Question about GT Bicycles Gt I Drive Eccentric Bearings 216h
My 2009 gt i drive xcr5 has a loud creaking noise when pressing down hard on the pedals i dont think this is my bottom bracket could it be the pivet point. If this is the problem how do i sort it and what tools do i need to do the job.
  • 186 Answers
YOUR BOTTOM BRACKET NEEDS MORE TIGHTENING EVEN IF IY LOOKS LIKE IT DOESNT.1/8 TURN CAN MAKE ALL THE DIFFERENCE.CONSIDERED BOTTOM BRACKET BEARINGS?
Posted on Sep 14, 2010
Just bought a ford ba wagon and when you do a hard turn like driving in your driveway or turning in a street it makes a loud creaking noise coming for the front
check the strut or top strut bearing for failure
the creaking noise can be from the spring being wound up from turning as the bearing has seized
have it inspected by a specialist suspension shop
Nov 16, 2015 | Ford Cars & Trucks
Noise and rough pedaling from main crank
not knowing if this is a single speed or multispeed bike, this could be several different things and a proper analysis by a mechanic at your local bike shop is what is needed.
It could be that the chain is too tight, it could be the derailleurs are out of adjustment and the chain is skipping between gears or rubbing on the derailleurs. It could be a bottom bracket out of adjustment and the bearings are loose and making the noise. It could be a loose bottom bracket shell in an aluminum frame make creaking noises.
Aug 14, 2014 | Cycling
When pressing gas pedal car makes a loud rating noise
use 2 persons to find location.
like real estate. Location-location-location...
same deal, nothing else matters. guessing is total waste of man power and cash.
the first test is to get it to make noise, parked. with brakes hard set
and in drive (A/T or m/t you never said) or in any GEAR.
that be first. if you can , then its 100 x easier to find,.
http://www.fixkick.com/NOISE.html
Feb 11, 2014 | 2009 Honda Accord
Creaking sound when applied lots of torque
This is probably due to a loose pedal crank arm. The cranks are attached to an axle (bottom bracket spindle) by means of a tapered fit and a nut or bolt. Just Google "How to tighten crank arm"
Good luck.
Oct 16, 2012 | GT Force Carbon Pro
When pedaling starts off making squeaking sound but now it is very loud with cracking and popping.
Pedal or bottom bracket bearings need a look. The web has many resources for identifying noises on a bike. Just search for a few key words. For example "bicycle pedal loud cracking and popping"
One resource...
http://www.parktool.com/blog/repair-help/trouble-shooting-a-creaky-or-noisy-drive-train
Happy hunting.
Aug 18, 2011 | Cycling
I have a jamis cross country 2.0 bike. the bottom bracket creaks. not sure why.
One or both of your crank arms are probably loose. Try pulling and pushing (pretty hard) on the pedal end of the crank arm (toward the bike and away from the bike) If it's loose, it will be apparent. The arbor of the bottom bracket is usually square on the ends, and this is tapered (the square is bigger closest to the bike) You just need the right size wrench to tighten the nut that holds the crank arm onto the bottom bracket arbor.
Oct 01, 2010 | Cycling
Fitted tiagra triple to cannondale caad9 frame. bottom bracket creaking
There are many possible causes for the noise you're hearing, but the most common source of creaks is loose crank arms.
You might be able to eliminate the sound by tightening the crank arms on the bottom bracket spindle. However, I would recommend removing both crank arms from the spindle and reinstalling them after lubricating the surfaces where the spindle and crank arm meet as well as the crank arm bolts. Use a high quality grease (not oil, such as Triflow) or anti-seize compound.
Torque the crank arm bolts to the factory spec. Crank arms bolts can take a lot of torque -- about 300 ft/lbs. Most people don't have a torque wrench, so you can "guesstimate" this by applying about 50 lbs of force on the end of a 6" long wrench.
Other possibilities are loose chainrings (check each bolt where they are attached to the crank), pedals (lubricate/service bearings), bottom bracket (check it is properly torqued), chain (look for tight links), derailleur idler gear, crack in frame.
Sep 16, 2009 | Shimano Cycling
"Creaking noise from front right side of jeep"every time hit bump
If it is new take it back to the dealler for warranty repair. No new vehicle should have any noises . seriously, take it back for repair.
Jul 23, 2009 | 2008 Jeep Wrangler
Creaking noise when I step on the brake (Honda Element)
have the brakes looked at at your nearesr honda dealer or reputable repair shop. sounds like ur brake pad sensor is contacting ur rotor...
Apr 04, 2009 | 2008 Honda Element
GT Bicycles Gt I Drive Eccentric Bearings 216h Logo
326 people viewed this question
Top GT Bicycles Cycling Experts
Michial Gueffroy
Ed Hauk
Ed Hauk
Level 1 Expert
Donald Ayers-Marsh
Are you a GT Bicycles Cycling Expert? Answer questions, earn points and help others
