACH YOR VAC HOSE TO HEAD O VAC FITS ON END OF POLE TWO PUSH PIN ATTACH HOSE TO VAC HEAD AND INTO SKIMMER IF YOU WOULD LIKE TO BYPASS HOOK VAC SAME WAY BUT DONT USE SKIMMER PUT HOSE OVER POOL AND DRAW WATER JUST ENOUGH TO CREATE A FLOW BY PUTTING THE END OF HOSE OUTSIDE POOL TO A WET VAC JUST LONG ENOUGH TO GET WATER FLOWING DONT KEEP IT CONECCTED LONGER THAN 20 TO 30 SECONDS GOOD LUCK
Jun 27, 2009 | Intex Krystal Clear Model 635 Pool Filter...
The jets quit working when I prime and attach the vaccum hose
you could have a leak in the vac hose or a shaft seal on the pump, if there is a wet spot under your pump there is a good chance the shaft seal is BAD.... some pumps are so strong you can starve the PUMP for water, the trick is to set your valve more towards the main drain./ hope this helps.. i'm your local pool pump motor repair guy
Jun 20, 2009 | AO Smith 2 hp Swimming Pool - Jet / Well...
Pool & Spa Logo
247 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Mike Squire
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
