Question about Maxtor Hard Drive
Can not partition the whole hard drive 300gb
  • TELLIS877 May 16, 2008
    need software to partition hard drive above the 138 gig barrier
    Scholar:
  • 143 Answers
Hi. What version of Windows (or other operating system) are you using? Even if you are using Windows XP, if it is not at least Service Pack 1, you won't be able to see more than the (I believe) 138GB. Please elaborate on your question.
Posted on May 14, 2008
I've dual booted win8 with linux, to remove i used "easyBCD" to restore MBR, and deleted the partition. the deleted partition was lost and my harddisk capacity (showing as online) reduced to 300gb fro
erase your drive and deallocate and repartiton your whole drive using fdisk(windows) or utility softwares like killdisk
also one thing is to be noted that Linux systems recognizes the windows fat32 and ntfs partitions but windows doesn't recognize file systems like ext4 or swap which are the prime type of file systems partitions used in Linux systems!
May 31, 2014 | Computers & Internet
My windows XP OS won't recognize my SimpleTech SimpleDrive Pininfarina 300GB External USB 2.0 Hard Drive
I found that often, external hard drives just don't have any active partitions and thus don't show up in Windows. Go into the control panel, administrative tools, computer management and then the disk manager and see if it has a partition. If it's just unallocated space, right click and make one.
Jan 16, 2012 | SimpleTech Simpledrive Computers &...
Computer says "please insert disk" when I try to
chances are it's not formatted or possibly not partitioned.
I don't know which OS you are running, so I'll try to be semi-generic with the instructions.
Click START then RUN and enter diskmgmt.msc
find the 300GB drive (it may not have a drive letter)
if the drive has no drive letter, right click the unallocated space and create a partition.
If there is a drive letter on it, right click the partition and click format.
That should FixYa right up.
If you have any problems, let me know more info like what OS you are running etc. and where you're getting stuck.
Feb 24, 2011 | Maxtor OneTouch II external hard drive...
300 gb hard drive but only 32 gb is visible
Check your jumper settings on the drive it sounds like youve got the jumper over the 32gig limit pins.....cheers from Scott and plz vote
Oct 23, 2010 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
I have an external hard drive (300gb) that I want to convert to FAT32 it is currently unformatted and windows only gives me the option to convert to exfat or ntfs and neither are of use to me. How can I...
You cannot format FAT32 on such a big drive unless you break it up into many, many, suitable partitions, to format a drive this size you MUST use NTFS....
You see FAT32 simply cannot mathematically address that amount of address space, it is just that simple.
The biggest size partition is 32 squared or 1024MB
Jun 22, 2010 | HP (EK423AA) 300 GB Hard Drive
Lacie won't register that it's empty
Click Start
Right-mouse click My Computer
Click Manage
Double-click Storage
Double-click Disk Management (Local)
Right-mouse click on the 60GB partition
Choose Delete Partition
Click on the 300GB of "unallocated" space.
Create a partition that "spans" the 300 GB.
Format the new partition.
Jan 16, 2010 | Computers & Internet
Cannot access hard drive, USB port detects it, but does not access
You can verify what drive has been detected by your Operating System, which I assume is Windows of some sort by going to: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk will be displayed with all existing partitions.
I order to use any partitions in your new drive, you will need to assign a drive letter to each new partition.
If you have a brand new drive that is completely unformatted, then you will need, also via the context menu, Create partitions, Format partitions and assign a drive letter so that you can use the formatted partitions.
Hope it helps: let me know how you go!
Below is example of Disk Management display showing my external USB 300GB drive with _EXT disks & displayed context menu:
Jan 02, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Maxtor come on but my pc doesn't conect to it
The controller of the Hard disk enclosure is probably dead. Also check that the hard disk is formatted and activated as a partition.
Jul 29, 2009 | Maxtor 300GB ONE TOUCH 2 USB2- 7200RPM...
My segate 300Gb HDD keeps asking to format it when i recently pluged it into a new computer to transfer data to and it said that the driver didnt install correctly. since then it keeps asking to forma
I'm assuming that this was functioning at one point. If you are using Windows, Right click on my computer and click "Manage" Then go to disk management? Does it see the drive at all. If so, has a letter been assigned? It is possible that the operating system will show the drive even if it can't read the data. Look to see what file system and how it sees the disk having been partitioned. It is possible that your partition table has been corrupted. This can possibly be fixed using a tool like disk doctor or fdisk.
If, on the other hand, the drive is also making funny noises, you may have a mechanical failure on the drive.
May 29, 2009 | Seagate 300GB USB 2.0/FireWire Hard Drive...
Maxtor 300GB--can't delete or write
You didn't specify if the original PC was Windows or MAC.
Is this USB external used on a PC with Windows? If so is it formatted NTFS? If so, Mac OSX and pretty much everything else but windows NT, 2k and XP can not write to NTFS. OSX and Linux will read an NTFS partition but at this time not write to it. If your drive is formatted NTFS, I would say, go to a windows machine and convert it to a FAT 32 Partition. Most everything will both read and write to FAT32.
Jan 10, 2008 | Maxtor OneTouch II external hard drive...
Maxtor Hard Drive Logo
15 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
