Question about U-Line Icemaker
Model will not stay on cuts off- shake machine, comes back on
    Sergeant:
    Novelist:
  • 193 Answers
Do you mean when you shake it, it starts up again? It is hard to say for sure, but it sounds like a main power wire is loose somewhere. Unplug the machine, take the lower cover plate off and check all the connections. There really isn't a part that works better when it gets shaken. Here is another possibility. If yoy mean that the machine shakes itself and then comes back on, it is probably a bad compressor. When a compressor goes bad, it has an automatic shut off switch to keep it from burning the wires out. If it shuts off it means the compressor is really hot because it is locked up. When it tries to restart, the compressor will shake sometimes when it kicks out again. If this is the case, its time for another ice machine. The cost to replace the compressor is almost what a new machine will cost.
Posted on Sep 07, 2010
LG Flat Screen Problem
may i kmow the exact model please...?
Aug 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Bread sticks to the bread pan, Can't get it out of the pan when finished. Can I buy a new pan?
Unless the non-stick surface is worn off your bread should not be sticking. When it's done do you turn the pan upside and shake vigoroursly up and down and side to side over the countertop? It should start to slide out. I have owned over a dozen different machines and I have never had the bread stick in any of them. It is best to try to remove the bread right after it has baked and use hot pads or hot pad gloves are best. If it is really stubborn try turning the little "T" on the bottom back and forth. Eventually your bread should come out if you stay with it. Shake!, shake! shake!
Oct 29, 2010 | Toastmaster 1142 Bread Maker
When I shake it it goes off
The switch is bad, contact Maglite at www.maglite.com and they will repair it under Warranty.
Apr 20, 2010 | MagLite 3 Cell D Blue Flashlight S3D116
My acer moniter comes on but wount stay on it cut back off
Shut down computer and monitor. Unplug the monitor from the computer. Plug it in again making sure it is connected firmly and that the connection in the back of the computer (video card) is not loose or shaking.
If the symptoms persist and the card appears loose (can happen on older computers) you might need to open the computer case, unscrew and remove the video card and then reinsert it making sure it is firm and attched.
Dec 23, 2009 | Acer AC713 17" CRT Monitor
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Dryer model NO.LGC8858EQO
what did you shake? the machine or the cord?? vaca what band is cut??explain please
Oct 23, 2007 | GE DBSR453EBWW Electric Dryer
F11 code washer locks up
We've had this problem for about a yr when i finally firgured out how to correct it. the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get. How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
Aug 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
U-Line Icemaker Logo
69 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
