Question about Health & Beauty
The unit is a Respironics BiPAP Plus, M Series, Model 600M. When plugged in but off all lights flash and screen reads "system problem", when turned on only operates in the low air volume mode.
yalmer
  • 549 Answers
SOURCE: Ionic Breeze Quadra Electrostatic Air Cleaner, Model S1637
http://www.allergybegone.com/ionbreezquad1.html
There is a manual for your purifier at this website.
It is in pdf form, free to download.
look for the sentence on the page.
it will take you to the download.
Posted on Feb 25, 2008
SOURCE: samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Posted on Feb 13, 2009
SOURCE: Screen flashing
I had the same problem. You will need to put it in the car cradle and plug it into the car charger. It will come on immediately.
Posted on Jul 04, 2009
kingbrizzle
  • 407 Answers
SOURCE: problem with mitsubishi air roof units
The thermostat would need to be insulated better from the air that is surrounding it. Im assuming that the thermostat is located on the wall unit where it blows out the air. This could mean that it is actually reading more from the outside temp, than whats inside the house. Another thing to consider is the location of the thermostat, even it being close to anything in the house that produces some kind of heat will effect the condition of the air. If anything, its the manufacturers mistake if it was properly installed in the first place and if defective, they should replace it. hope this helps.
Posted on Dec 28, 2009
SOURCE: The operation and timer lights on my Fujitsu split
I have same problem like yours to my newly installed Fujitsu multi-split system (the first time use since system installed 1 week ago). I rang the electrician who did the installation; he said it must be the units themselves nothing to do with electricity.
Okay, then I rang Fujitsu and their local service agent. They suggested me to switch off C/B for an hour to reset the units. I followed the instruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired to the outdoor unit). So I used a multi-meter to test the power terminals of indoor units (Danger! If you have no idea about this, don't even try! ): it seemed no power supply even C/B is on. I turned to the isolator which next to the outdoor unit. The isolator was making arcing noise when I switched it on and off. The indoor units suddenly turned on for few minutes then died again.
So I figured out the problem is that crooked isolator. I called the unhappy electrician to replace the isolator. End story....
I hope my experience will help you a little bit.
Posted on Nov 23, 2010
How do i get my resperonics vpap 25 to turn on
James, I used to have one, but I spent so much time fighting it that I gave up and sold it. I would go online and check out sleep apnea mouthpieces (that typically treat snoring, but work for apnea as well!) They work pretty well, are much less expensive and much quieter, and much less invasive!!!! Good luck!!
Aug 16, 2014 | Philips Respironics Auto BiPAP Machine...
I have a code E-35
Just so you know there is a recall on this and may end up with a new one... read below
Respironics, the manufacturer of the Respironics REMstar Heated Humidifier, has received complaints of failures of the AC inlet connector on the REMstar Heated Humidifiers manufactured between December 2001 and April 2003. A small number of these failures have resulted in thermal damage to the humidifier enclosure, and there is a remote possibility that a thermal failure could result in the ignition of materials external to the device. For this reason, Respironics is asking that you remove the humidifier from its power source. You may continue using your CPAP device.
Respironics has decided to take voluntary action to mitigate the risk of failure. This action includes only the model 1005792, U1005792, R1005792, SC1005792, AC1005792, and 1007861.
This voluntary action is classified as a medical device recall, and is being conducted with the knowledge of the United States Food and Drug Administration (FDA).
WHAT TO DO:
Call Stericycle, Inc at 877-574-5038 or 317-275-7667.
Jul 02, 2014 | Respironics Remstar heater humidifier -...
Respironics synchrony bipap error code 084
i alway get error 41 while using respironics bipap avaps what should i do please sujjest me some thing.
Nov 15, 2013 | Respironics BiPAP Synchrony Blower...
Humidifier is not warming. Indicator light had
reset the humidifer, Turn off, wait for 3 minutes, and try again.
If the problem persist, see your owner manual go to the website from the supplier and get support via ONLINE chat for fix it.
God bless you
Oct 12, 2013 | Philips Respironics Auto BiPAP Machine...
Check engine light for volvo 850 wont go off wat else can be the problem if i got a full tune up and put in new spark plugs plus it trembles alot and it shakes when i start it up plus wen i put it on...
Hi, I recommend you access the OBD panel to extract the trouble codes. Then send us the trouble codes for further advice. On 850 models the DLC is located in the engine compartment in front of the module box, behind the passenger side headlamp.
  1. Open diagnostic socket cover and install selector cable into socket No. 2 for fuel injection codes or socket No. 6 (except Motronic systems) for ignition codes.
  2. Turn the ignition switch to the ON position.
  3. Enter control system 1 by pressing the button once. Hold the button for at least 1 second, but not more than 3.
  4. Watch the diode light and count the number of flashes in the 3 flash series indicating a fault code. The flash series are separated by 3 second intervals. Note fault codes.
