Question about Briggs & Stratton Prosumer 20324 Gas Pressure Washer
I have a Briggs & Stratton Pro 3400 pressure washer that I got new last year and used for maybe 5 hours and it worked great. Have had it stored since then with stabilizer in the gas (I didn't run it dry) and now it won't run for more than a minute or two without dying. A dealer said it was probably bad gas and I now know that even with the stabilizer I should have run it dry last year before storing. Everything is like brand-new including plug and air filter so it must be the gas/carberator gunk from the gas. What do I need to do to clean it out so it will start an run again?
Tnsiouxfalls
  • 617 Answers
SOURCE: Briggs and Stratton pressure washer fuel leak
You've hit the nail on the head.The float,needle and seat are stuck wide open.Once the carburetor bowl is full of fuel the float rises up on top which pushes the needle back into the seat shutting of the flow of fuel.As the engine consumes that fuel the float drops and opens the needle and seat filling the bowl and shutting off the fuel again.Things that cause this process to not work are:forgetting to empty or run out the fuel before storing it for the winter.Sediment buildup in the bowl.Mineral deposits in the needle and seat.
Not emptying out the carb can leave water in the bowl which freezes,crushing the float.It also promotes sediment buildup and mineral deposits.The float when crushed or cracked will not float,nor shut off fuel.Sediment takes away capacity of fuel in the bowl,very necessary for wide open throttle.Mineral deposits build up to the point that the needle and seat can't make a good seal so fuel will continue into the carburetor.
Enough information yet?
To repair,take the nut off the bottom of the carburetor bowl.There are the float and needle and seat assemblies.All three need to be replaced,$10 max.After you get the parts replace one piece at a time so you can see how they go together.Next replace the spark plug, engine oil and air cleaner.They are fuel fouled and even if you could get the engine started will only add more damage to your engine.BEFORE you put the new plug in cycle the engine by pulling the starting cord a few times to get rid of the excess fuel.When there's now more fuel in the cylinder replace the plug,filter and oil.
That's it!Take your time and you can do it just fine.Re-post if you have any more troubles.
Posted on Jan 13, 2010
  • 15 Answers
SOURCE: craftsman pressure washer constantly fluctuates and then stops
sounds like fuel problem. Either water\trash at bottom of tank, or most likely, carb needs to be disassembled and bowl and jets sprayed out w\carb cleaner.my money is on the latter.
Posted on Feb 10, 2010
SOURCE: 18hp twin cylinder Briggs & Stratton backfire
Check to see if the carb is clean, if so the anti diesel value could not be working. Apply 12 volts to value and see if it move's. If that works then you may what to check the fuel pump and see if it pumps. After you tried all that then you may have change the main jet size because these engines come with a small jet for the EPA.
Posted on Apr 23, 2010
SOURCE: I have a Briggs & Stratton pressure washer,
If #1 doesn't work, the ports in your carb could be clogged. I just dealt with this problem this weekend. This is a relatively easy fix. Locate your carburetor and find the aluminum bowl underneath. On the bottom of the bowl, you'll find a bolt. Loosen the bolt (gasoline will come out because the bowl is a reservoir for gas, but please make sure you've turned the gas supply off) and remove the bolt and the bowl. Clean any debris out of the bowl. The ports are holes in the bolt you removed. Make sure that air can pass through these holes (I blow through them, but I don't mind the taste of gas too much. Probably NOT healthy. You can use thin wire, carb cleaner, etc..) Reassemble and your motor may start, if this was the problem. Make sure that the bowl seats properly and that you are careful screwing in the bolt, lest you cross-thread it. Hope that helps.
Posted on Apr 29, 2010
Biggdex35
  • 333 Answers
SOURCE: Engine wont stay running
It is a diaphram carb. Doe's the primer **** straight gas or does it have air bubbles in it? If it has bubbles in it then it is a leak in the fuel line.
If not then Unhook the intake fuel line and pump the bulb until all of the gas is out of it. Then pour the gas out of the tank and rinse it out with new gas. Pour in new gas and it should be ok.
Posted on May 24, 2010
Why is oil leaking from air cleaner?
this is usually due to an oil overfill situation. You most likely added the full quart of oil into the crankcase on setting it up without checking the actual oil level periodically as you fill it. Recheck and drain out the excess as needed.
Jul 14, 2014 | Briggs & Stratton 020324 3700 PSI Pro...
I have a Craftsman (B & S) pressure washer 7 HP 2900 psi 2.3 GPM Model No. 580.752410. It's about 4 yrs old and 2 years ago I put a seal kit 193807GS into it after it failed to put out proper pressure....
I worked at a tool rental store while attending college and discovered how to extend the life of tools. Really a simple trick that you practice every day. Although your car can travel at a very high rate of speed, you only use about 30 to 40 percent of its power, if however you traveled at 100 mph everywhere that you needed to go, you would greatly shorten its life. Althouth I do believe that you have received good service from your unit, you may have increased the life by using only 60 to 80 percent of its pressure potential for most general work and increase only for stubborn debris.
Apr 26, 2011 | Briggs & Stratton Garden
My Powercraft 9686 pressure washer has always been stored in my garden shed. It is 4 years old and when I used it last September the power washer had lost considerable pressure, as it was leaking water....
put some silicon spray in inlet/outlet then reattach hoses then run it will proform after a while do this everytime you store it pryer to sroring away...........
Jan 17, 2011 | Craftsman 2700 PSI Briggs Stratton...
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
Oil
Remember when your searching for something you can't find the internet is always your best bet. You should also use a good search engine; www.bing.com is one of the best search engines I have ever used. I searched some stores that have the oil your looking for, one online store is www.amazon.com and if you have one near you and they also carry it at Sears. The grade of the oil is definitely weird, 75W90. Also if you would like to look for other stores that carry it go to Bing and type "Briggs & Stratton Pressure Washer Oil" into the search bar.
May 23, 2010 | Briggs & Stratton Briggs Stratton 2000...
Can get no water flowing to the spray nozzle
Most likly the sliding nozzle valve is not fully down or up. I have found after the nozzle lay about for some time they get stuck from water scale. It took two persons pulling and pushing on the valve to get my to operate again. It worked for me.
Jun 11, 2009 | Briggs & Stratton Adjustable Spray Nozzle...
Briggs & Stratton 2500 Power Washer Loses Pressure Time to Time
If by "a few minutes" you mean 180 seconds, I really don't know what to say. But if you mean 5-10 seconds, you probably are experiencing air in the water line or normal engine warm-up behavior when the choke has been set to full lean too soon.
May 23, 2009 | Briggs & Stratton 020324 3700 PSI Pro...
Briggs & Stratton Prosumer 20324 Gas Pressure Washer Logo
186 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
