Exterior hard drive not recognise by the computer
The exterior hard drive conected throug usb to the computer but you cannot find it inside the computer icon and cannot be used for backing my email razzoukg@msn.com also I have another problem 4gb flash drive sombody empty it and cannot be used anymore the wollum 0 have been change please any body with a solution please help george
  • 1 more comment
  • hcab123 Aug 21, 2008
    my problem seems to be similar to this one. My hardrive is connected via usb to the laptop, however, it is not recognized by the computer. it doesn't show up anywhere.
  • royandlinda Jan 01, 2009
    Buffalo external 500 GB hard drive USB 2.0 - spins up, makes clicking sound then spins down without computer recognizing it.
    Any ideas?
    Thanks!
    royandlinda@comcast.net
  • doodle65 Jan 31, 2009
    Buslink works fine on my Mac. I unplugged it to transfer some data to my PC and the it isn't recognized by the PC. This is the first time this has happened. I have tried several usb ports, same problem
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive shold be detected & configured automatically by the computer.
Can you be a bit more elaborative on the second issue.
What is "wollum 0" i cant get it.
Good Luck.
Live, Love, Laugh.
Posted on May 14, 2008
I have a Maxtor 500GB. It was working ok but today the green light is blinking and the external memory is not conected with the computer. I have tried using different USB ports, conecting an desconecting...
you could disassemble the case and remove the drive. it could then be connect via an external controller such as(http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2477926&CatId=3770) and test if the drive itself is good in which case it is the controller in the case.
cheapest way I can think of to diagnose these external enclosures
GL
Don't forget to vote if I have help you,
TY
Jammer
May 25, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
My PC does not recognise the La Lacie 1tb hard drive therefore I cannot access the data What can I do
First, try it on another computer. If you get the same problem then the USB controller in the Hard drive case may be faulty. You might be able to take the drive out and use another USB to PATASATA converter. These are available on the internet and in computer shops but you need to check the type of drive inside the case (IDE or SATA) before you buy one.
Feb 22, 2011 | LaCie Rugged All-Terrain (301017) Hard...
I have 500GB transcend Portabale hard drive but not working,need installation driver or some thing other ?
External hard drives connected to the USB port do not require any additional drivers for WIN XP, Vista or Win 7. If it is not being recognised at all then the USB converter inside the box is faulty. If the PC recognises the USB converter but not the hard drive then the hard drive may be faulty.
Feb 20, 2011 | Computers & Internet
Computer not recognising hard drive. I have even looked in disk management and it's not recognised there either. The hard drive is lighting up when connected so it is working.
HI sineadkirk1
There are several reasons why your hard disk can not be recognised by the computer
1> usb cable problem
2> usb port problem
3> the problem on a computer virus or hard disk
4> computer problem
5> hard disk problem
do the test one by one to ensure that the root cause
thanks&regards
Jan 09, 2011 | Western Digital Elements powered by WD 320...
Why is my computer not loading my portable hard drive
It's possible the circuitboard inside is broken.
or
does it recognise other devices
..did it come along with any sofware that u need to install and haven't yet???
Jun 25, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Computer recognises usb connection briefly and then drops it. computer never sees hard drive
This generally means you have a failed USB controller board or a failed drive inside the enclosure.
Try removing the hard drive from the shell and transferring it into a new external enclosure. If this works you're done, if not the fault is in the drive. I can offer you some advice on DIY methods or direct you to a professional lab near you if you provide your location.
Hope this helps FixYa,
Crankstart
Mar 23, 2010 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Computer cannot recognise the hard drive ;
inside there is a usb and data port attache in hard drive. some time thise port may be damage and also usb cable which we connect on computer may be damage. we came to know after changing two thing ,change one by one to check,
Sep 30, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Xp computer wont recognise new 250gb elements ext hard drive
use it on a differnet usb port
these portable hard drives have some issues with 1.1 usb ports
Jul 12, 2009 | Computers & Internet
The device used to interface the hard drive to the computer must be compatible with the USB port in the computer. (If our machine has only USB 1 ports but the device needs USB 2 or 3 then it won't function). If the ports are correct, connect up the drive to the computer and then power off the computer and power it back on. Older BIOS's will find the drive during startup and you will then see it as one of your devices.
Apr 02, 2017 | Toshiba Computers & Internet
Computers & Internet Logo
352 people viewed this question
David Payne
David Payne
