Question about Char-Broil Professional Series Grill
No flames coming through the burners? - Char-Broil Professional Series Grill
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
Many newer grills have a safety feature built in where the valve will not
allow gas to flow if the burner valve is in ON position when the valve on
the tank is opened.
Try this - Shut of all valves, disconnect and then re-connect hose to tank,
turn on valve above LP tank, THEN turn on burner valve, light w/ spark or
match...
This feature can be really frustrating if you don't know it is in
operation...
Posted on Sep 09, 2010
Orifices burner flame adjusted
Most burners have an adjustment under the knob. Pull off the knob and use a slender flathead screwdriver. Turn burner down to low, insert screwdriver into knob shaft and rotate internal screw until flame is at "simmer" height. Can adjust each burner separately this way.
Jan 17, 2014 | Kenmore 71042 / 71044 Gas Kitchen Range
How to adjust side burner on weber grills
Burner could be blocked try cleaning the burner then you should be able to adjust air mix Lpg will a bit of yellow in the flame.
Jun 14, 2013 | Grilling
How to fix a pressure switch on a goodman Gms807034ana
Since the burners light this eliminates the pressure switch as the problem. Typically when the burners come on and shut off quickly a flame sensor, ground problem or the limit switch tripping are the main reasons. Since the flame sensor has been replaced, check the limit switch
Jan 04, 2013 | Goodman GMS80453ANA Open Flame Mid-Size...
Frontier BBQ flame at insertion of gas to burner and not going along the small holes
Air mix could be wrong , burner not lined up with injectors burner out of postion
Sep 15, 2012 | Grilling
Only left side of burners working
If you have the Cal Flame burners that are straight, cast brass burners, there is a slot under neath the burners on the back end of the burners. This slot allows the flame to move from the left side of the burners to the right side of the burners. This slot in the burner will corrode shut and not allow the flame to move from the left to the right side. Sometimes you can scrape out the corrosion, and sometimes you can not. If you can't get the slot open, then you have to replace the burners. Cal Flame burners also have a reputation for warping.
Mar 04, 2012 | Cal Flame 4-Burner Drop-In Grill
Burner lights. Flame pulls away from burner and sensor. Unit shuts off
The first thing I would do is check burners to make sure they are clean. Often if rust particles or carbonsoot come loose from inside of the heat exchanger they can partially clog burner opening which causes increase in gas pressure to fewer ports.This can make the flame roll out of burner compartment shutting off flame rollout switch.With burners off turn thermostat down so that furnace won't come on and inspect burners. If they are dirty you can use shop vac with crevice tool to clean most of them. If needed the burners can be removed for cleaning. Usually all you have to do is raise up on the back end of burner and slide it backwards to clear air shutter and burner orifices and then remove. Clean one at a time and put them back in the same position they were in.When they are all back in furnace reset flame rollout and check furnace.
If burners are not dirty then I would have service tech. check gas pressure and repair as needed. Hope this helps you. Thanks
Dec 14, 2010 | Honeywell Heating & Cooling
The burner comes on but goes out after 2 seconds
Your flame sensor may need cleaning. It is a sensor located in the flame of a burner far right or far left in the burner box. Use a tooth brush or scotch brite pad. Do not attempt to clean the igniter as it will break.
Dec 29, 2009 | Goodman GMS80453ANA Open Flame Mid-Size...
Gas Grill Burners with yellow flames coming from beneath them
the flames should be blue and the burners clean. check gas pressure and the air mixture dampers. touch air will give you the same effect. if the burners are clean, it is the mixture. as far as the slots in the bottom. i have not seen that. but i work on commercial ranges.
Feb 27, 2017 | Char-Broil Commercial Stainless Steel...
Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
Apr 23, 2009 | Magic Chef 31000 Gas Kitchen Range
Gas Burners Not Lit Completely
sounds like there isnt the right amount of gas coming out of the orifice. orifice could be partially plugged
Oct 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Char-Broil Professional Series Grill Logo
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
