Question about Mitsubishi WD-62825 62" Rear Projection HDTV
No response from the TV when turned on. Slight hum but no green light flashing....
  • 36 Answers
Power supply or mainboard deffective..go to your nearest mitsubishi srvice center
Posted on Sep 07, 2010
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
Turn on benq pb6200 with new bulb all I get is humming and no led
same problem here. checked fuse, mainboard seems ok. nothing looked blown.
Jul 15, 2010 | BenQ PB6200 Multimedia Projector
The tv Sony kdf-42we655 will not turn on, the light will flash green and make a humming sound but thats it, the light below that labeled "lamp" flashes red? Why is the tv not working properly and why is...
Your tv is a projection one - it uses a very powerful lamp/bulb to generate the light that used for the image. In your tv that bulb has died and must be replaced - it will cost about $200.
Jul 05, 2010 | Sony KDF-42WE655 Television
I have an lg 32lb9d that wont turn on. the green light flashes 19 times then goes solid.when it goes solid green the screen lights up ever so slightly and u can hear a slight humming sound???
You need to replace some bad capacitors on your power supply. Easy fix and you can do it yourself for less than $15 parts. I order mine from Digi-Key. Check out some videos on youtube for plasma and lcd repair.
You will need to identify which capacitors are bad on your power supply and order ones with same same ratings (micorfarads, volts, temp and actual size).
Good luck
Feb 23, 2010 | LG 32LB9D TV
Red light
sounds like its time to look into getting a replacement bulb.
Jul 18, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
The other night while watching the tv turned off by itself.
There are two usual causes for this. One is the convergence integrated circuits have failed. The second cause is slight leakage of one or more picture tubes.
Apr 15, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Akia 27 inch tv wont turn on
Power packs can be repaired, and most time it is simply capacitors. I don't charge an arm and a leg
Mar 26, 2009 | Akai LCT2715 27 in. LCD Television
Timer light will not go off and I cannot turn on TV
ybhughes,
Are you asking about the wd62525? If so that's a v26 chassis and equipped with a self diagnostic test by flashing a series of two digit sequence after depressing the power button. After depressing the power button count the number of flashes - then you'll see a slight pause - then another series of flashes. (for example: four flashes, pause and four more flashes is an error code 44). The unit repeats this coding at least three times so be as accurate as possible...
Bill
Sep 26, 2008 | Televison & Video
Mitsubishi WD-62825 62" Rear Projection HDTV Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
