Question about Whirlpool 24 in. ADP6940 Dishwasher
My whirlpool 6th sense adp6940 dishwasher won't fill and is displaying F7 on the screen. all the connections have been checked and the filter washed, what do you think the problem is?
SOURCE: Whirlpool dishwasher
We had same problem with our ADP 5966. An engineer over the phone said he thought it was related to machine being unable to drain. I checked the drainage pipe connection to u-bend under sink, and sure enough, there was a major blockage. Cleared that and hey presto, problem solved.
Posted on Oct 13, 2007
Buy a new
Posted on Nov 26, 2007
SOURCE: Whirlpool dishwasher 6th sense, model no ADP7406
how does the wash nosel fit in
Posted on May 30, 2008
SOURCE: Whirlpool ADG 6340 Dishwasher
fault 7 is a fill fault . If you take the left side panel off you will see a white plastic tank . The sensor in the tank has failed
Posted on Jun 23, 2008
SOURCE: Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Posted on Nov 23, 2008
Whirlpool dishwasher F8 E1 error
You have a blockage in the drain line someplace. If you have a garbage disposer, check to see that it is clear where the dishwasher connects to it. Also check and make sure that the drain hose is higher then the inlet to the disposer to prevent water draining back into the drain line from the disposer. If that's clear you have a blockage somewhere in the drainline. Best to unit from cabinet and check it
Apr 05, 2014 | Whirlpool Dishwashers
Long Cycle times on ADP6940/5 6th Sense Dishwasher
It might not be getting enough water.
Try fully taking power off of the dishwasher and turn it on/off a couple times.
If its your board, it will take a while to fix it,first check the main settings on your front display then try locating the board and check for any switches or knobs.
Did you just get this dishwasher ?
If you've tried this things with no luck, respond with more details.
Jan 13, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
HI, WE'VE GOT A WHIRLPOOL 6TH SENSE WASHING
washers are very expensive to fix they cost more to fix then to buy
Aug 09, 2013 | Whirlpool Washing Machines
What does F6 mean?
The dishwasher can't take on water. Check that the water inlet is properly connected, the stop tap valve is open and that water supply is otherwise available to the dishwasher. Also check for kinks or blockages on the water hose.
F6. means "Water valve (WV1) is switched on but flow meter (FM) senses no impulses" (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
Jul 25, 2011 | Whirlpool 24 in. ADP6940 Dishwasher
Fault code F6 on whirlpool adp6940. what is it?
Hello there
F6 error code - The dishwasher can't take on water. Check that the water inlet is properly connected, the stop tap valve is open and that water supply is otherwise available to the dishwasher. Also check for kinks or blockages on the water hose. if all is good than you may have a problem with the solinoid valve for the water or the cycle timer may be faulty and the door switch may be bad or not working properly so
you will want them checked for ohms and resistance if they are found bad they need to be replaced
Jan 05, 2011 | Whirlpool 24 in. ADP6940 Dishwasher
Code f7 appearing on whirlpool dishwasher adp 6940/5
f7 means a water flow meter problem. Either your dishwasher is not getting proper water pressure, or the flow meter is bad. Check to make sure you have good water pressure to the dishwasher, and then check that your water is coming in at a good flow rate. If both of these are ok, then replace the flow meter. If your house water pressure to the dishwasher is good, but your water flow coming into the dishwasher is slow, then your dishwasher water valve is probably plugged. Some valves you can take apart and clean out, and some you will need to replace. Good Luck, Appliance Specialists
Dec 08, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
What does F7 mean on a whirlpool 6th sense washing machine?
F7 in whirlpools means "Clean the filter”.
The following troubleshooting steps would help fix it. Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a program this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filters clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine.
Thank you for contacting www.Fixya.com
Jul 30, 2009 | Whirlpool Washing Machines
Whirlpool dishwasher ADP905
Depress start button till start light goes out. Close door, drain pump should run for a while. Wait for end of program, rer-try a new program start. This process is re-setting memory.If this fails to sort problem then start checking components, ie: fill valve water on? heaters open circuit/down to earth, drain pump, is it emptying, wash pump.
Jul 31, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
Whirlpool 24 in. ADP6940 Dishwasher Logo
113 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
