Question about Nokia 6126 Cellular Phone
Phone resets when i send pictures
Every time I go to send a picture the phone restets and goes back to what it is like when i first turn it on. This happens when I go to the image and hit send and also when i go to new multimedia message and try to add a picture. This happens on both when a picture is on the memory card, or when I move it to the phones memory.
  • byork Jul 18, 2008
    resetting fixed mine thanx
Hey! I solved it. This seemed to be a common problem for Nokia 6126 phones. I had to go to settings and reset the device with the default security code of 12345 and It work, but it went back to factory settings which is kind of annoying. I didnt lose any files or contacts or anything though.
Posted on May 15, 2008
Resetting works! =)
Posted on Jun 27, 2008
I have a network busy message on a RAZR V3 when trying to make a call. I can send text messages and the sim works fine in another phone. When I call the phone it goes straight to voicemail.
Turn off your phone then take the battery and sim car out for ten seconds replace then reboot your phone. This performs a soft reset. If it still doesn't work back as much stuff up as possible (contacts, pictures, apps, ect.) and perform a hard reset.
Good Luck!
Dec 14, 2012 | Motorola Mobility RAZR V3
Tip
Tips for camera
Using the camera:
Your phone has a flash to help you to take pictures in different lighting environments. The flash is on by default, but you can turn it off or use the automatic setting. To set the desired mode when using the camera, select Options > Flash and Flash off, Flash on or Automatic.
Fast viewing with memory card To view your images and video clips quicker, use your memory card as the main memory for storing them.
In the camera application, select Options > Settings > Image / video storage > Memory card.
Capture and send You can send the picture immediately after you have taken it when you are previewing it. To display a picture immediately after you take it, select Options > Settings > Image preview time and the preview time. During the preview time, select Back to take another picture, or Send to send the picture as a multimedia message.
Print your images Your phone supports Nokia XpressPrint to print images that are in .jpg format. To print your pictures, connect your phone to a compatible printer using a data cable or send the image by Bluetooth to a printer supporting Bluetooth technology. Select the image you want to print from the Gallery, and when viewing the picture, select Options > Print.
on Jun 13, 2010 | Nokia 6500 Slide Cellular Phone
For my camara the lens won't go back in and it tells me to reset the camara but I'm not sure how to reset the camara
Most digital devices can be restet by removing the battery and then powering it back on; but read the manual as that may cause you to lose your pictures depending on the device you have.
Jan 04, 2011 | Canon PowerShot A530 Digital Camera
LG Dare turning off almost constantly
try typing 2945#*# and a menu appears,from that menu select reset phone.reset it may be your problem is solved.
May 30, 2009 | LG Dare VX9700 Cell Phone
Phone wont send or receive picture messages
call ATT, mine did this same problem, and it for some reason got kicked off in the ATT system that i didnt have the correct messaging plan anymore. it sounds odd, but it fixed mine. good luck!
you may try a master reset after backing up to your PC if that doesnt work.
Hope this helps! pls dont forget to rate the solution!
Mar 02, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Picture messages
Go to Menu>Settings>Restore factory settings
Jun 22, 2008 | Nokia 6133 Cellular Phone
TEXTING PICTURES
Check with your provider to make sure you have picture messaging enabled in your account, then turn phone OFF and back ON, send one of those pictures to yourself, meaning select picture messaging and send a picture message to your own cellphone number, if you phone receives that picture back, that means you are ready to send all the pictures you want out f your phone.
Will be much easier to send then to your email address.
Also check with your carrier to see if they have an ONLINE ALBUM option, if so you can upload pictures to that ONLINE ALBUM and access them thru the internet on a computer.
If you are lucky enougth to have BLUETOOTH on your phone and your carrier allows it, you could go to WALMART and find one of the BLUETOOTH Enable printing stations and send those pictures thru bluetooth and print them
Let me know if you need help
Thanks
Apr 17, 2008 | LG CU400 Cellular Phone
I need help!
your main-board needs to be reflash or replaced
Mar 14, 2008 | Nokia 6133 Cellular Phone
Restarts/Multimedia Files
have your phone reprogramed maybe it has software problem. or worst hardware related problem.
Oct 14, 2007 | Samsung SGH-X830 Cellular Phone
Nokia 6126 Cellular Phone Logo
105 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
