Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
On my poulan xt pxt 12530 tractor...i shorted something out trying to start it with charger...it will turn over but wont start....maybe fuse ...solenoid....what should i check? Also i cant find 20 amp fuse shown in diagram
  • 25 Answers
SOURCE: 2005 Poulan PD17542LT Lawn tractor, It starts fine
Normal maintenance been applied to this rider ? Filters, lube, cleanings ? This sounds like an electrical issue (component hot), or a vacuum in the fuel tank. Next time it 'stops' open the fuel tank up and listen to any air 'whooshing' in.
Posted on Jun 23, 2009
  • 376 Answers
SOURCE: i cant get the drive mower belt on my poulan pro lawn tractor!
The belt you should have bought is part # 140294 and yes, it is longer.
Posted on Jul 29, 2009
  • 95 Answers
SOURCE: 42' Poulan 20 hp-I was mowing & there was a
Check compression, should be over 90psi to start. And check spark. The loud pop I am going to assume came from the exhaust, which if you lost spark would cause excess gas to ignite. Causes of no spark, bad coil, or defective and or damaged safty swith.
Posted on Mar 14, 2010
huffman49
  • 235 Answers
SOURCE: Poulan Pro Lawn Tractor (PB195H42LT)
sounds like you have a little rust on the very top of the piston. try this take the plug out and spray a little wd-40 in the hole(just a little) and pull the starter rope until the piston frees up(turn key to engage the starter if no rope) then trplace the plug and try to start it up...good luck
Posted on Apr 03, 2010
  • 12 Answers
SOURCE: have a 2005 18.5 hp poulan riding lawn mower,
most likey you have a short . how do you ingage your blades by button or lever. if the button type look for a shorted wire . look for a bad wire some times mice get in to it and chew wires .
Posted on Apr 11, 2010
My charger Wont start. Has new battery. Everything else seems fine. Changed the #9 and 22 fuse. Still wont start
Fuses don't make a burning smell when they blow. Yours is far more serious, something has shorted out and irreparably damaged an electrical component or part of the wiring harness. You need a mechanic, preferably at a dealership who have the diagnostic equipment and vehicle history to know where to look.
May 27, 2016 | 2009 Dodge Charger
My blades will not disengage after turning off manual switch poulan model xt- pxt16542
The clutch solenoid seems to get stuck, cleaaning may be the solution.
Jun 25, 2015 | Poulan Garden
Why wont it start
is the the battery 100% charged? and are the fuses good?also check ground wires.
Oct 04, 2014 | Poulan Garden
Poulan riding mower wont crank. wont turn over. no head lights
bad fuse more than likly a bad ignition switch
Sep 14, 2014 | Poulan Garden
Poulan xt 12530 lt with grabby clutch
there should be a adjustment rod from the pedal to the tension pulley
Apr 23, 2012 | Poulan Garden
Poulan xt mower won't start
check the safety switches
Mar 31, 2012 | Poulan Garden
How do i charge my poulan xt lawn tractors battery
if the battery is more than 3 years old just replace it but a charger you can get at a parts store a home depot type store walmart target etc
Mar 25, 2012 | Poulan Garden
Poulan lawn tractor wont start at all actually will not do anything tried jumping it nothing
Check the inline fuse to see if it is blown, should be located on cable running from battery to starter
Aug 08, 2010 | Garden
Apr 03, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
184 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
