Question about Nikon D200 Digital Camera
There is black dot in left upper corner, every time i take picture of sky dot is there, it's not a lens cause i try different one, same result, any idea why?
    Problem Solver:
  • 10 Answers
Common problem, easy solution. It is dust on the chip.
At first try to blow the spot away on the image chip. Don't use your mouth or air, but use the airblaster.
And there are special swap stick which can help. Go to a photodealer, they will have the swaps. If you don't trust yourself, it's on the image chip, let the shop do it.
Posted on Aug 14, 2011
Nikon Coolpix p80 blacked out, rounded corners
Have you attached some sort of lens shade to the front of the lens? The vibration might have something to do with the shake reduction system but I can't be sure. It certainly shouldn't vibrate heavily. You might get a better answer if you e-mail the tech guys at the support section of the Nikon website.
Feb 19, 2010 | Nikon COOLPIX P80 Digital Camera
Canon power shot sd1000 black dot on lens
If by saying the upper right corner of the lens you really mean that there is a dark spot on each image AND the rear display, there may be dirt or dust on the lens itself. Clean the lens with an optical quality cleaner. Do not use paper towels and Windex or the like - as paper towels can scratch the lens.
It is also possible that the dark spot is a "stuck pixel" on the image sensor inside the camera. There is no way to repair a stuck pixel outside of replacing the sensor. Any dark spot (regardless of source) can be edited out by using image editing software. This will allow you to to make the dark spot less noticeable - or practically invisible.
If the dark spot is on the rear display only, it can also be a result of a "stuck pixel" on the display itself. This should not show up an images, but only on the display. There is little that can be done outside of replacing the entire rear screen.
There are other things that can cause these problems, but those listed above are the most common.
I hope this was Very Helpful and good luck!
Nov 20, 2009 | Canon PowerShot SD1000 Digital Camera
Black dot on top left corner and center of photos
This is dust on the sensor. Google the words...cleaning a digital camera sensor. You'll find instructions and sources for supplies.
Oct 02, 2009 | Nikon D80 Digital Camera with 18-135mm...
TI 84 plus calculator, flashing dot in upper left hand corner
When you turn the calculator on, its screen is cleared, save for a small square on the top left corner. This is the cursor and it is blinking: The calculator is waiting for you to order it to perform some calculation.
Try this simple operation
[1] [+] [1] [ENTER]. The calculator will display the result one line down justified to the right.
Hope it helps.
Aug 26, 2009 | Texas Instruments TI-84 Plus Calculator
I just bought a Nikon D60 on ebay,Theres a black dot in all pics
My guess is that you have a dust spot in the camera on the mirror. This is not a user fixable ptoblem unless you are very well versed on camera repair. I would take to a camera store and have them clean the mirror.
Aug 23, 2009 | Nikon D60 Digital Camera
CAMERA IS THREE MONTHS OLD. ON MY LAST OUTING I NOTICED A PERFECT CIRCLE SPOT ONLY IN SHOTS OF THE SKY. THE SPOT IS IN THE IDENTICAL PLACE ON ALL SKY SHOT PHOTOS NO MATTER WHAT FOCAL LENGHT IS USED. THE...
If you have another lens, switch it and take some shots of the sky. If the spot is gone, it probably was the lens that needs cleaning/servicing. However, it's more likely that there's dirt on your CCD. On your camera's menu, select mirror lockup/clean CCD (I can't remember the exact terminology but you get the idea).
After you select that, the mirror will stay up. Remove the lens and you'll see that the CCD is now exposed. Use a blower (don't use your mouth to blow as you will end up with spit in the camera) to clear out any dust/debris on the CCD. Don't touch the CCD.
Turn off the camera and you'll hear the mirror go back down. Re-attach your lens and try some shots.
Apr 13, 2009 | Canon EOS 40D Digital Camera with 28-135mm...
Screnn going blank
sounds like sky tv issue, try different cabling
Jun 02, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
TH-50PX60U picture problem
Try to replace the Logic Scan board on the upper left side of your tv. The part no. is printed on the board and you can order it from Panasonic's Website. Also check the Service Manual for the part description and part no.
Oct 17, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Camera shakes when turned on and when taking a picture there is a black area in upper left corner
This soundfs like a Zoom lens element problem May be expensive to get fixed Check out customer support
Jul 31, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Nikon D200 Digital Camera Logo
79 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
