Question about LG Refrigerators
We have LG referigerator Model no. LFX25960ST that has stopped making ice and not colling properly. Serial No> 606KRWZ07473. We need Service tech, where can we find one. our zip is 70128
    Genius:
  • 1,478 Answers
An ice maker, as you all know is an appliance in your refrigerator's freezer that makes ice cubes. The ice maker receives water through a quarter inch pipe placed behind the refrigerator, which in turn is connected to the water pipe and tap valve. As and when water is needed, the valve lets the water flow through a fill tube into the ice maker assembly and thus, the water gets frozen into ice cubes. A thermostat is attached to the ice maker to monitor the temperature. Once the ice is ready, the ice cubes are pushed by the ejector blades into a bin till it is full. Now that you are aware about the functioning of an ice maker, you need to identify the ice maker problems that might be causing trouble.
With your ice maker not working properly, you might be wondering the reason behind the malfunctioning of your ice maker. Several factors could be involved in case your ice maker is not making any ice at all. It might be caused due to a defect in the water supply line. It could be possible that the water valve isn't getting any water. Check the water line at the back of the freezer for any blockage. Look for the water shut-off valve placed behind the refrigerator or under the sink and turn it off.
Next step would be to unscrew the copper line located at the back of the refrigerator. Now place the copper line in a bucket and turn on the valve to check if pressurized water comes out. The problem could also be linked to a defective tap valve. You could have it replaced. Since, freezer temperature can also be responsible for ice maker malfunctioning, make sure the freezer is not too warm.
Take care.
Posted on Sep 07, 2010
Ice maker stop making ice put in new filter
probably filter backwards? or wrong filter?
why did u put new filter in? cuz it stopped already, and thought new filter should fix problem? u guys kill me
Jan 01, 2015 | LG LFX25960ST Stainless Steel French Door...
I have one year old lg 1.5ton window a/c then start a/c that time is colling ok but after 2 & 3 hours all colling coil block by ice.i asked other persion he told high pressure wall is defective plz...
I would let it thaw out and then clean all coils,blower motor,and fan that you can get to. Next I would check line pressures to see if you have enough refrigerant in system. You may have to install self tapping service valves on lines to test them. If you don't have gauges to check them with you will need to call a service tech. Sorry I am not more helpful. Good luck and thank you.
Jul 10, 2011 | LG Electronic Window Air Conditioner
I need a manual for my LG Ref. Model LFX25960ST. Mine was lost in the Nashville Flood.
Here is a Service Manual=> LFX25960XX and your Owners Manual=> LFX25960_Owners_Manual
and here=> LFX25960ST Parts and last but not least=> LFX25960xx Parts View If you have other questions please ask, Thank You, Sea Breeze
Apr 12, 2011 | LG Refrigerators
Ice maker is not working - sensor bar rolls up but no ice in ice maker - no water in ine trays
Sound like it is the dual water control only. Try filling ice maker with tap water and then let freeze. If after the ice in the ice maker dumps the cubes into the ice container and does not refill I would think the water control valve is at fault. I see your model had three different choices of water control valves and listed on this page=> Here and in right sidebar about 1/3rd down the page you will see three different water control valves. Here is your Service Manual=> LG LFX25960ST Stainless Steel French Door Refrigerator Try this test first because you mentioned no water in trays. Let me know what results you get and if you have more questions feel free to ask, Thanks, Sea Breeze
Feb 15, 2011 | LG LFX25960ST Stainless Steel French Door...
Ice maker stopped working and how to clean the stainless steel?
For this problem you need tech support. There are many things that can cause this and it needs to be diagnosed by an authorized LG tech. In the long run you will save money and get a quality repair.
Jan 24, 2010 | LG LFX25960ST Stainless Steel French Door...
LFX25960ST Ice maker problem
As long as switch on icemaker is on then your i/m died. It needs to be replaced. I can get LG parts if you need one. Please leave feedback. Thanks
Nov 22, 2008 | LG LFX25960ST Stainless Steel French Door...
LG Refrigerator model LFX25950SB
it means that the motor fan inside freezer the sends air to the ice maker is not communicating with mother board you have no ice right then you need either the motor fan or main board if you dont know howto trouble shoot you need a tech to come out
Oct 31, 2008 | LG LFX25960ST Stainless Steel French Door...
Ice maker LFX25960ST
3 months old?? warranteed for a year call for service , you bought new so you wouldnt have to fix it!
Ice maker quit - LG refrigerator model LFX25960ST, ice maker PN 5989JB0001A
I have the same problem.
Ice in the gears.
Splash from opening and closing the door when liquid water is present seems to be the logical problem.
I had cleared the ice before, thoroughly dried the icemaker and reinstalled it. It worked until I adjusted the icemaker to make large cubes.
I will reinstall it and see how long it last. I will also complain to Sear about the short life of this device.
Dec 27, 2007 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
75 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
