Question about Kenmore 26732 Top Load Washer
The top agitator is not agitating! the bottom one is. what do I check?
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the Sears site for Agitator, basket and tub.
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
See the following illustrated steps to replace the "dogs"
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136
Posted on Sep 07, 2010
  • btutmaher Jun 14, 2011
    thanks...i'll try it
Need to replace the agitator dogs and can't remove the mover from the bottom section
Direct drive Whirlpool washing machines use a two piece agitator. In-between the two pieces there are cogs, sometimes referred to as "dogs," which will wear out. When the dogs start to wear, you will notice a clicking sound and the top agitator will not move as it should. When you learn how to replace the agitator dogs on a Whirlpool washing machine, you can have your Whirlpool working correctly again. Agitator dogs are available at appliance repair facilities.
* 1
Disconnect the Whirlpool washer from the wall outlet. Open the washer lid to access the agitator.
* 2
Insert a flathead screwdriver in the notch in the agitator cap. Twist the screwdriver to pop the agitator cap off of the agitator. If your model has an inner cap, remove the inner cap by pulling up on the handle and removing it from the agitator.
* 3
Use a socket wrench to remove the bolt in the center of the agitator. Most Whirlpool washers use a 7/16-inch bolt to secure the agitator.
* 4
Grab the bottom of the agitator with both hands and pull it straight up out of the wash tub. Do not have your face directly over the agitator. If it is stuck or pops up too quickly you could injure yourself.
* 5
Set the agitator on the floor and carefully place your feet on each side of the agitator. Grasp the top of the agitator and pull the top half of the agitator off of the bottom half. Turn the top half over to access the dogs.
* 6
Use needle nose pliers to pull the dogs out of the agitator. Install the replacement dogs into the agitator according to the specifications given the manufacturer.
* 7
Set the top half of the agitator back on to the bottom half. Make sure to align the two tabs together between the halves so that they will friction fit. Grab the bottom of the agitator and apply a thin coat of dishwashing detergent on the rubber gasket on the bottom using your finger.
* 8
Set the agitator back into the wash tub and secure it using the retaining bolt. If your model had an inner cap, set the inner cap back into the agitator until it snaps into place.
* 9
Place the top of the agitator into place and press down until it locks into place.
Mar 21, 2011 | Whirlpool Washing Machines
It leaves soap on the clothes after it goes thru the cycle and I noticed that the top part of the agitator doesn't move hardly. The washers model # is LSR8233JQO and the serial # is CK4729250, Type 111.
The agitator dogs (part # 80040) that grip and turn the top agitator to push the clothes into the bottom agitator during the wash cycle are worn and must be replaced. It costs about $5 and replacing it is an easy task to do.
Disconnect the power to the washer. Open the lid and remove the agitator cap by prying it with a flat-bladed screwdriver off the agitator top. Remove the 7/16 inch stud and seal holding the agitator to the shaft using a socket wrench with extension.
Lift the agitator off the shaft and pull the top agitator off the bottom agitator. Remove the cam that holds the agitator dogs from the top agitator.
Lay the cam upside down and install the agitator dogs on the slots. Hold the cam with the newly installed agitator dogs on one hand and the top agitator upside down on the other. Slide the cam up into the top agitator and turn the assembly in the upright position.
Align the cam and bottom agitator tabs and cut-outs and place the top agitator with the cam over the bottom agitator. Place the agitator assembly on the shaft and rotate it until the grooves match. Push the agitator down and reinstall the stud and seal. Do not over tighten the stud or the agitator will not spin properly.
Feb 10, 2010 | Dryers
Agitator wobbling from the stem. it comes right
Those are the agitator dog ears. They have teeth that grip and turn the top agitator during the wash cycle. It must be replaced when damaged or worn.
  1. Unplug the washer.
  2. Remove the fabric softener dispenser by pulling it off the agitator top.
  3. Look for the prying location on the agitator cap and insert a flat blade screwdriver between the agitator cap and the agitator then pry the cap off.
