I have a sony KDF-60x5955 the red standby light is flashing in the front of the television, last time I had this problem I changed the bulb, this time I changed the bulb again and it is not working. Could it be another problem?
What can it be flashing red light in front like it was on stand by
Posted on Feb 19, 2011
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
Kdf-e50a10 green standby light flashes about 20 times.
At that price not a Sony Lamp, do not expect it to last as long as the last lamp did.
Nov 30, 2012 | Televison & Video
The fan dont turn on when i turn on the tv and the red light is flashing
Red light flashing on tv indicates that tv got some problem and shifted to protection mode to avoid further damage.
If Lamp light is flashing on tv then check lamp that would be dead or broke, replace lamp to solve tv problem.
If standby red light is flashing on tv then let me know how many times it is flashing after 3 seconds long pause to provide you helpful info.
Thanks.
Jan 22, 2011 | Sony KDF-E55A20 55 in. LCD Television
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony wega 70 in new bulb lasted 8 hours now
hello.+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Oct 21, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony KDF-E50A10 stays on for 15-20 minutes then shuts off power standby light flashes green and turns back on. Replaced bulb about 6 months ago with sony bulb. Any ideas. Thanks
The reason this happens the most is because of the lamp being weak. I have not seen anything else cause this problem. You can varify this by turning the set off and wait until it shuts down totally.
with the Sony remote, press the display button, the #5 button,
volume down button, then power button. This puts you into the the factory error code mode. If you see the lamp code with multiple errors and no other errors shown, the lamp is the problem.
Most of Sonys lamps have a aprox life of 3000 hrs. Some last longer and some shorter.
I hope this helps,
Skyassoc
Jun 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-50WE655 will not power up. Red blight blinks 4 times
4 blinks shows problem either one or all 4 fans are not working AND internal temperature high error.
If you are familiar with TV repair and know basic electronics then unplug TV from AC outlet an take off back cover and check fans are running?
Jan 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Tv Problem
standby only usualy flashes when child lock is engaged...normaly a hard reset is in order...
Aug 10, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Electro Med Services...
