I have a CGEU401M 5635P remote which appears to be functional, indicator light shows. It suddenly lost control of a Symphonic 21" TV. I do not have the manual for the TV code. Have tried instructions for other remotes, including scanning, and no go. Would you have the code for my TV? Don
SOURCE: tv codes
my screen is all blue with a red lock button in corner how do i unlock it
Posted on Jan 30, 2008
  • 73 Answers
SOURCE: Setting wrist remote controller
Follow the link below and follow the instructions for finding your watch module, once this is done you should be able to download your particular watch manual. Good Luck!
http://world.casio.com/wat/download/en/manual/
Posted on Feb 21, 2008
freetek
  • 5568 Answers
SOURCE: ld200em8 universal remote code
Check DTV's site to see if they have updated the code lists for your respective remotes.
I have two newer sets for which there are no codes too.
Seems like the term 'multibrand' remote might be more accurate than the common 'universal.'
Posted on Aug 27, 2008
SOURCE: Rrmote control codes
i need the code for philips universal remote i lose the code
Posted on Oct 12, 2008
SOURCE: GoldStar wireless Remote Controller Code for Toshiba TV
need codes for innovage jumbo universal remote
Posted on Nov 08, 2008
Can i use a 4-6 program universal remote control for my lcd color tv model num. wf20l6
Use code search to find something that can handle some or all functions of your Symphonic TV. If a search through all codes stored in the remote is unsuccessful, you may have to try a different universal remote. All possible codes are not stored in all universal remotes.
Aug 01, 2016 | RCA Televison & Video
What are step by step instructions on programming a he universal remote for symphonic tv
1. Turn on your Symphonic TV.
2. Press and hold SETUP until indicator lights
3. Enter 0053 (or 0189 or 0227 or 0456 or 0024)
4. Press CHANNEL UP. If your TV responds, it is programmed. If some buttons don't work, try repeating by entering one of the other codes.
Oct 28, 2014 | Universal Remote Control GE174Universal...
Sirs and mesdames: I have a Symphonic TV/VCR COMBO model # TVCRI3E1. The remote control part # (UREMT32SR007) is missing. Where can I find a replacement? Thanks, Ilia Rivera
Hello
Just buy one Philips Universal Remote control Model number [CL 034]. You can synchronise it with your Symphonic Combo by entering one amoung the following codes. Proceedings are also given.
Note: Switch OFF and Switch On your combo, before entering each code.
Three digit codes for Symphonic are:-
033/ 053/ 189
Four digit code for Symphonic TV/VCR combo is:-
0227
Four digit remote codes for Symphonic tv are:-
0053 0189 0227 0456 0024
Four digit codes for Funai are:-
0051 0189 0053 0227 0456 0042
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
You can also check according to the catelogue of that remote control also. The above given numbers are most common for all universal remote controls. OK.
Dec 24, 2010 | Funai Televison & Video
Program my symphonic tv
Here are the steps on how you will program your remote control to your Symphonic TV
1. Manually turn on the component you want the remote to control.
2. Press and hold the TV key. The illuminated ON•OFF key turns on and remains on. If you release the component key at any time during the Direct Code Entry procedure, the illuminated ON•OFF key blinks four times, and the process is exited.
4. While holding down the TV key, consult the list for the four-digit code that corresponds to your TV and use the number keys
(0-9) on the keypad to enter it. While you are pressing the
numbers, the illuminated ON•OFF key turns off.
5. After the fourth number is entered, the illuminated ON•OFF key turns on. At this time, release the TV key. If the illuminated ON•OFF key turns off, you have entered a valid code and have followed the correct
procedure for Direct Code Entry. If the illuminated ON•OFF key blinks
four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the process from step 2. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. To confirm that the TV key is programmed with the correct
code for maximum functionality, test the TV. Attempt to
control a variety of the TV’s functions with the remote. If some of the features of your TV do not work, try programming the remote with a
different code in the list until you find the code that allows the remote to control the majority of your TV’s functions. Different codes can provide
different levels of functionality.
7. Remember to enter the code for future reference.
The codes for Symphonic TV are as follows:
1026, 1033, 1038, 1046, 1155, 1189
Jun 13, 2010 | RCA RCR311B Remote Control
No remote, need code for universal remote
Try this method:
Turn on the device you want to program.
Press and hold CODE SEARCH until the indicator light lights then release code search.
Press and release the device button you are programing TV, the indicator light will blink once then remain lit.
Press and release OFF/ON until your device turn off.
you may have to press upto 200 times
When your device turn off press enter button the indicator light will go off,good luck.
Jun 02, 2009 | Symphonic WF20D4 TV
I need the codes for my Tv Symphonic I lost them
need codes for phillips-magnavox remote with a symphonic t.v
Mar 16, 2008 | GE RM24912 Universal Remote Control
Whats the tv remote code if i have a direct tv + remote.
The Directv remote isn't capable of fully emulating the native remote of the Symphonic Combo. You can get limited functionality though.
1. Move Remote slider to "AV1" position.
2. Hold down mute and select until you get 2 flashes of the green light, then release both keys.
3. Enter 20821 and observe 2 more flashes of the green light.
Next lock the volume controls to this device.
4. If you have moved the remote's slider from the AV1 position, move it back. The slider should remain on AV1.
5. Hold down mute and select until you get 2 flashes then release both keys.
6. Enter 993 and observe 2 flashes.
7. Press and release THE SELECT KEY and observe 2 more flashes.
You can control the TV's power using the big power button under the device selector.
Oct 23, 2007 | Symphonic WF20D4 TV
No input channels
Universal remote control are normally programmed for basic functions, ie. chennel up down, volume up down, numbers, etc. This is even written in the manual that they do not guarantee that all functionality can be used. Here are your options: 1. Try all the codes that match your TV, there is a slim chance that the other code have the functionality that you need. 2. Buy the original model remote control. 3. If you know of someone that have the same TV, buy a universal remote control with 'learning' function and copy the signal from the original remote control. I have the same problems before. Now I use my Casio wrist remote control to copy the special functions such as A/V so that even if the original remote control is lost, I can still use these functionality
May 23, 2007 | Symphonic ST419E TV
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
Electro Med Services...
