Question about Toshiba Satellite M100 Notebook
Can not get the power button to shut down the computer no matter how long I hold it down and the computer appears to stay in hibernation. Will not reboot or do anything when power is applied and power switch pushed.
  • 331 Answers
Remove the battery and leave off for about 1 minute. Put the battery back in place and press the power button to turn the unit on. immediately after you see system light come on, press and hold the power button and see if it shuts off after a few seconds. If not, then its likely your motherboard is defective.
Posted on Sep 07, 2010
New computer will not shut down
Try going to your power option in the control panel. Make sure that hibernate is disabled, change what power buttons do. Make sure when you press power button it is set to shut down. Choose when computer sleeps as never.
Oct 07, 2017 | ASUS Computer International Computers &...
My computer still functioning even its shutdown already
have you tried to hold the power button down for 5 seconds? if that doesn't work, it's possible that when you click the shut down the last option used was the hibernate option. when you click the orb click the arrow pointing to the right next to the power indicator and make sure it's set to shut down and not hibernate
Aug 02, 2012 | Lenovo Computers & Internet
I accidentally put my Compaq 6715 b laptop into hibernation. I don't know how I did it or how to bring it out of hibernation.
You need to hit the power button just the once to bring it back out of hibernation mode. It may take around 30 seconds until you hear your computer starting to boot back up and a little longer for the screen to come on.
Failing this, you can try a hard reboot by holding down the power button until you hear your computer re-boot. Usually you need to hold around 10 seconds. However using this last method as a final resort will result in your computer telling you that it did not shut down properly.
Aug 04, 2011 | Computers & Internet
I accidently shut my computer down with hibernation before leaving. When I come home, the computer will not turn on, no lights no noise, nothing. How do I unlock the hibernation? Or could it be something...
Jul 08, 2011 | Gateway 310X PC Desktop
Hiberation mode ,,what do i do/
Hibernate mode is a power saving feature for computers. In hibernate mode, the current state of a computer is saved to the hard disk, and the computer shuts down. A user will have to power on the computer to restore the previous settings. When a computer resumes from hibernate mode, it reads the saved settings from the disk and restores the system state as it was before it entered hibernate mode. By default, hibernate mode is disabled. If a computer is not ACPI-enabled or APM-enabled, users will have to enter hibernate mode manually. Users cannot set the computer to automatically hibernate after a certain time. With ACPI-enabled and APM-enabled computers, users are able to set hibernate mode automatically
How to enable Hibernate:
Please follow this steps below to enable your Hibernate features:
1. Go to Main screen in your windows then right click your mouse to an empty area in your main menu.
2. After clicking the right click please select the properties then go to Screen Saver Tab.
3. Please Click the Button name Power then click the Hibernate Tab.
4. Please check the CheckBox name Enable Hibernation to enabled the hibernation if it is not hibernated.
5. To try test the Hibernate process please follow the steps in How to start using Hibernate below.
How to start Using Hibernate:
Please follow this steps below to active your Hibernate Features:
Make sure all necessary programs are closed prior to shutting down. Hibernating will put all programs to "sleep," but some programs won't start up properly. Experiment after this to figure out which programs perform as intended.
  1. Click Start and Shut Down,
  2. Point the standby button and maintain the shift key pushed,
  3. A new hibernation button appears: click it while still holding the shift key: voila your PC will hibernate.
Thanks
Aug 07, 2009 | Averatec C3500 Tablet PC
How do I get a monitor out of hibernation mode? It is not responding and did not reset when I rebooted.
Try using the power button, which usually takes the computer out of hibernation. Also, the mouse and keyboard can sometimes wake the computer from hibernation as well.
If the computer is still stuck in a hibernated state, hold the power button in for about 5 seconds so the computer fully shuts down and power it back on.
Good Luck!
Aug 06, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Pressed hibernation key and now the computer won't work
Unplug the computer for a minute and plug it back in. It should restart normally.
Usually you restart just by tapping a key in sleep or hitting the power in hibernate.
Jul 30, 2009 | HP Multimedia Cordless Keyboard/Mouse...
After shutdown of gateway laptop blue power button stays lit.....
Hi this sounds like your computer is in hibernation mode as opposed to shut down mode. Could you check and see as if running Vista many people assume that clicking on the brown power type selection under start that they are shutting down where as this actually only hibernation mode and clicking on the little arrow to the right of this and selecting shutdown is the way to go.
I hope this helps
Apr 07, 2009 | Gateway MX6441 Notebook
How do i get out of hibernate mode and get into standby
To get the computer back up again and out of hibernation you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Also the following may be of interest.
You must be logged on as an administrator or member of either the Administrators or Power Users group in order to successfully complete this procedure. If your computer is connected to a network, the forced network policy settings may prevent you from completing this procedure. In this case please consult your Network Administrator.
  1. Click Start, then Control Panel, and then double-click Power Options.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box.
    If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start, and then click Shut Down then select Hibernate.
    If you are using Windows XP Home Edition, or Windows XP Professional with Fast User Switching turned on, the Shut Down menu will present the options to Stand By, Turn Off, or Restart your computer. Hold down the Shift key, and the Stand By button will change to Hibernate.
Dec 23, 2008 | LaCie Electron III 22" CRT Monitor
Computers & Internet Logo
117 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
