Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Dishwasher leaking out front door - Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Sep 08, 2010
4 Suggested Answers
  • 171 Answers
SOURCE: Whirlpool DU1100XTPS dishwasher leaking from front door panel
Hi karen_kinzer,
I'm Harvey the Master Plumber.
The d/w was a recent purchase?
Then my advise to you is don't worry about it! The unit should be under warranty. It's time to make the call. Let the warranty repairman worry about it. If he can't fix it, he has the authority to condemn it and you'll get a new one. Anyway, this is one problem you should not have to worry about.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
  • 423 Answers
SOURCE: dishwasher leaking from front door..not gasket leak
Contact LG support number. Have proof of purchase info available, but even if the LDS 5811ST is out of warranty, explain the symptom then firmly but politely explain that you are aware of a retrofit program for the LG LDS and LDF models that fix the problem of poor drying and water leaking from the _door_ panel (Lower left area)
Insist that they schedule a service call (no cost) or replace your dishwasher with the retrofit applied.
Good Luck!
Posted on Apr 06, 2009
joe_lishman
  • 192 Answers
SOURCE: my dishwasher is leaking water from the front door
The water inlet level setting could be faulty and thus "overfills" the washer with water. The water level is senced via a plastic tube feeding an ajustable switch. Sometimes the plastic pressur sence pipe gets clogged and water level is then not correct. The switch can have burnt contacts and might need replacing.
Posted on Jan 24, 2010
Dishwasher leaking
Hello - Make sure that dishwasher is level; if not, water can leak over the front lower baffle in the door. Look along the cabinet and see if the dishwasher is even with the cabinet. Another possibly could be that the dishwasher has a poor or damaged door gasket. If it is not sealing properly, it may need replacing.
Dec 08, 2012 | Frigidaire Dishwashers
No water going in and water leaks from front door
Leaking Dishwasher
heatman101
rrrw
May 29, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher leaking out the bottom of the front door
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
May 15, 2010 | GE Nautilus 24" Built-in Dishwasher
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Leaking dishwasher
i had a ge that leaked in front, needed to replace rubber door gasket....
Nov 09, 2008 | GE Nautilus 24" Built-in Dishwasher
My kenmore built in dishwasher is leaking out the front
change the door gasket. also check to see if the wall hasn't "sprung out" of position this will always cause leaks if the side walls aren't supported.
Feb 02, 2008 | Dishwashers
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
124 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
