Question about GE (PSS26MSRSS) Side by Side Refrigerator
My frige does not dispense water or ice
  • 121 Answers
If when you attempt to dispence ice/water the light dims and the refrigerator seems to shut down unitl you let off the dispenser the main board is bad. http://appliance-repair-it.com/GE-refrigerators.html
Posted on Sep 07, 2010
Last night, I connected an active water line to the back of my Kenmore side by side. The ice maker is making ice but water water and ice is not coming out of the dispencer. There is another water jug...
You have a dual water inlet valve where your water supply connects. One goes to the ice maker and the other goes to the water dispenser by way of the water reservoir you mentioned in the fridge.
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing.You should hear the ice door open and the augur motor turning to turn the augur which pushes the ice out the door. If the augur doesn't turn Take all the ice out of the bin and try. perhaps the motor is too weak or the augur is locked up. Take the bin out and try to see if the motor will turn with no load. The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter when you try the dispenser. If you are, probably bad motor. If not ,dispenser switch or solenoid is not working.
Apr 20, 2011 | Kenmore Side by Side Refrigerator
Clogged Water Dispensor
The water inlet solenoid is the culprit. It lets water into the icemaker and water for the dispenser. Follow the waterline to the back of the frige and it ends at the water inlet solenoid. Note the 2 solenoids built into 1 part. Replace this part and you are done. Don't forget to unplug frige and turn off the water before you replace this part. EZ FIX...
Mar 29, 2010 | Kenmore 21.7 cu. ft. Top Freezer...
Kenmore refrigerator 71203100 ice maker does not make ice. I get water from the water dispenser inside the refrigerator, but no water in the ice maker. The metal bar used to turn the ice maker on and off...
The water inlet switch on the back lower is always the problem. It has 2 solenoids, 1 for water and 1 for ice. They never go out at the same time. Follow the water line to the frige and there it is. Turn the water off repalace the part and plug the frige back in. check for leaks and enjoy...
Mar 29, 2010 | Kenmore Refrigerators
No water or ice dispenses
replace water filter in the back of fridge
Jan 09, 2010 | KitchenAid KSSS36QK Side by Side...
I have water going through the water dispenser, but no water going into the ice maker. The infrared light seems to aligned with the receiver.
The water inlet solenoid on the back of frige has two valves that never go out at the same time. Follow the supply line to the solenoid. Turn off water supply, unplug frige and replace part.
Nov 06, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Kitchen aid refrigerator water dispenser does not dispense water. the ice will dispense, and there is no filter for the water, so i would assume no clogging is the issue. But any ideas would be appreciated...
could be a few things. fist, when you call for water, listen for a very faint "hum" noise, if you do hear that, it is either the solonoid on the valve, or the reserve tank in the frige froze. easy way to check. pull the frige out and un-plug from power. on the back of the unit is a cover on the bottom, remove cover. the valve is on the far right as your looking at it. it has 2 solonoids on it. there are two plastic water lines on the bottom of the valve, i believe the one on the left is for ice maker, and the right one goes to door dispenser. remove the water line going to the door dispenser and put a cup under the valve. plug in frige and call for water at the door for couple seconds, check to see if water came out of valve into cup in back. if it did, the valve is ok, if no water, replace valve. they run about $50. if you didnt hear the hum i talked about, and the valve is ok, let me know and i can walk you through checking and replacing the switch in the dispenser. good luck, shane
Aug 24, 2009 | Refrigerators
There is a smell from outside the frige
check drip pan for smell see if ice maker lever switch is up for noise
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
WATER DOES NOT DISPENSE, EVEN THOUGH ICEMAKER WORKS
the way you test that is by going behind the frige and taking the bottom panel and find the water connection as the line connects to the frige there is one line coming to it from the wall and 2 goin out in to the frige 1 goes to the ice maker and the other to the water at the door. disconnect one first and try getting water from the door, one of those lines is going to pas water when you do that, if no one passes water with this test replace that water valve.
Dec 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Re: Dispensing water and Ice
the water valve is located behind the frige, remove the lower back panel and follow the water line from the house to the frige as that line meets the frige that's the valve that may be bad,but before you change it, you can test it, remove one of the 2 lines that goes to the side of the frige and push the switch to get some water, water should come from back there, if not re move the other line, it meant that the first line belong to the ice maker, try the other one now, it should give you water. if not replace the valve.
Mar 26, 2008 | Kenmore 50522 / 50524 Side by Side...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
113 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