1f there are no fault codes in the diagnostic unit, the diode will flash 1-1-1 and the fuel system is operating correctly.
  1. If diode light does not flash when button is pressed, or no code is flashed there is a problem with the soft-diagnostic system, proceed as follows:
    1. Check ground connections on the intake manifold, and the ground connection for the Lambda-sond at the right front mudguard.
    2. Check the fuses for the pump relay and the primary pump. On 240 models, fuses are located inside the engine compartment on the left side wheel well housing. On 760/780 models, fuses are located in the center console, just below the radio. On 740/940 models, fuses are located behind the ashtray. Access can be gained by removing the ashtray, and pressing upward on the tab marked electrical fuses press. On 850 models, the fuses are located on the left side of the engine compartment behind the strut mount plate. The fuses on 960 models are located on the far left side of the dashboard. The driver's door must be open to gain access to the fuses.
    3. Remove glove compartment, and check control unit ground connections.
    4. Turn the ignition switch to the OFF position. Remove control unit connector and connector protective sleeve.
    5. Check diagnostic socket by connecting a voltmeter between ground and No. 4 connection on the control unit connector. Reading should be 12 volts. If no voltage is present, check lead between control unit connector and fuse No. 1 in the fuse/relay box.
    6. Turn the ignition to the ON position, and install selector cable into the No. 2 socket on the diagnostic socket. Connect a voltmeter between ground and No. 12 connection on the control unit connector. Reading should be 12 volts. Press the button on diagnostic socket and note reading. Reading on the voltmeter should be 0 volts. If no voltage at the control unit is present, take reading at the diagnostic socket connector. If reading remains at 12 volts when button is pressed, check diagnostic socket.
    7. Connect a voltmeter between ground and the red/black lead on the diagnostic socket connector. Reading should be 12 volts.
    8. Connect a suitable ohmmeter between ground and the brown/black lead in the diagnostic socket connector. Reading should be 0 ohms.
    9. Turn the ignition to the OFF position. Connect ohmmeter between diagnostic socket selector cable and the pin under selector button. The ohmmeter should read infinity. Press the button and note the reading. The reading should be 0 ohms.
    10. Connect a suitable diode/multimeter tester, or equivalent, between the diagnostic socket diode light and the selector cable. Connect red test pin from the tester to pin under diode light and black test pin from tester to selector cable. A reading on the tester indicates correct diode light function. With no reading on tester, replace diagnostic socket.
    11. Check the system relay/primary relay by connecting a voltmeter between ground and the No. 9 connection on the control unit connector, then connect a jumper wire between ground and No. 21 connection on the control unit connector. The relay should activate and the reading should be 12 volts.
  2. Press the diagnostic socket button. Note any additional fault codes.
The diagnostic system memory is full when it contains 3 fault codes. Until those codes are corrected and the memory erased, the system cannot give information on any other problems.
  1. Press the diagnostic socket button for the third time to see if a third fault code is stored in the memory. If the diode light flashes the same code 1-1-1, there are no other codes in the memory.
Fig. Fig. 1: Push button once for mode 1
Push button twice for mode 2
Push button three times for mode 3
To clear the codes:
  1. Turn the ignition switch to the ON position.
  2. Read fault codes.
  3. Press diagnostic socket button 1 time and hold for approximately 5 seconds. Release button. After 3 seconds the diode light should light up. While the light is still lit, press the button again and hold for approximately 5 seconds. After releasing the button, the diode light should go off.
  4. To ensure that the memory is erased, press the button 1 time, for 1 second but not more than 3 seconds. The diode light should flash code 1-1-1.
  5. Start and run engine. If engine will not start, correct the problem before proceeding and start over with Step 1.
  6. Check to see if new fault codes have been stored in the memory by pressing the diagnostic socket button 1 time, for 1 second but not more than 3 seconds.
  7. If fault code 1-1-1 flashes, it indicates that there are no additional fault codes stored in its memory.
Oct 05, 2011 | 1994 Volvo 850
Unit won't power on
I use a Respironics myself. It sounds like you have a shorted Power supply brick (the block halfway up your power cord). I have been in a similar situation and used a laptop power supply and swapped out the unit end of the cord. Most any PC or small appliance shop should be able to test your brick for you.
May 04, 2009 | Computers & Internet
Laptop won't dock
The inspiron 600M will not function in a D-Dock, but will work in a D-Series port Replicator. (Although the D600 and 600M share the same motherboard, the bottom plastics are different)
After trying the 600M in the D-Dock, it is possible the dock is damaged. I would undock the D630, then delete the docked profile. power off, dock, and reboot and see if it detects and works.
Jan 16, 2009 | Dell Latitude ATG D630 Laptop
Health & Beauty Logo
192 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
