Question about Amana Dryers
How many cubic ft is the Amana dryer model LE8217W2?
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: I HAVE A AMANA DRYER
sounds as if the motor is overheating, shutting off and not restarting for 10-20 min??? if thats the casse sounds as if yooull need a new motor assemly
Posted on Dec 03, 2008
protek480
  • 1723 Answers
SOURCE: Amana electric dryer model #LE8217W2 belt replacement
This will help:
Posted on Jul 08, 2009
stewbison
  • 577 Answers
SOURCE: whirlpool dryer model #LG7681XSW2
Hello, about 7 cubic feet or roughtly 1.918 feet X1.918 feetX1.918 feet equal 7.048 cu/ft. I hope this help you. GB....stewbison
Posted on Sep 22, 2011
hunter19_46m
  • 7482 Answers
SOURCE: amana dryer le8217w2 turns on
Hi victorgulliy...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
Note: This method works for most front loading machines.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
Here is a link to see a picture of your belt routing in case the belt is broken when you open your dryer:
http://www.expertappliance.com/dryerbeltconfiguration.html
While you have the drum out, I would recommend that you remove and lubricate the drum rollers.
And also clean the shafts of the rollers as they will collect hair,dust,etc and cause problems and then lubricate the shafts and rollers with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting dry and making a squeeling noise, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
Please take time to rate me thumbs up
Posted on Sep 23, 2011
What's the cubic feet of Amana TM17tbw refrigerator?
Yes, probably 17 ft^3.
Open the door, look on the walls, find the information plate, and write down the model number and serial number. Then go to the Amana website and look up the specifications. " Amana TM17tbw" won't cross to a specification but the exact model number from the label on the wall should.
Jul 08, 2015 | Amana Refrigerators
Whirlpool dryer model #LG7681XSW2 what is the cubic ft of this dryer? 22000 BTU...serial # MAO143334
Sep 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
I need to know how the cubic feet of this dryer
I am not sure if you have a solution yet. I see the post is 21 days old. The answer is that this dryer has a 7.1 Cu Ft capacity. That is 21 to 22 lbs of clothes.
Kelly
Dec 26, 2010 | Amana NDE2335AY Electric Dryer
We have Distinctions Model (7.1 cubic ft. super capacity plus gas dryer) It's running, but not getting hot most of the time. We removed the bottom panel & can see the glow plug get hot & ignite the...
OOOOoooKKKkk...
Please know your 'GLOW PLUG' should stay on 'only long long enough' to ignite the gas...
Your More/Less Dry function is probably a totally unrelated problem?
MAN you make this difficult !! Is yours a : Amana NDE2330AYW
27 Inch 7.1 Cu. Ft. Electric Dryer?? In fact I give up ~ I WANT to provide SPECIFIC help for you but DON'T want to guess about your stuff.
Anthony
Dec 23, 2017 | Amana Dryers
I HAVE A AMANA DRYER MODEL # LE8217W2 THEY DRYER WILL TRY TO START AND TURN OVER LIKE A COUPLE OF TIMES AND WILL HEAT BUT SHUTS RIGHT BACK OFF--BELT IS FINE ELEMENTS HEATS? WHAT WOULD BE NEXT TO CHECK?
Dec 03, 2008 | Amana NDE2330AY Electric Dryer
Cubic feet?
Most refrigerator models with two digits, the rest letters, the digits stand for the cubic foot capacity of the refrigerator. In you case, 23 cubic foot model.
Sep 16, 2008 | Amana Refrigerators
Amana Electric Dryer runs but does not heat up - model ndw2330ayw -
I HAVE AN AMANA DRYER MODEL LE8217W2 ITWILL COME ON FOR A SHORT TIME AND THEN CUT OFF. I CHANGE THE BELT, THE MOTOR AND THE THERMOSTAT. THE DRYER STAYS ON , BUT WILL NOT HEAT UP. WHAT'S NEXT ???? PLEASE HELP!
Nov 05, 2007 | Amana NDE2330AY Electric Dryer
Dryers Logo
130 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
