Question about Jenn-Air Microwave Ovens
I have a 13 year old JennAir microwave. It works fine except the caurosel won't turn. My repairman says the part needed is no longer available. Is he right?
  • 1 more comment
  • mohlf1 Sep 07, 2010
    JMC8100ADB
    Tag inside says Maytag, altho outside it's JennAir.
    Sears has the Motor (58001073) and the Motor Screw (58001048) but says the Motor Gear (58001192) is not available. Could that be the problem?
  • BMik
    BMik Feb 27, 2014
    Do you still have this microwave? We are looking for the control panel, but they aren't available any more. Would love to buy your old unit for parts. contact me at farmertan@hotmail.com Thanks 2/26/2014
  • Jenn-Air Master
  • 19,396 Answers
Hi.
Parts for older models are often out of stock.
Please try giving us the full model number, as printed on service tag. I will see if I can locate the parts for this oven.
Posted on Sep 07, 2010
My microwave turns on, turntable turns, just won't heat. the microwave is 6 years old. Is it wiser to bring in a repairman or just replace? there is a picture of the microwave by the timer window.
There are 2 fuses inside the cabinet. One is for the clock and turntable. The other is for the high voltage transformer and the microwave module. If this fuse is blown either the transformer is shorted or the module has failed to cause the fuse to blow. Parts and Labor can get close to the cost of a new one, so get an estimate so you can have information to make your decision
Nov 09, 2017 | Maytag MMV4205 Microwave Oven
Ge spacemaker microwave JVM1650 won't heat
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
Oct 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
My JennAir went completely dead. It is probably 13 years old. Should I replace or have someone try to fix it?
Hello -
I cannot give you instruction on how to remove the kit(?) surrounding your microwave.
I can provide you with information which may help you decide if arranging for an repair technician authorized to service your JennAir microwave is the best option compared to replacing it. I refer you to the information from Angie's List:
https://www.angieslist.com/articles/microwave-repair-and-what-it-costs.htm
Best wishes.
Jan 15, 2018 | Jenn-Air JMC8100 Microwave Oven
Microwave stopped heating
I had the same oven for one and a half years and had the same problem. Had the sears repairman come out and he said the magnetron burned out and needed replacing for $285. It was never under warranty with the warranty that came with oven. I couldn't believe it! We had an independent repairman look at it and he found a design flaw that causes the magnetron to blow. If you replace the matnetron (megnatron?) it will work for awhile, maybe, but then just need to be replaced again. It's cheaper to buy a new microwave. In fact, I got out our old microwave that's over 20 yrs. old and still works--just isn't as fast and as new ovens. Good luck!
Jul 22, 2009 | Kenmore Microwave Ovens
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Need glass plate for 24 year old Goldstar microwave model ER4010
The original part number was 2B70335A then it was 30QBP004, but these are no longer available.
Jan 14, 2009 | Microwave Ovens
Need to replace JMC7000 Microwave
Yours will likely have a bad high voltage diode, transformer or magnetron, all of which are covered under the extended parts warranty for five years from the date of purchase!
All you have to pay is labor, unless it's less than the two-year full warranty, then there's no charge.
That's a really great warranty!
It's on the back page of the owner's manual.
If you opt for replacement, Jenn-Air Customer Care can tell you which model would be a "drop-in" replacement.
Jan 06, 2009 | Jenn-Air JMC7000 Microwave Oven
Microwave does not heat/cook
hi
power spikes are very damaging to a microwaves internal parts, it sounds like your transformer and/or magnetron are blown. if the unit is out of warranty I would recommend calling a repairman or getting a new microwave (the transformer & magnetron are expensive and dangerous to work on) also get a small single plug surge protector for the new one.
Mar 21, 2008 | Microwave Ovens
JennAir Microwave worked one minute then won't the next.
If this microwave is more than a couple of years old, it's possible that the magnetron tube or a rectifier has burned out. You'll probably need to take it to an experience microwave service technician to get a diagnosis.
Jan 16, 2008 | Microwave Ovens
Microwave Ovens Logo
142 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
