Question about Kodak EASYSHARE 5100 All-In-One Printer
Printer my printer will not pull the paper into the printer whats the problem
    Problem Solver:
  • 13 Answers
Your probably not using compatible paper, try using kodak brand or even hp
Posted on Sep 08, 2008
What should i do when the paper stuch inside the printer and can't pull it out?
please backside of printer both lock of paper open lock and remove the paper
Apr 22, 2012 | Samsung ML 2010 Laser Printer
Paper feed problem - tilts to the left and tries to print can't see anything blocking right restarted printer, unplugged/plugged it back in don't know what else to try
The mechanism that "pulls" the paper into the printer is not pulling the left edge of the sheet of paper at the same speed that it is pulling the right edge. So, the paper "slews".
Check those mechanisms, and/or take the printer to a qualified technician, for professional repair.
Jun 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have a hp deskjet 3940 colour printer,there is paper jam error,so what i could do to solve the problem
Follow these steps :
1.1
Take out any paper that is not jammed. Remove the loose paper from the in and out paper trays to prevent any more paper from being pulled into the jam.
2.2
Open the cover of your HP laser printer. This will give you access to the inner machinery of the printer and should unveil the jammed paper. If you do not see jammed paper, you may have another type of malfunction.
3.3
Gently pull on the jammed paper. In many cases, it will come out easily.
4.4
Move the rotors on the inside of the printer by pressing the flashing button on the housing of the printer. This may help to loosen any jammed paper.
5.5
If the jam persists, unplug your HP printer. You'll be able to pull more firmly on the paper with the power turned off. Be careful not to rip the paper.
6.6
Attempt printing again. Refill the trays with paper and plug your printer back in to test its functionality.
Oct 30, 2010 | Office Equipment & Supplies
There's a paper jam in OKI B2400n printer. the manual says to take out the ink cartridge and the jammed paper could be pulled out. Well, the paper is tight and I can't pull it out. What can I loosen or...
You will have to pull hard and evenly to remove the paper. Often, the toner has built up on the fuser rollers, and the paper is actually stuck to the rollers. In that case, you will not be able to get all the paper out, it won't do you any good to remove the paper anyway, because the paper will just jam and stick again. Those rollers will need to be replaced. That is a pretty big, technical job.
Oct 18, 2010 | OKI Office Equipment & Supplies
The paper is stop in the printer
open the printer remove the toner and slowly pull the paper out. Pull in the natural printing direction of the printer, so if the printer pulls the paper from top-tray to bottom-tray when printing you should pull the paper from the bottom tray outwards
Jul 15, 2010 | Brother HL 2140 Laser Printer
Document comes out crumpled
Paper is not feeding through your printer properly.
First thing you should do is to remove the paper from your paper tray. After removing, place the paper back in the tray, making sure it sits evenly within the tray. There should be no part of that is higher than any other.
Next, carefully close the paper tray, making sure that no part of the paper catches when closing. Do this by feel. If you feel any resistance when sliding the tray shut, pull the tray open and try again.
If this does not solve the problem, open the printer doors and take a look inside the printer. There might be something small impeding the paper's smooth movement through your printer.
Finally, take a few seconds to clean the paper pulls (the little rubber wheels you see inside your printer). If these are dirty, the paper will not be pulled through the printer in an even way. It could pull off track causing one of the sides of the paper to rub against the printer. This is what causes the crumpling. To clean the paper pulls, just use a damp cloth and gently wipe them. Good luck!
Mar 25, 2010 | HP LaserJet 4050 Printer
Paper jam on printer
Apparently, you pulled out the paper with the printer on; that's wrong if so. Then it is likely you pulled it out jammed paper from the wrong side, (always pull out jammed paper in the reverse/backward direction of the paper movement). This is enough to unsettle your printer. What you should do now is shut down your computer, turn off printer. Then open all the "covers"of the printer, (top and at the back, if applicable) and close all again firmly. Turn on PC and try to print again.
Sep 27, 2009 | HP LaserJet 1022 Printer
PAPER FEED DOESNT WORK KONICA MINOLTA COLOR PRINTER
This happened to me one time after I pulled out a jammed paper the wrong way. I pulled it from the paper tray. Heard the sounds, it tried to grab the paper, but couldn't. It happened a long time ago, so I'm fuzzy on which part I tinkered with...but I recall that because I pulled the paper (backwards) from the tray, it flipped a lever/feeder/roller/thing and that 's why it wasn't grabbing the paper. If you look in the paper tray as the rollers go down to grab the paper, you'll see what's not working......sorry, lame solution.
Mar 26, 2009 | Konica Minolta magicolor 2430 DL Laser...
MF5750 All-In-One Laser Printer DOES NOT PRING indicate paper jam I check and there is no paper jamed in the printer. It starts as it will pull the paper to copy document and then indicates in the display...
It starts as it will pull the paper to copy document and then indicates in the display that the paper is jamed.
Can anyone explain what the problem my be?
Please assist me.
Jan 19, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Will not pull paper into printer...half the time
What sort of paper are you using? What sort of volume has the machine done? Have you ever had a jam and pulled the paper back out through the auto sheet feeder instead of feeding it through the exit rollers?
Nov 12, 2008 | Epson Stylus Photo R300 InkJet Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
13 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