  4. Use a socket wrench, usually 7/16", with extension to remove the stud and seal holding the agitator to the shaft.
  5. Pull the top agitator from the bottom agitator.
  6. Pull the cam that holds the agitator dog ears from the top agitator.
  7. Lay the cam on its top and install the agitator dog ears on their slots.
  8. Hold the cam on one hand and the top agitator on the other.
  9. Slide the cam up into the top agitator and turn it over so that the agitator dog ears do not fall off.
  10. Reinstall the top agitator into the bottom agitator.
  11. Reinstall the agitator assembly into the shaft.
Jan 11, 2010 | Maytag Washing Machines
Series 80 Agitator top dosent work
I assume that your model number starts with a 110 instead of 100.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26842692
See the part "Dog, agitator "
Following is an illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Jan 09, 2010 | Kenmore Washing Machines
The bottom part of the agitator will turn, but not the top part
The agitator has two parts. One is the bottom agitator and then you have the top agitator that moves the clothes around. If the top part of the agitator is not moving. You probably need to replace the dog ears. Check the agitator dogs inside the top of the agitator, they are bad for wearing out, sometimes the agitator may only agitate one way when the dogs are worn out. This is an instruction sheet that came with the last parts I ordered for a Whirlpool/Inglis style direct drive washer agitator. If you need to replace your agitator dogs, please see this link for some repair aid. -- click on this link directly to get the detailed instruction for replacing dog ear
http://www.american-appliance.com/catalog/newsdesk_info.php?newsdesk_id=136
to remove the whole agitator check out the instructions as follows:
(1) Kenmore washer..... Remove the agitator cap, some caps unscrew and some will just pull off. Look for a bolt and remove the bolt, lift up on the agitator...picture1, picture2.
(2) Kenmore washer.....Remove the agitator cap, some caps unscrew and some will just pull off. Look for a plastic bolt and remove the bolt, the plastic bold will have a square in the middle that the square end of the shaft of an socket extension ( or a very large flat screw driver ) will fit into the square hole to unscrew the plastic nut off...remove the upper 1/2 of the agitator....remove thebolt holding down the bottom 1/2 of the agitator, lift up on the agitator. also you can get the exact required parts from www.repairclinic.com
This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya.
Nov 25, 2009 | Kenmore Washing Machines
I have a Whirlpool LSN1000LW0 Washer. How do I separate the agitator to replace the dogs?
remove the fabric softner assemble.if ther is a plastic cover remove it remove 1/2 bolt and reach down under agitator up. put agitator on the floor.put a foot on both side's of the bottom of the agitator.place a hand on both side's of top part of agitator and pull up.turn top agitator upside down and the dog's should come out along with the holder.replace the dog's.to put holder and dog's back in top agitatoruse your 1/2 socket and exstention.place the 1/2 bolt in socket and place holder and dog's on bolt.turn top agitator upside down and feed holder and dog's up in top agitator.holding socket and exstention in top agitator,rotate top agitator down holding dog's and holder in with socket and exstention.place top agitator over bottom agitator and line up the two aliment ear's on bottom agitator and use exstention to push top agitator down on bottom agitator.place agitator back on transmition shaft and replace 1/2 bolt.replace plastic cover and fabric softner assembly.
Nov 15, 2009 | Washing Machines
I can't get top part off the agitator
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
If you have a 2 part agitator assembly (Fabric softener dispenser, top agitator and main agitator)
First, push down on the ring around the bottom of the fabric softener dispenser and lift it off the agitator.
Pry the top cap (a short screwdriver into the slots in the cap works) of the top agitator.
Looking into the center of the top agitator, you'll see a plastic piece with a 1/2" square hole. Using a 1/2" socket set extension, unscrew the piece carefully. You might have to hold the bottom agitator in place while you do this.
The top agitator pulls up.
You'll see a bolt and screw holding the bottom agitator on. Carefully unbolt this one and the entire bottom agitator will pull up.
Sep 27, 2009 | Washing Machines
Agitator: bottom moves, top does not
On the Sears parts site:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691&pop=flush
replace the 110.26902691 with your model number (lift the lid and the model number should be printed on the cabinet) and look at the section on the Sears site for Agitator, basket and tub.
This is what they look like:
pd_26_110_80040?$pddetailsth$ #21 on diagram Dog, agitator (4) Number:3366877Substitution:80040 $9.25Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Sep 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore elite won't agitate properly
Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Agitator problem
Check and see if it spins freely in both directions. If it does, this means that your "dogs" are worn out in the top agitator. This is an easy fix. You just get the new ones (usually 10$ or less), pull the top cover off the agitator, then pull the center cap off inside of the agitator. Then you just remove the center bolt and pull the whole top agitator off. You will see the 4 plastic dogs right on the top of the agitator.
Oct 16, 2008 | Washing Machines
Kenmore 26732 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
