Question about Jura Capresso Impressa S90 Espresso Machine
When I try to brew espresso-the espresso nolonger comes out of the machine where its supposed to. It just empties into the espresso ground resevoir instead. The rinse unit function does the same thing- jsut empties into where the spent grounds go.
  • 33 Answers
You a have a blockage in the spouts. This is caused by a number of things:
  • You used the wrong grind coarseness in the pre-grind
  • you used the wrong cleaning table for the machine (this is the most common)
  • you have an insect in the spout
  • The plumbing system has a fault, where the switch that re-routes the water is stuck
Try the following:
  • Take a paper clip and bend it open
  • Then that the point of the bent open peice, and insert in each one of the spouts and check if there is a blockage
  • if you feel something or something comes out, see if the rinse works, try a few times
If that does not solve the problem then you may need to get a service tech to look at it
Posted on Oct 31, 2010
Xp9000 does not in form me that it has run out of beans, any help please , thanks
They only know that the beans is empty when it comes to compressing the grounds into a puck just before brewing. If the brew unit has nothing in the chamber to compress then it assumes you are out of beans.. Remove and thoroughly clean the brew unit and make sure grounds are exiting the grinder when the grinder is running.
Oct 19, 2014 | Krups Super Automatic XP 9000 Espresso...
Need to descale k75.
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste
Nov 02, 2013 | Keurig K75 Black Platinum Coffee Maker w...
Water will not dispense on my Keurig Vue .Brewing process stops after a couple of seconds
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
RINSE:
Sep 29, 2013 | Keurig Vue Brewing System
When I hit brew, it sounds like its going to brew and stops right away.
RINSE:
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Aug 15, 2013 | Keurig Platinum B70 Coffee Maker
My machine does not completly drain the water into machine and does not make more than i/3cup of coffee
RINSE:
Apr 17, 2013 | Keurig B60 Coffee Maker
Mini keurig stops brewing and blows tops off k-cups
RINSE:
Jan 01, 2013 | Keurig Mini B31 Plus Black Coffee Maker
Lights for descale and grounds drawer flashing red
Have you ventilated the machine . turn to hot water and see if can get water out .
Dec 10, 2009 | Saeco Talea Giro Espresso Machine
Coffee has stopped dispensing
Looks like your machine is leaking internally and rather than the water come out of where it is supposed to, it is leaking inside.
Repair Service in New York
http://cerinicoffee.com/Saeco_service.asp
Or check saeco website for a service center near you.
Hope this helps,
Johnny C
Oct 27, 2007 | Saeco Vienna De Luxe Espresso Machine
Jura Capresso Impressa S90 Espresso Machine Logo
136 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Jim Goldsmith
Jim Goldsmith
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
