Question about Bell & Howell BH-10 Digital Camera
Memory error on splash WP5 camera, whats wrong?
Card error light flashing green
When the camera accesses the memory(card) a green LED will burn or flash. When it can't do what it wants, it will warn you.
A memory error, can be caused by lots of things. Like card full, card physically damaged, file system damaged. Too many folders, too many pictures. Wrong card (SD, SDHC or SDXC) cannot be used in every camera.
Check if you did put in the card correct (not the wrong way around) Check if all contacts on the memory card are clean, shiny and straight. Check if you did not switch the lock switch to the wrong position. Check if there are still pictures on the card, in an external memory card reader. put all the pictures you can find on the computer and than try to format the card. (in the computer, FAT 32) but after you put it in the camera. do a format in the camera too.
Success
Mar 05, 2014 | Samsung L200 Digital Camera
What's your problem?My PNY 16Gb sdhc mememry card keeps saying card error in my camera
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Nov 26, 2011 | PNY Attach? 16GB USB 2.0 Flash Drive
Memory stick error, and flashed C:13:01 and the memory stick on the top right. Whats wrong with it?
the screen is black wether i use picture or a movie. Whet went wrong. please help i needeit graduations is when i need it most.
May 26, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Memory card error appears on screen,camera seem to be locked
I would like to ask what memory card seem to be locked. is this literal so you cannot pull it out ? If so then the memory card might have been inserted in the wrong position.
Mar 05, 2009 | Canon PowerShot A700 Digital Camera
Memory card error in powershot SD1100
Try a retailer near you to see if they will allow you to test your camera with a SD card from a display camera.
Good luck, I hope this helps!
Gom
Nov 14, 2008 | Canon PowerShot SD1100 IS Digital Camera
When inserting a transcend 4GB card the camera shows "card error" when i then try to format it the camera locks and will not do anything including switching off. What is wrong and what do i do R L...
HI,
try to use memory card to other device like cameras, cellphones and other devices and if it still has error problem, your card may be the one defective. use other cards.
try to take pictures without using memory card. use only the internal memory of camera. if camera still display this error message, camera needs service.
Jul 16, 2008 | Cameras
Memory card error
Check the slot and see if the pins inside are fine, no breakages, free from dust etc. Try turning the camera on and off (completely remove batteries etc).
Mar 03, 2008 | Canon PowerShot A530 Digital Camera
Digital camera error
1. What's the make and model of the camera?
2. What's the make, model and capacity of the memory card?
3. How old is the camera?
Dec 19, 2007 | Cameras
Bell & Howell BH-10 Digital Camera Logo
Top Bell & Howell Cameras Experts
Sunil Pratap Singh
Sunil Pratap Singh
Are you a Bell & Howell Camera Expert? Answer questions, earn points and help others
