Question about GE WJSE3110A Top Load Washer
Hi. my ge wjse3110a won.t spin unless is start spinning it first by hand
  • GE Master
  • 43,501 Answers
The motor is going bad...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 08, 2010
Won't spin and does not wash properly
Sounfds like the belt is broken. An easy fix if you are handy.
May 02, 2012 | GE Washing Machines
Washing machine not spinning
HI! base in your complaint and explanations! i find the problem is the motor belt... maybe this is too loose belt... you can replaced a new one replacement belt... and make sure when you replace the belt is the same size in the original!
Nov 01, 2007 | GE WJSE3110A Top Load Washer
Will not agitate or spin, belt is fine. Motor is not turning, just making a humming noise. Is the motor bad or are there brushes that can be replaced or.....?
move the belt to see if it is not jammed and spins the rotor. If that is the case, the Humming noise is then an indication of a burned motor and not from a good motor trying to drive a jammed belt.
Oct 09, 2009 | GE WJSE3110A Top Load Washer
The drum seems to bang the side of the machine when starting a spin cycle, the drum also seems to lean over slightly
This is usually caused by an unbalanced load. You will want to stop the machine ASAP when you hear the "banging" noise, and reposition the clothing or towels, whatever you have in the washer at the time, to create a balanced load. If this doesn't help, I would suggest calling a repairman.
Aug 08, 2009 | GE WJSE3110A Top Load Washer
My washer turn on but won,t spin
tub bearings may be frozen up. Can you move tub by hand?
Jul 20, 2009 | GE WPGT9360EPL Top Load Washer
Washing machine noisey when drum turning
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 18, 2009 | GE WJSE3110A Top Load Washer
Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Mar 02, 2009 | GE WJSE3110A Top Load Washer
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
GE WJSE3110A Top Load Washer Logo
186 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
