Microwave Ovens Logo
Posted on Sep 07, 2010
I have a FreshStart Oasis FSTB-B60. The water is running slow. Should I put vinnegar in to clean it?
Microwave burn smell how to remove
put an ozone generator inside for 5-10min. Unplug the microwave, then run the ozone generator for 5-10min. IF that does not work you may need to start replacing plastic bits inside.
GE dishwasher GSD6260JSS doesn't clearn as well as when new
water temp should be a minimum 140 degrees at inlet this can be checked with meat thermometer at kitchen faucet,also need proper fill of water entering dishwasher proper water pressure and fill also important for proper cleaning of dishes,if water is slow entering you may have sediment inside fillvalve screen if on well water in this case you will have to disconnect water supply line and take valve apart the screen is in side valve reassemble and test operation...if this does not work you may have to replace inlet vavle
My Mister Coffee adx 20 needs to be cleaned. Water goes through coffee maker at a very slow rate. I assume it is caused by mineral build up due to the water supply. Please advise
you should be able to clean it with a store bought descaler,but read the instructions before buying, or check with the assistant first.
What am I doing wrong. Cusinart 1200 less than a year old. Takes an hour to brew. Took out permanent filter and use paper #4 filter. Has been slow since I bought it. Please advise. Other than that,...
Try cleaning it with vinegar. Sounds like you need alot of help on this one run a full pot of vinegar through the machine. with a paper filter in the basket. then run two to three full pots of just water. this should help decale the coffee pot.
I just melted alluminum foil onto the bottom of my oven...what can i do to remove it. It is a self clean and don't think i can run the self clean?
The first rule in using a microwave oven is NEVER NEVER NEVER put metal of any kind inside. You are very lucky to have a microwave to clean and are able to talk about it.
Clean it manually until every last bit is cleaned out ... cross your fingers and hope it works when you turn it on for the first time. Put a coffee cup full of water inside. Do not test for longer than 1 minute 50 seconds. If the water is hot, you can continue to use your oven.
Thanks for your question at FixYa.com
How do I clean the machine
best way to do this is to put a hot bowl of water in the machine with lemon juice in it run on high for ten mins it will drive out all yucky smell buildup and simply wipe the iner casing with a clean cloth as the steam will lossen all the food splatter
take care .
2answers
Can you run a microwave with nothing in it? Someone told me that just putting a sponge in it will ruin the microwave.
hi, running it with nothing in it will cause it no harm, the only object that will cause it any harm is if you place anything metalic inside it whilst it is switched on.
to clean a microwave most people place a bowl of clean water inside and put the microwave on high for 5 to 10 min doing this breaks up any grime stuck inside the microwave making it easier to wipe off, you can also put a wet cloth in a bowl and switch it on doing this does the same as a bowl of water.
so the only thing that can cause damage is anything with metal in it this will cause it to short out.
hope that has been some help to you
2helpful
2answers
JVM1540DN1WW leaves food cold
Put in one cup of water at 2 1/2 minutes on high -- it should boil.
The fan slowing down is normal becaue the magnetron, which does the heating and, which pulls about 10 amps, will drop the voltage across the fan and slow it down.
What type of circuit was your old microwave using? Was it a circuit dedicated to the microwave?
Charlie
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
