Question about ZT Group CISNET A7022 PC Desktop
Desk top just turn off, will boot up or power will go on just for a few secounds and turn right off again
  • 166 Answers
You are having an improper hardware installation or having hardware malfunction. It may be because of the following reasons:
  1. You changed the hardware settings of some device that results in malfunction of device.
  2. Your RAM will be having some problems. Try unplugging your RAM from RAM slot and remove dust by rubbing with an eraser(only from pins at the bottom of RAM.Do not rub the IC chips and circuits)
  3. You have installed a new hardware device on previous system use that have correpted the system boot settings. Remove the newly installed hardware and try restarting.
If you have checked the above problems and the computer didn't return to normal state then contact for nearest technical support.
Posted on Sep 07, 2010
How do I get my HP computer to boot into windows when I turn it on
mine can boot to 7 things, not just the first hard disk.
usb mem, sd, hdd0,1,CD, and more..
no computer stated by you of th 10,000 models. 1984 to now.
what windows, 14 versions exist.
XP? what?
when you turn the PC the booting is a serial process. (ends at windows login screen)
first it runs BIOS< ROM,
the BIOS ROM, runs POST, (self tests and Plug and PLay)
then BIOS jumps to the first thing in the list (boot order)
and boots to the HDD #0 (default ) F9 key I can change that.' on the fly...
so first is what:?
  1. if a laptop get that bad main battery out first, now
  2. use AC power pack only, NOW. lap or desk top.
  3. does the PCs fan run? (my desk top has 4) if not, power is bad.
  4. does the CD eject? (button) if not power is bad.
  5. does the screen ever show text? like Hit ESC to enter SETUP?> as it did every day since new?
  6. if yes, good, no bad. (bad CCFL lamps>)?
  7. yes, then see if ESC works, F10 , F1 info page work in BIOS.
  8. yes, good, see , now you can boot to 7 things if want.
  9. but if the HDD is bad, you cant boot to that. if its bad.
  10. we run HDD test no as shown on the HP page on topic.
  11. then we try (2006 and newer) the F11 magic recover method.
if the PC is older than 2010, it can in fact have bad CCFL lamps
even PC that are desk tops , the eternal monitor same.
the flash light test. pre 2010 PCs
http://www.pcdied.com/monitors.html#flashlighttest
Sep 29, 2017 | HP Computers & Internet
When I boot up my desk top with monitor E197 FP LCD stays black takes a few times to go
This is a common problem with the E197 units. The problem is caused by a failure of the filter capacitors on the power supply board, they are not holding a charge like they should and it takes several power cycles to get them charged up so the monitor turns on. The E197 uses the same power supply that the E177 uses. Here is a link to a repair guide for the E177 with video disassembly and repair instructions that will help you get your monitor going again.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-e177fpf-lcd-monitor-with-power-issues/
Dec 31, 2012 | Dell E197FP LCD Monitor
My HP desk top shuts down during boot. I've
The CPU cooling fan usually sits on top of a heat sink which is held tightly agaist the core of the CPU by the clasps you refered to. It soumds to me like the CPU has oveheated and will only function for a few seconds. If it's a fairly new CPU, you may be able to buy one online at places like http://www.tigerdirect.com. If it's an older model, you will have to try & find one at places like E-bay.
If you install a replacement make sure the CPU fan/heatsink clamps the CPU flush against the heat sink (apply a thin coating termal paste to the top of the CPU core).
NOTE: If the plastic clamps attached to the motheboard which hold the fan clips are broken - forget it! A new CPU will just ovehat again.
If you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Jun 24, 2011 | HP Computers & Internet
My laptop has been preparing to configure windows screen its been doing this for over 2 hours not sure what is going on with it
Bobby,
Please press F8 at boot up and boot in Safe Mode. Once booted, right click on the desk top and select Properties->Settings. Here Reduce the resolution of the screen display one notch and let it reboot normally after that.
If the problem still persists then Press F8 at boot up again and boot up in Last Known Good Boot. option.
Dec 27, 2010 | Toshiba Satellite L455DS5976 Notebook
How can I unlock the region code on my SR150M
hi
makesure there is no disc in the player. go into menu leave libary ilighted keep a eye on the top right hand corner type the code 57538 and in the top right hand corner u will see the code it is set to 1-2 region change the code to a 9 for multiregion open and shut the disc tray then go back into menu same again type in the same code if the number 9 is in the top right hand corner then it is know multiregion just leave don,t touch any keys after a few secounds it will be set. enjoy
Mar 10, 2010 | Samsung Electronics - Others
I HAVE A DELL FLAT SCREEN DESK TOP MONITOR . THE PROBLEM IM HAVING IS THAT AFTER I TURN IT ON , IT WILL BE ON FOR A COUPLE OF SECOUNDS THEN IT SHUTS OFF . BUT THE POWER CORD WORKS AND ALL IS OK
you problably have a power supply problem because of litning or maibe a super charge and the power supply is defected and the only way to fix it is replace the monitor power supply thanks
Oct 20, 2009 | Computers & Internet
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Desk top icons
Right Click the desktop, select "Sort By", select "Show Desktop Icons". Done!
Dec 06, 2008 | Dell Inspiron 2200 Notebook
Acer Monitor boots up w/computer then "no signal"
you must have disconnected it while the pc was running.damage can occur while doing this as can a keyboard (they are not like USB devices that can be plugged and unplugged while "hot".)
Jul 20, 2008 | Acer AL1916W 19" LCD Monitor
Shuts off about 5 sec. after i turn it on
The power amp module ( s) have probably "bought the farm"
Post what part numbers you find on them.
Jan 05, 2007 | Harman Kardon AVR 510 Receiver
ZT Group CISNET A7022 PC Desktop Logo
35 people viewed this question
Top ZT Group Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Kyocera HP Expert
didi2005
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
