Question about Dishwashers
Leaking water out the bottom of door - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Sep 08, 2010
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
Kenmore model #16761691 leaking at the bottom of the door. Where is the gasket located? Or is it another problem?
does it leak all the time or did it just start?try running it with nothing in it and see if it leaks,if the dishes were racked wrong the water can get deflected and leak out through the door,also,remove the bottom rack,look at the screws going around the bottom part under the wash arm,if any of those are loose it causes a wave in the dish washer and the water leaks from under the door.if it's leaking from one of the corners the gasket could be bad
Apr 17, 2011 | Kenmore Dishwashers
I have a side by side Kenmore refrigerator model #363-9562510. Water leaks from the bottom right corner of the freezer door from a small round cut out hole. This is the door that has the ice and water...
couple of things to check if you have a dispenser on this model there is a hose that goes up into the bottom of the freezer door you need to remove bottom kick plate and take a look at this...also if no water from that hose and its actually coming from the door you could have a ruptured line in the door itself.... next make sure the water is not actually coming from the freezer compartment as the drain in the freezer could be clooged and leaking over on defrost mode and out door...
hope this helps good luck...
Jan 05, 2011 | Kenmore Refrigerators
Why is water leaking from the bottom of the door? Do I need a new seal?
Hi, Yes... Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
May 20, 2010 | Amana 24 in. ADU5000D Built-in Dishwasher
Water running out of tube from fridge into bottom of freezer door that leads up to water dispenser ?
Is the water leaking from the bottom of the freezer door ? ( new door ) line is not replaceable inside the door .
Is the water leaking from the tubing at the connector ( about 6" from the bottom of the freezer door ) ( remove both lines from the connector , cut off about 1" of each tube and reinstall into the connector )
To access , remove the kickplate by either removing 1 screw on each side or just pull off ( held on by clips ) .
Apr 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leeks from the bottom of daewoo FRSU20FAI freezer door when dispensing water
There is a joint at the bottom of the door which can be loose and leaking. If it's not leaking there it would be hard to replace the water line in the door.
Sep 21, 2009 | Refrigerators
My whirlpool dishwasher is leaking water from the bottom of door
Water is being forced out under the bottom door seal. Is the lower spray arm melted on the bottom? Or is there something directing the water flow toward the bottom of the tub instead of up toward the dishes?
Sep 03, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Water keeps filling up under passenger seat in rear of car
My 2001 passat did the same thing. my leak was coming from the door panel. Open your door and use a water hose to simulate rain water running against your window. Water should run into door and drain out of several drain holes at the very bottom of your door. Check for water leaking from the bottom of your plastic door panel. The water runs down into the door and leaks through your inner door panel seal causing water to leak inside from the bottom of your door panel and run into the floorboard instead of draining out the water hole in the bottom of your door.
Aug 26, 2009 | 1999 Volkswagen Passat
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Dishwashers Logo
227 people viewed this question
Top Dishwashers Experts
