Question about Fedders A7DH45B2A Dehumidifier
We purchased this unit at home depot 3 years and now it does not work anymore , we start it and it does not go below 70 please give me some info
    Master:
    Sergeant:
  • 449 Answers
Sounds like you need to check the condensor unit
Posted on Sep 08, 2010
Ihava a dehumidifier MOdel#106955250. The coils are icing up, can you help me?
as with any freeze up of any unit (any mfg) there are a few things to look at first before consulting a profesional ,
1st ck your filter most units have a filter these are the most forgoten things when it comes to reg cleaning , remove it and run under tap shake excess water off and replace in unit
2nd is unit warm enoght to work air temp has to excede 68 degrees for these to work
3rd how old is unit if unit is over three years and has been largely neglected for cleaning and maint issues then overheating can cause gas charge to leak out and cause freeze ups , replacement is only option on this reason
4th setting: is unit large enoght to remove water from area if its undersize it runs too hard and never cycles off/on this causes freeze ups , purchase a small humidmeter to measure the area % rh 70%rh is considered normal for a home
Oct 13, 2014 | Kenmore Dehumidifiers
BUCKET DOES NOT FILL WITH WATER
It could be the coil & condensor are dirty.
Or it could be that the humidity level is below what the unit will work at. Below 50% humidity and or 70 degrees Fahrenheit, it generally will not do much.
I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. If it actually still runs, I would suggest you take off covers and give the coils a good thorough cleaning. Otherwise the units are not designed to be serviceable aka - "disposable small appliance". if you do dispose of it take it to a qualified recycle organization for Freon products. WHIRLPOOL DEHUMIDIFIER Parts Model ad75ust0 Sears PartsDirect
Aug 08, 2013 | Whirlpool 75-Pint Dehumidifier
The unit still makes a running noise but seems to collect no water. this unit is about 4 years old but stopped collecting water about 2 years after purchase
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 30, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have always set my M7DH45B2A at 60 percent (it's in the basement). Lately it runs all the time and the humidity does not go below 65 percent. It seems "stuck" there even if I lower my...
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 65 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope the above helped you. Please let me know and thanks for choosing FixYa.
Aug 10, 2011 | Maytag M7DH45B2A Dehumidifier
Unit doesnt work properly .. no water ...when front cover is removed piping towards top has frost on it .. but coils have no frost or moisture .. purchased 3 years ago at ace hardware clear lake Iowa...
Hi, The unit has leaking freon and is low on charge... not worth fixing...
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
May 16, 2011 | Comfort-Aire Dehumidifiers
Dehumifier blows out my electrical switch in my electrical panel.
You definitely have an electrical short in the unit and should stop using immediately. Have it checked out by a licensed electrician. It is a very real fire hazzard.
Jun 07, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Dehumidifier
After reading comments and complaints from other frustrated Maytag owners, I just went out and bought a new LG EnergyStar dehumidifier. I'm taping the receipt inside a plastic bag, along with the user manual, to the side of the machine. Hope this one works for a LONG time! Ronnisue
Jun 15, 2008 | Maytag Dehumidifiers
Fedders A7DH45B2A Dehumidifier Logo
Top Fedders Dehumidifiers Experts
Bill Long
jasbo
jasbo
Albert
Level 1 Expert
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
