My Philips modle number 23PFL5522D/05 Will not turn on and keeps switching onto standby and off then onto standby again repetedly.
4 Suggested Answers
  • 60 Answers
SOURCE: HI, I have a Philips tv
Change C82 (1500uF/16V), C83 (1500uF/16V) and C84 (680uF/16V) on the external power supply.
Let me know what happens after that.
Posted on Apr 07, 2011
SuperTech-11
  • 1591 Answers
SOURCE: I have a philips flat
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Jun 18, 2011
ekcnoel
  • 998 Answers
SOURCE: I have Phillips TV Model
The problem of your tv is that the main power supply board is already faulty. this problem is caused by a leaky capacitor or bulged up in the top of the capacitors or not perfectly flat. So then your dc voltage is not sufficient to supply the other parts. when trying to replace the capacitor you should unplug your unit then wait for a minute to be sure that the electric charge to the capacitor will be discharge. and remember the proper position of the capacitor it has a polarity.
Posted on Jul 06, 2011
Elonex tv keeps going on standby, take 10-15 times for it to work
It sounds that there is some short circuit with its SCL-SDA rail, at its main digital circuit board. It will be best to contact any service technician, as troubleshooting the main board is a skilled work.
Nov 25, 2013 | Televison & Video
Elonex tv keeps going onto standby, take about 10-15 goes to work.
Sounds like you may have some capacitors going bad. If it is a high end TV it may pay you to take it to a repair shop.
Nov 25, 2013 | Computers & Internet
42pfl5522d/05 tv screen is blue and cant tune or watch anything?
With the TV on pull out it's AC plug and leave it for a few minutes (10 minimum)
Then switch off the manual switch you left on, on the TV set.
Plug in again and turn on the TV by the manual button (this should be standby mode) then turn fully on as usual by the remote control.
It may need complete or part setting up again per the instructions but you'll hopefully find that all will soon be well.
Sep 21, 2011 | Philips Televison & Video
HI, I have a Philips tv model no: 23PFL5522D/05 and the red light has started to flash one long and two short what has gone wrong with it please?.
Apr 07, 2011 | Televison & Video
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
Television problem
Hi there!
I would start with power supply caps and regulators. However it could really be anywhere on the circuit, Philips TVs are error sensitive so I would recommend a repair technician. Good Luck, Jus004
Feb 20, 2008 | Philips 32PT6441/37 32" TV
DVD recording.
Sounds like the DVDR is recording from the digi-box through the TV, so when the TV is switched of or into standby the signal is lost, causing the recorder to pause.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
Feb 05, 2008 | Philips DVDR3380/05 DVD Recorder
Philips wide screen TV
OK sorted the problem on my set. Replaced the capacitor ref: 2455 on main board it is a 47uf 25v but i was told a 35v will work as well? But mine is a 28pw6506/05
Nov 08, 2007 | Philips 28PW6506 28" TV
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Aug 24, 2006 | Philips TV Tuner Video Capture PCI Card -...
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
Electro Med Services...
