Question about Toys
How do I remove the cover to wash it? - Toys
  • 1,498 Answers
My name is Mike. A couple times a day I go looking around to give some pointers to our clients (you).
Look at it your question from our point of view, with potentially thousands of products, at this point no one here has a clue which one. The cover of what? We need a little more info.
More is better:
If you are serious about getting an answer, repost your problem, include Make, Model of the product that's misbehaving and what type of product it is.
Describe your problem clearly, concisely and with as much detail as possible.
For future reference:
Often, a problem can be the result of a seemingly unrelated event. It is always a good idea to include a recent history.
Additional information such as what steps have already been taken, has the product ever worked, is it new, etc. can have a bearing on providing the best solution for your particular circumstances.
Remember, you are a key participant in this process. We are not there, you are. We depend on you to be our eyes and ears. We can only respond to what you provide us. Without you, all our talent is worthless. How's that for an ego build?
What you get out of the experience depends on what you put in to it. So help us help you.
It would be also be advantageous in your case to repost your problem so that it is correctly categorized and starts over at the top of the queue. This way it can be directed to someone with expertise in the area you need. They may have the manual memorized. Who knows?
Best regards
Mike
Posted on Sep 07, 2010
Removing ferrari car seat cover to wash
Do not remove it unless you have the skills to remove the dozens of clips that hold the cover to the seat frame. BAD IDEA.
Oct 31, 2012 | Cars & Trucks
How do you remove the top cover ariston am xxl 129 washing machine
see the video and proceed according . God bless you
Oct 16, 2012 | Washing Machines
How do I machine wash my futon cover?
You should wash your futon cover separately from other items. You need to ensure there is room in the machine for it. Avoid using detergents containing bleach. Wash the cover using the cold wash/cold rinse cycle (unless label inscription suggests otherwise). After the wash cycle is complete, you can put the cover in the dryer and tumble dry on a low-heat setting. I like to remove the cover halfway through the drying cycle to flip it to ensure that it dries evenly.
Aug 01, 2012 | Furniture
How do I clean out filter in maytag dishwasher Model number DWU8260AAX
To clean the filter what ya do is
remove the lower rack
unscrew the center wash tower off of the lower wash arm
remove the screws from the pump cover (the almost frisbee shaped part with the stainer around the bottom of it)
lift off the pump cover...directly below the pump cover will be the filter it will pull off and can be cleaned in the sink.
this link is a drawing of the pump for your model http://c.searspartsdirect.com/lis_png/PLDM/M0112066-00006.png
the center wash tower is items# 1,27
the screws for the pump cover is item # 5
the pump cover is item # 4
the filter is item # 6
GENE
Oct 06, 2011 | Dishwashers
Wash load stops with a few minutes left and unit alarms f02, don't see any visable drain problems
Hi, pop off the front cover (3 Torx screws on the bottom lip) After removing the cover you will see a white plastic unit with a screw on cover on the front. Unscrew the cover (no tools needed). Pull the cover off then remove the strainer. It will have gray gook on it plus God knows what else. Clean the strainer in the sink replace screw the cover back on and your in business.
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i remove maxi cosi car seat cover for washing please
hi bodsierpa..hope this helps..good luck!!!
• First remove the belt pads.
• Open the rim at the sun canopy as far as possible
• Remove the cover from the hooks
• Remove the cover then from under the hooks and quick adjuster button
• Pull the buckle tongue sections and adjustment strap through the openings.
May 15, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Washing car seat cover
Here are the download instructions for the seat. Page 49 has the instructions for removing the cover.
http://www.coscojuvenile.com/instructions/index.asp
Feb 23, 2009 | Eddie Bauer Deluxe 3-in-1 Convertible
Filter in aqaurius 1000 washing machine
Depending upon which model you have, the filter can be be found in 2 different locations.
First, if there is a removable plastic cover at the bottom front of m/c, then remove same, and see if the filter is there.
If it is there, then unscrew plastic cover anti clockwise, remove and clean filter.
If no filter there, then remove lower rear cover of washer, locate large black hose at lower right ,remove clip and hose, remove plastic filter and ball inside ,and clean.
Be careful as there will be water run out.
Refit filter and hose securely, test for leaks.
Plz rate my solutrion.
Thanks.
Jan 16, 2009 | Washing Machines
How do I remove the back cover on the washing machines?
removed screws from top / bottom and sides? then pull top pcover back slightly and lift at rar to clear back cover manouver the flex drain pipe as you remove panel ?
Nov 01, 2008 | Zanussi FJS1225W Front Load Washer
Door seal replacement
This video will show you how to change a door seal on this Bosch classics 1200 WFL 2463GB/12 FD
Jul 24, 2008 | Washing Machines
Toys Logo
50 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
