Question about Garden
Refrigerator model HSS25GDMD, Serial# ZD213077 Defrost sytem is not working, coils freezing up. - I have checked the heating element and it is functional (continuity test OK and confirmed function by connecting directly to 120V and it was heating properly). - I tested sensor and it was working, but replaced anyhow. - I replaced curcuit board/electronics panel and the system is still not functioning! Comments: I replaced board because I couldn't figure out what else it could have been if element and sensor are working. The board came with some instructions that indicated I needed to cut one of the wire leads for ENCODER serial numbers starting with ZD, so I did that. Is mine an Encodoer model? What else could the problem be and how do I do diganostic tests? Thanks, Jeff Smith homeowner/handyman
  • yadayada
    yadayada Mar 16, 2017
    Lots of information but what is the question here??
  • 49 Answers
SOURCE: Fills with water, sounds like it starts to pump water then stops, then start again
you have a wash pump problem. can be 1 of 3 things. most likely something is caught in the pump impelor if not the wash pump motor may be faulty or ceized or it could be the capacitor for the wash pump motor is faulty. you can try removing the wash pump yourself and check the impelor if it spins freely then you will have a motor problem.
hope this helped
Posted on Feb 19, 2008
tech master
  • 120 Answers
SOURCE: Sears Kenmore Elite Refrigerator model
need model number even though it says kenmore we need to know the model will tell us the maufacturer but start by checking voltage at the outlet to see if you have proper ground
Posted on Oct 17, 2008
Sea Breeze
  • 4654 Answers
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Posted on Aug 05, 2009
Benimur
  • 6966 Answers
SOURCE: Refrigerator (s/n: AV051008384) refrigeration unit
Hi and welcome to FixYa,
Peltier devices although not that efficient are known to be reliable. On your described problem, possibilities are:
  • thermoelectric (Peltier) module(s) (most likely) - the active cooling elements.  Most design have several sub-modules connected in series to form an array.  Failure of one in between will fail the entire module;
  • controller board  (likely) - or more specifically the section that regulates/control supplied power to the Peltier modules;
  • sensor (least likely) - most designs would have a sensor for the hotside forced ventilation system.   If the external ventialtion (fan) fails, then the controller board would prevent supply of voltage to the modules;
  • connectors (a possibility) - other than the Peltier effect, it is possible to have electrolysis on the terminals/connectors which would cause corrosion.  Check and clean all connectors to expose fresh metal, ensure tightness and positive contact.
An easy check is to test for the presence / absence of voltage to the module(s).  If voltage could be found, then it would be the Peltier module(s) that have failed. Absence of supply voltage would indicate the controller board to be possibly faulty.  To confirm, determine if there is power supplied to the controller board but none is in turn supplied to the Peltier modules. Absence of power going into the controller board would indicate a power supply problem.
Please exercise due caution when working with a live unit.
Good luck and thank you for asking FixYa.
Posted on Aug 31, 2009
Testimonial: "Very good initial advice. Just wish that the FixYa Website allowe me to communicate more efficiently back to you to work this prob to resolution."
VinayT
  • 1884 Answers
SOURCE: My lawn tractor won't start
May be the coil is bad. have you checked the spark plug? If there is gas and spark then it will have to start.check the circuit breaker points. is there current in the cb points?
Posted on Sep 11, 2009
My GE 19.7 TFX20JR only partially freezes in certain areas and not cold on refrigerator side. This all happened at the same time it stopped making ice. Water still dispenses.
Check for frozen, iced over evaporator coil caused by defective defrost timer and/or heating element. Ice maker will not work unless freezer temp is around 10 degrees or less.
Mar 15, 2015 | GE Refrigerators
Not freezing enough
You might have ice building up on your evaporator coil. That ice serves as an insulator and prevents the internal freezer temps from going down to design parameters. The ice buildup is caused by the defrost mechanism not working - check the timer or the defrost heating element.
Jan 07, 2014 | Summit 12.6 Cu. Ft. Frost Free...
My Maytag side-by-side is a MSD2655HEQ. The coils in the freezer compartment keep frosting over and the refrigerator side quits keeping cool air. I've defrosted the coils with a blow dryer and the...
The defrost circuit in you freezer has failed that is why you have to defrost the coils. The defrost circuit consists of the heater element, the defrost thermostat and the control module. The control module turns off the compressor and powers up the heating element to melt the ice on the coil, after the coil reaches 40 deg F the thermostat cuts off power to the heater. The heating element and thermostat is mounted to the coil. If you have a multimeter and know how to use one, you can check the thermostat and heater. You can check the heating element with a multimeter to see if it has electrically opened. If it has then you will need to replace it. Check also the thermostat, it should be in series with the heater. It should read close to 0 ohms if it is freezing and read infinite ohms if the temperature is above 40F. If the thermostat and heater check out, the problem might be with the control module.
Oct 05, 2010 | Maytag MSD2655HE Side by Side Refrigerator
My Whirlpool Freezer/Refrigerator model# ET19RMXGW02 is not keeping items cold. The ice maker is not working. There is frost in on the back wall of the freezer but objects like ice cream are all soft. ...
your evaporator coil behind this frost on the wall is iced up and you cant blow cold air through solid ice,remove this panel and defrost the coil,then check the defrost heating element below the coil,the defrost thermostat located on the coil or the defrost timer itself for being defective
Aug 05, 2010 | Whirlpool Refrigerators
My refrigerator model # JTB2188AEA the bottom half dosent get cold enough and the top half get cold but dosent freeze
your evaporator coil in the freezer behind a panel has iced over and the fabn can't move air over a solid sheet of ice,remove the panel,defrost it with a hair dryer,then check the defrost heating element and defrost thermostat under the coil and defrost control in the refrige section for proper operation
Jul 28, 2010 | Jenn-Air Refrigerators
Kenmore won't cool down.
I you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 15, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Refrigerator and freezer not working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 15, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator portion temperature has dropped to 65-70 degrees even on highest setting. This is an older model manufactured in 1992 with the freezer on the top. Serial # GG516729.
Aug 12, 2009 | Refrigerators
I have had to have my appliance repair man unthaw and unclog my condensation drain 2 times in the last 3 months. The bottom of the freezer freezes and water drips into the fridge. My refrigerator model #...
Three things. First is that your defrost element is faulty, replace. Second, if the defrost element is working there is usually a thin filiament of aluminium which is attached to the element and inserted into the drainpipe, this keeps the drainpipe from freezing up by radiant heat conducted from the element. Thirdly, your main pc board defrost side is faulty and needs replacing.
Mar 09, 2009 | Refrigerators
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
