Question about Cell Phones
The colors in the screen get mixed and messy sometimes and everything is not so clear and visible and when i have call or if im in hot place my screen become totally white and i cant see anything...when i put in the ref it get better and visible again
    Guru:
  • 277 Answers
Change the screen as it has gone faulty
Posted on Sep 07, 2010
My Sony 32" TV with CCFL Back-light module started having green tint. On black colored images, green pixels are clearly visible.
according to your observation we called abnormal picture & common mode choke coils are defective l3000,whech are near to LVDS connecter there are 3 coils & must change all coils after replacing these coils your set will ok
Jul 10, 2015 | Sony KLV-32S550A 32 inch Multi-System LCD...
How do i prevent colour bleed from fabrics?
You can't. Best option is not to mix colors with white when doing hot wash. Generally colors on own go well with cold wash with the right detergent. When you get new colored clothes like pyjamas rinse separately overnight to get non fast colors out and then put in the general laundry. But always keep whites on separate wash.
Sep 01, 2014 | Washing Machines
Vertical streaks but only on first 2-3 pages
replace the image units associated with the color of the streaks
Apr 17, 2017 | Konica Minolta Magicolor 4690MF...
LG 50 Plazma screen is dark pink sometimes goes to normal
Might be to some loose interconnection cables. Seek tech support.
Jun 09, 2012 | LG 50PS60 50 in. Plasma HDTV
How do you internally adjust the hot water setting of a Symmons pressure balancing mixing valve?
  • To set the shower valve handle limit stop, remove the screw holding on to the handle and remove the handle.
  • Remove the round dome cover by turning in a counter-clockwise direction. At this point you will see a small slotted screw head that is visible in the valve cap.
  • Place the handle back on the valve stem (loosely) and open the valve turning the handle until the maximum desired position is reached. This may require turning the limit stop screw (T-34) counter-clockwise (see CAUTION above). To most accurately and safely verify the temperature of the hot water, place a thermometer in a tumbler of water filled from tub outlet.
  • Shut off valve and re-attach dome and handle.
  • Mar 02, 2011 | NRS Symmons Temptrol pressure balancing...
    I have a 1998 Saturn. The reservoir often leaks water/antifreeze and light comes on to indicate. I have had water pump as well as reservoir replaced. Doesn't leak everday but still leaks. WHat is this?...
    you need to find that leak, is the leak visible? if its not from radiator or the reservoir, the only other place I could think you can lose water is the head gasket. It happens to high miles and hard driver. 100k miles would likely be a head gasket. Leaking head gasket will also cause the engine temperature to rise and run super hot. antifreeze will leak through the head gasket down to your oil pan mixing oil and water. Check your oil by pulling the dip stick and see if you have oil mix with water; it will have a slimy looking colors, oil is light color and it should never be black. if it black than change your oil and inspect it afterward when the car has been running for while. when engine really hot cause the heat to effect the starter not to engage or start or engine is too hot to run. repairing head gasket could run anywere from 500-800 bucks.
    Nov 24, 2010 | 1998 Saturn SL
    I have a Hitachi 50v710 it has a yellow tint in the middle of the screen can this be fixed thanks
    This tv is an LCD projection one. in it the image is generated this way: a bulb makes the light; this light is divided then passed thru 3 small LCD screens; the 3 pure color images are mixed together by a prism then passes thru a set of fine plastic lenses (this is called the optical engine) ; from there the final image is projected on a screen.
    The entire image quality is determined by the quality of the optical engine - if something goes wrong with it it's clearly visible on the screen. In your case the heat of the bulb has deformed the first lens, and that has caused optical aberration - color shifting.
    This is fixable, the optical engine will have to be replaced - you can't replace just a single lens, it's a sealed unit. Unfortunately it's not a practical solution: a new optical engine will cost you over $800.
    Use the tv as is until you can save enough for a new one.
    Nov 23, 2010 | Televison & Video
    The page is all messy and not clear (gray color).
    It is the toner cartridge!Replace it and it should be sorted!Enjoy!
    Feb 09, 2010 | Canon FAXPHONE L80 Laser
    Cell Phones Logo
    43 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
