Question about Cameras
Casio Z-750 camera: The Select/set button has stopped working. Pulled and reset the battery and card. Still won't work. Can't do a full factory reset because the Set button won't respond. Any ideas??? Thanks
  • 3,083 Answers
I hate to be the messenger of tough news, but this is probably either a switch problem or ribbon connector. Since resetting didn't help, it's going to be, in all liklihood, a hardware problem.
The problem with the switch, is that it's a sealed push button type contact, and the plastic switch pin could be broken, or the contacts faulty. In this case, the switch board or pad has to be replaced.
If the problem is with a slightly loose ribbon connector, going from the switch plate to the main board, you can try to disconnect and reconnect them.
You might take it by a camera repair shop just to get a second opinion, but get an estimate if you elect to have it repaired, as often it's just better to buy a new one.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 07, 2010
My Casio ex-z75o is only taking 7 photos before it says memory full i have tried different memory card but no change
Delete the photos off the internal memory and remove the battery. this will reset it the factory setting and that should clear it up
May 03, 2014 | Casio Exilim EX-Z750 Digital Camera
Buttons locking
If taking the battery out for at least 15 minutes, pressing the power button without the battery in the camera, and then after you put
the battery in the camera doesn't work to fix a problem you can reset the camera to factory settings like this:
  1. Press the "Menu" button. Press the right arrow once to highlight the "Setup" menu.
  2. Press the down arrow five times to select "Reset All." Press the "Set" button.
  3. Press the right arrow button once to select "OK." Press "Set."
Apr 06, 2014 | Canon G12 Digital Camera
Casio privia px-750 how to do a factory reset?
HIS WORKS ON MOST. Turn the keyboard off.Hold the C note down at the far right of the keys.The very last C note.Keep holding it down and turn the keyboard on.
Jan 19, 2014 | Casio Privia PX-750BK - 88-Key Digital...
Reset original settings
If taking the battery out for at least 15 minutes, pressing the power button without the battery in the camera, and then after you put the battery in the camera doesn't work to fix a problem you can reset the camera to factory settings like this:
Nov 25, 2013 | Canon G12 Digital Camera
How do I reset my camera to its factory settings? all my pictures are blue.
Go into the camera setting and find "reset to default" and select yes.
Make sure you have good batteries too.
Dec 22, 2009 | Olympus EVOLT E-500 Digital Camera
My sony dsc w80 is taking green pictures! It was working perfectly, but recently every pic has a green effect. Ive tried to fix it but can't figure out.
Hello!
Please turn off the Camera and pull out the Battery then press and hold the Power button for 30 seconds. Next, reinsert the Battery and turn ON the Camera then reset it to the original factory settings. Furthermore, please ensure that the Battery pack in the Camera is fully charged.
Follow the steps given below to reset the Camera to the original factory settings:
Press the Home button then select Settings, Main Settings 1 using the control button. Next, select Initialize and OK.
This will reset the Camera to the original factory settings. If the issue persists then the issue is related to the image sensor of the Camera and service will be required to get it fixed.
Aug 23, 2009 | Sony Cameras
Flashes turn off and on in the LCD. beep sound
Hello!
Please consider the troubleshooting given below:
(a) Remove the Battery from the Camera then press and hold the power button for 30 seconds.
(b) Reinsert the Battery pack and turn ON the Camera. Please make sure that the Battery pack is fully charged.
(c) Next, try resetting the Camera to the original factory settings if the menu options are accessible on the Camera.
Perform the steps given below to reset the Camera to the original factory settings:
(i) Press the Menu button on the Camera to access the menu options.
(ii) Press the right arrow on the control button to select (Setup) setting, then press the right arrow again.
(iii) Press up/down/left/right arrow to select the Setup 1option.
(iv) Next, select the Initialize Option and select OK.
Performing the above mentioned steps will reset the Camera to the original factory settings.
If the issue persists even after performing the above mentioned steps then service will be required.
Aug 23, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Error code - Camera Stablizer is not available.
try resetting the camera if you can. This is a fairly easy procedure which involves either going into your setup menu and choosing "reset," or, removing the batteries for a few minutes. After which, you should have the camera reset to factory default settings.
Another tip for when you get home is to go to to the website and look for firmware updates. Download and install them.
Are you working with a Casio as this error is common with the Casio user.
In Casio EV-7, anti-shake only works in S-Mode or M-Mode and the speed must not be more than 4 seconds, which means the lighting must not be too dim.
If you have set it to the correct mode and lighting condition is not too dim, then you got to perform one more step - to set the anti-shake to on.
" In Record Mode, press Menu button
On Rec tab, select anti shake "
You will be given 3 options, Auto, Camera shake, Image blur.
Select Auto or Camera shake.
2. In connection with this, you may wish to read about the test on anti-shake function for the camera at DP Review
Thank You
May 12, 2009 | Casio Cameras
Sidekick slide malfunction
1. go to menu
2. select setting then click
3. scroll down the select reset factory settings
4. press 0000(4 zeros) as it ask for security code
Thank you
Nov 13, 2008 | Cell Phones
Cameras Logo
12 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
